  1. Dec 15, 2024 at 5:05 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    More like Methuselah :p
    jubei and Digiratus[QUOTED] like this.
  2. Dec 15, 2024 at 5:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Or maybe Lazarus Long
  3. Dec 15, 2024 at 7:01 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Your references are dating you…
    Digiratus[QUOTED] likes this.
  4. Dec 15, 2024 at 7:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah seriously I haven't heard of any of these pornstars
  5. Dec 15, 2024 at 7:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup. Definitely pre-TikTok.
  6. Dec 15, 2024 at 7:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, definitely not Johnny Holmes.
  7. Dec 16, 2024 at 1:20 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I was going to say the same thing lol
  8. Dec 18, 2024 at 3:03 PM
    scofflaw
    scofflaw Well-Known Member
    Can anyone recommend an aftermarket front bumper (similar to OEM but not as pricey) for a 2000 4X4 Tacoma (TRD Off-Road MT Extended Cab)?
    - I got clipped by someone in a hurry recently and want to replace the bumper with something OEM adjacent (the OEM bumper costs probably 10% of what the whole truck is worth so OEM doesn't make sense).
    - There are some aftermarket options on Amazon and eBay (Evan Fischer seems to be a leading brand), just curious if anyone has had luck with them.
    - Planning to take the fender off as well and have a body shop paint a new one (rather than try to mend the crumpled front of mine).
  9. Dec 18, 2024 at 5:57 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    Check certifit and any of your local aftermarket auto body part stores they all have kinda the same parts be it local aftermarket or online aftermarket, some good some crap. The tong yang brand fender fit my 2001 perfect. You can also get sidemarker light from those places as well as rockauto but would not order bumper or any big body parts online cause of shipping usually eat your lunch. Good luck I just did fender bumper on mine got lucky found a bumper on craigslist.
    scofflaw[QUOTED] likes this.
  10. Dec 19, 2024 at 2:03 PM
    Sudog
    Sudog Member
    01 regular cab 2.7 5 speed 4x4
    Iv only had the truck for about a month or so. But when I bought it, it had 10 year old mischelins on it. I found a set of newer take offs but one of the tires I could never get to balance so finally I found a cheap set of swampers and I couldn't be happier. 20241219_164001.jpg
  11. Dec 20, 2024 at 7:04 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Door handle on the passenger side broke. So replaced both handles with those metal ones. So begins the truck project weekend.
  12. Dec 20, 2024 at 10:01 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Lube them before install!
    I replaced mine not too long ago, and before lubing when I went to open the door, the handle would catch on something causing the door to lock halfway. After lube its a nice smooth open.
    Toyota Dude and Parkvisitor like this.
  13. Dec 20, 2024 at 12:29 PM
    Moonrman
    Hill Country, TX
    Got me a CL Austin score, HF 12 ton press and toyota bearing tool for leaking rear seal PO had done. $120 for the package, nice. Tackle that after Holidays with confidence and not having my axles at a shop for days.
  14. Dec 20, 2024 at 1:13 PM
    noodles93
    Charleston, SC
    I was going to but they already had a ton on them from the factory. One mistake was not hitting the latch assembly while I had access.
  15. Dec 20, 2024 at 1:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's a great score
    Moonrman[QUOTED] likes this.
  16. Dec 20, 2024 at 5:03 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I think I sold mine for $20 earlier this year :anonymous:
  17. Dec 20, 2024 at 6:04 PM
    Moonrman
    Hill Country, TX
    I did get a press and the tool but Yeah, don't feel bad that's probably what I'll get for mine when I'm done with it.
    Tis Better than rack rates and a HF coupon.:cheers:
  18. Dec 20, 2024 at 8:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yours didn't have the the bearing tool.
  19. Dec 20, 2024 at 9:27 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Nice rig! I love 1st gen 4x tacos!!!
    Sudog[QUOTED] likes this.
  20. Dec 21, 2024 at 2:33 AM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
    Very nice catch. Is this a 12 or 20 ton? Thought the latter was needed for axle length...and for strength if want to do front bearings sometime. Looks like 20 ton is on sale now new for $219.
