  1. Sep 13, 2024 at 6:38 PM
    TragicBronson
    TragicBronson Well-Known Member
    Eddie
    Pflugerville TX
    2003 Tacoma Dbl cab SR5 4WD
    And now I deal with shoving the wiring harness between the windshield and weatherstripping for a flush look!
    Any suggestions? Im using plastic panel removers which work great until this point. I can use heat or lube but idk ‍♂️. Thoughts?
  2. Sep 13, 2024 at 8:36 PM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    Jersey Turnpike?
  3. Sep 13, 2024 at 9:49 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I just lock the CC on and let it do its thing.
  4. Sep 14, 2024 at 7:42 AM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    Installed Corbeau seat brackets and Corbeau Moab seats replacing the original bench seat. Folks at Corbeau are nice folks to work with and sell quality products. Used the existing threaded holes in the Tacoma's floor to mount the Corbeau brackets on our base model 2003 Tacoma that we purchased new in 2003 for less than $12,000. These seats are firm, but the more I use them, the more I like them! At 213,000 miles makes me wish I installed seats like this over 200,000 miles ago. Better late than never.
    Checked fit of Corbeau brackets with existing threaded floor holes before installing with brackets pre-mounted on new seats:
  5. Sep 14, 2024 at 12:28 PM
    moscow1972
    moscow1972 New Member
    2002 Tacoma Pre Runner
    Just wanted to show off my 2002 Pre Runner with white Nomad 501 convoy wheels. I love it. I really with it was 4x4. I might try to source a rear diff locker in the future.
    TacoLolo, Pbfender15, koenbro and 6 others like this.
  6. Sep 14, 2024 at 1:40 PM
    Phessor
    Phessor Well-Known Member
    Nice looking rig, and some nice looking seats.
  7. Sep 14, 2024 at 2:44 PM
    exploringcarolina
    Bill
    North Carolina
    The bench seat did not allow a short driver with a tall passenger, knees would be contacting the dash, no longer have that problem. The seats and mounting brackets are sturdy built.
    Going to install 1/8" thick grey plastic sheet covering the back metal portion of the cab and install a console organizer between both seats. Will also post about that when complete.
    Like you say, they look nice, too.
    Thanks!
  8. Sep 14, 2024 at 6:58 PM
    TragicBronson
    Eddie
    Pflugerville TX
    Figured it out. Outer insulation was too thick to fit so I removed it maybe 1.5 ft down and got a flush look.
    Long story short LED light bar wiring can fit in the weatherstripping and windshield but without the insulating wire the actual power/common/ground wires around surrounded with! I put adhesive RTV on where I think the water will pool. We'll see how that goes.
    Cheers.
    unstpible and noodles93 like this.
  9. Sep 15, 2024 at 9:57 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    The Race Taquito does in fact have this... ~74mph lol
    Fastest I've been in it so far, probably won't see the track till spring
    Speedytech7[QUOTED] likes this.
  10. Sep 15, 2024 at 9:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What happened to your gearing haha
  11. Sep 15, 2024 at 10:01 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Mostly going from a 31" tire to a... 25ish inch tire. Prerunner trans, speedo gear, and ecu in the low body.
  12. Sep 15, 2024 at 10:15 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Can't remember... LBJ bolts are M10 1.25 correct?
  13. Sep 15, 2024 at 10:22 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    M10x1.25 x30mm
  14. Sep 15, 2024 at 10:38 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Right on! Thank you. Had the bolts... may need a tap to chase...
    I have a slight problem.
    unstpible and Bandido like this.
  15. Sep 15, 2024 at 10:39 AM
    Speedytech7
    If anyone has a cordless grinder and a cutting wheel you can make a chaser tap with an old bolt pretty quick
    jubei and Parkvisitor like this.
  16. Sep 15, 2024 at 10:39 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I hate when that happens!!
  17. Sep 15, 2024 at 1:35 PM
    Phessor
    I've hit 110 mph in my truck a few times.
  18. Sep 15, 2024 at 1:45 PM
    Speedytech7
    Probably could going downhill, can't kill gravity with a computer
    Yetimetchkangmi and Black97v6MT like this.
  19. Sep 15, 2024 at 2:52 PM
    K-DubTaco
    Ken
    VB
    ‘25 TRD Off Road
    Damn man! Hope you can get the shit fixed fairly quickly out on the trails!
  20. Sep 15, 2024 at 3:21 PM
    SoutheastTaco334
    SoutheastTaco334 Member
    Alejandro
    Dothan, Alabama
    2004 Double Cab Taco
    Finally upgraded to the metal door handle. It feels much more sturdy and it was simple to remove and replace.
    K-DubTaco likes this.
