  1. Jul 18, 2024 at 12:30 PM
    Theebrain85
    Theebrain85 Member
    Hey guys new here lot of cool tacos
    m3bassman, Logans2001 and Speedytech7 like this.
  2. Jul 18, 2024 at 12:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Welcome to TW :)
    Theebrain85[QUOTED] likes this.
  3. Jul 18, 2024 at 1:47 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Not sure how well the speed bleeders work, but prior to using a Motive pressure bleeder, I did a 2 man bleed after the Tundra brake swap and could not get the firm pedal feel.
  4. Jul 18, 2024 at 6:30 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Did the pressure bleeder give you the firm pedal? I get really solid engagement at 50% or so no which I'm totally fine with but would definitely prefer better.
  5. Jul 18, 2024 at 7:37 PM
    ChargedSHOTaco
    Yes, only after I pressure bled the system did I get the firm pedal, which tells me that there was still air in the system even after multiple 2 man bleeds.
  6. Jul 18, 2024 at 7:43 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I also feel like my brake pedal pressure is temperamental. Sometimes it’s super firm and bites quick, other times I have to push a lot harder than usual. I’ve never heard of a pressure bleed. Maybe I need one too.
  7. Jul 18, 2024 at 8:20 PM
    Diy2k
    Diy2k Well-Known Member
    MG
    02 Tacoma, 2.7
    Softopper, shocks
    Did you crack open the ports that connect to the MC?
  8. Jul 18, 2024 at 8:38 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    If you’re directing to me.. no I did not. MC is master cylinder?
  9. Jul 19, 2024 at 10:05 AM
    noodles93
    Charleston, SC
    That's good to know, probably have it done with a shop whenever I find a place that wants do actually do my rear main. 2 bleeds and I didn't have much luck but don't see any air.
  10. Jul 20, 2024 at 8:56 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    unstpible likes this.
  11. Jul 20, 2024 at 10:03 AM
    Diy2k
    MG
    02 Tacoma, 2.7
    Softopper, shocks
    Yup,
    there’s a few tricks for fully bleeding systems.
    You can prebleed the MC, tap the lines lightly while bleeding, and tilting the brake calipers while they’re off the knuckle( but still connected).
  12. Jul 20, 2024 at 10:19 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
  13. Jul 20, 2024 at 10:23 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Who's done a power steering cooler? What cooler did you use? Any pics/build thread?
    Just looking for ideas.
  14. Jul 20, 2024 at 7:52 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
  15. Jul 20, 2024 at 8:24 PM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    No pics, but I replaced rotors & pads and both cv axles. I knew the passenger cv axle was ripped and spraying grease, so I got it when I ordered the rotors & pads. To my surprise when I went to change the brake parts on the driver’s side I saw that cv boot was ripped and spraying grease everywhere too. That side was replaced a little over 2 years ago. At least now I know the axles are good and the diff is full of nice, clean gear oil.
  16. Jul 20, 2024 at 8:45 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  17. Jul 21, 2024 at 2:26 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Finished making a new driver side transmission crossmember mounting bracket
    Speedytech7, jubei and Tour991 like this.
  18. Jul 21, 2024 at 2:40 PM
    FlexingtonKY
    FlexingtonKY Well-Known Member
    Sam
    The South
    2003 silver regular cab 4x4 Taco
    33” Dexteros, body lift, bed liner, and head unit
    thanks! I’ll refocus there then
  19. Jul 21, 2024 at 9:06 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Adjusted my windshield washer squiters, does that count?
  20. Jul 21, 2024 at 9:26 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I used a Derale transmission cooler for a power steering cooler. Just plumbed it into the return line and called it done. Zero issues on my end.
    PXL_20230618_222452345
    by Cory Bechtold, on Flickr
