  1. Dec 25, 2024 at 6:08 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Pretty much. 12V batteries are designed for a number of charge cycles at a certain depth of discharge. As the depth increases, the number of expected lifetime cycles decreases. Similarly as the temperature increases, the number of expected lifetime cycles decreases. So if you can keep your battery at a steady or near-steady state of charge and preferably at about 25C, that should maximize the life.
  2. Dec 25, 2024 at 2:59 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    New OEM mini header in today. Swapped out my LCE header for a walker pipe and OEM mini header. Truck is quieter I was chasing a vibration in idle and this was pretty much the last thing. Seems to have solved it. Didn’t get any better pictures
  3. Dec 25, 2024 at 5:43 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Seems like a downgrade to me. The LCE Street headed is a nice power upgrade for the 3rz
  4. Dec 25, 2024 at 7:30 PM
    noodles93
    Charleston, SC
    I was getting a pretty rough vibration in idle with the header. Really didn't want to swap out but it worked in curing the vibration. Definitely keeping the header for future projects, it is far too nice to part with.
  5. Dec 25, 2024 at 8:25 PM
    betterbuckleup
    Ian
    Concord, CA
    Interesting. Might be worth reaching out to LCE to get their 2 cents on that.
    Installed a couple of those and haven't had that result. Maybe some of your exhaust hangers are shot? The OEM header has an extra support at the mid pipe that the LCE doesn't utilize.
    tacomakid96 likes this.
  6. Dec 26, 2024 at 5:31 AM
    noodles93
    Charleston, SC
    I went through everything trying to fix it hoping to keep the header. New exhaust, new hangers, new engine/trans mounts, ruled the engine out with IAC/plugs/wires. I’m thinking the combination of the nature of the engine + missing that clamp at the bell housing is what ultimately did it.
  7. Dec 26, 2024 at 7:30 AM
    aust
    aust Well-Known Member
    where did you get these?
  8. Dec 26, 2024 at 7:33 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
  9. Dec 26, 2024 at 6:39 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    I really wish they would make a metal one for the tailgate, I replace that one more often. It is way easier though. My friends are terrible with my tailgate latch.
  10. Dec 27, 2024 at 5:04 AM
    TACO in SC
    TACO in SC TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
  11. Dec 27, 2024 at 5:44 AM
    Moonrman
    Hill Country, TX
    I have got them from Amazon. They have them at rockauto and eBay also. Since Dorman makes an aftermarket part you could probably get them from your local auto parts store if you wanted to, Don't forget the dealer I think toyota still makes them.
  12. Dec 27, 2024 at 11:17 AM
    goldirock
    goldirock Member
    jim
    2000 xtr cab 2.7 5spd
    front hitch
    This is what I believe is crack on my exhaust manifold (I have replaced 2X before.) Done with that so have just ordered LC Engineering Header. Looks difficult to replace so may go to local shop here in North Texas (Goodes Offroad) where they have helped me with a few previous issues. Should I decide to attempt myself, can anyone suggest best way to get to the lower bolts? Do you need to remove the passenger side wheel (on 2000 Tacoma Extra Cab 4X4 with 2.7, 5 speed?)
    Thank you, I am Jim (first post outside of introduction last year)
  13. Dec 27, 2024 at 12:13 PM
    betterbuckleup
    Ian
    Concord, CA
    You can remove it yourself pretty easily, although expect for some of the studs to come out with it. Just remove the heat shield first and then you can get to it with common hand tools
  14. Dec 27, 2024 at 12:42 PM
    noodles93
    Charleston, SC
    It’s a very straightforward process. Remove the heat shield it’s just some nuts and bolts. The worst part is pulling the intake off. The LCE header just sorta slides right in.
  15. Dec 27, 2024 at 3:08 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I gave mine away when I got the plate bumper too
  16. Dec 28, 2024 at 12:44 PM
    noodles93
    Charleston, SC
    Finally did the line-x. Had it sprayed over the rails since the plastic liner wore down paint on the top. Got the UV upcharge as the truck sits outside. Really happy with how it turned out. Going to purchase some of those billet aluminum tie downs to replace the old ones in the corner next. But man… $100 for 2 is steep.
  17. Dec 29, 2024 at 12:29 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Anyone know where to get the sticky tar like substance that holds the vapor barrier between the door and the panel?
  18. Dec 29, 2024 at 12:30 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    O'Reilly's, ask for some butyl window tape
  19. Dec 29, 2024 at 9:10 AM
    Diy2k
    Diy2k Well-Known Member
    MG
    02 Tacoma, 2.7
    Softopper, shocks
    You can also replace the plastic by purchasing a throw sheet at a local hardware store. Then cutting it and adjusting it to the door.
    Make sure you get the thick kind.
  20. Dec 29, 2024 at 1:42 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    Oil change, rear dif changed, all driveshaft points greased, inside of snug top painted as it was starting to get powdery when touched.
    Tomorrow is fixing the rear drivers side window and programming a new key fob as this truck had one but the original owner broke it.
    Toyota Dude likes this.
