  1. Mar 1, 2025 at 9:44 PM
    Phessor
    Phessor Well-Known Member
    Chucked mine in the trash when I went manual hubs
  2. Mar 2, 2025 at 6:06 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I’ve been meaning to get a setup like this for a while now for both my rigs.
  3. Mar 2, 2025 at 3:16 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Welp. Got most ways through the hard parts of the disassembly portion of a timing belt, found some very confusing indications. Timing belt looks extremely new - no record at all of it being done recently, and the bolts all fought coming off like they've been on (and rusting... oh boy) since the sticker on the timing belt cover says it's been done. And the auxilary belts are... well, alternator belt's newish, PS belt is very old.
    Plus the passenger side bolts at/below the camshaft all came out with a nice layer of engine oil over top - something tells me that's not at all supposed to happen. Suppose I'll figure out if it's the cam seal once I get further in.
    However, ran into a problem. When I was pulling the harmonic balancer (which I'm pretty sure is toast), one of the two M8 bolts I was using in combination with the OTC Stinger to pull it seems to have stripped some of the threads... And leaves me pretty stumped on how to proceed to get it pulled the rest of the way. I'm thinking I'll run a M8 tap down next chance I have to work on the truck to see if I can chase the threads clean and hopefully there's enough of them to get the thing off (I think it's toast, there's a noticeable crack running around the circumference of the rubber).
    That said, I'd appreciate any suggestions for getting the stupid thing off. Preferably without trying to cut it free, I'm nervous about damaging the crankshaft while trying that.
    Truck's really showing its Ohio here and with the fan pulleys, which I really hope I can just wire brush and repaint.
  4. Mar 2, 2025 at 5:02 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I like these much better. easier to mount with just some quick fists.
  5. Mar 2, 2025 at 5:24 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Ever actually used one? I’ve seen a few very critical reviews from people who tried them and thought they were ineffective. It’s a small sample but one was from a YouTuber I consider trustworthy.
    I have one myself but I still carry a common chemical extinguisher. It’s hard for me to argue with tried-and-true when the stakes are so high.
    Speedytech7 likes this.
  6. Mar 2, 2025 at 5:52 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    yup this. A concern I had after watching videos too.
  7. Mar 2, 2025 at 5:56 PM
    6P4
    Colorado Springs
    I want to like them, the sales pitch is great, but like I said, hard to argue with proven standards for safety equipment.
  8. Mar 2, 2025 at 6:27 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Seems like I've done this before :pout:
    I don't really want to do this again.
    But, I also got the sliders spotted up and tacked.
    unstpible likes this.
  9. Mar 2, 2025 at 6:31 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    IMG_5909.jpg I just used a cheep bracket, my seats have the pull bar for the dual sliders so clearance was a challenge.
    A while back there was a thread on fire extinguishers and the know it alls popped off saying the little fire extinguishers are worthless because they are used up in like 10 seconds.
    I wasn’t aware of rhe Element fire extinguishers at the time, I think both might be worth carrying since the Element ones are so easy to store
  10. Mar 3, 2025 at 8:42 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Question for those who have relocated your battery to the back. What gauge wire did you use to run to the back, and I'm assuming you used that same gauge wire to run back up for the winch.
  11. Mar 3, 2025 at 8:58 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Just hashed this a bit last week in the LT thread, mix of 4/0 and 2/0... consensus that 4/0 was better.
    I am laying out my own now also, and planning to do 4/0 battery to a "bus" terminal in roughly the OE + terminal location and run more normal gauge for the remaining discreet runs in the engine bay.
  12. Mar 3, 2025 at 9:02 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Seems like we're both having the same idea.
    Something like this in the area where the battery would normally go?
    unstpible and Bandido[QUOTED] like this.
  13. Mar 3, 2025 at 9:10 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I used 4ga for the engine bay items (starter, OE fuse block, alt) back to the blocks but ran single ought to the block and from the block to the winch.
  14. Mar 3, 2025 at 1:27 PM
    betterbuckleup
    Ian
    Concord, CA
    Hadn't seen any videos previously but I just watched a few and can see what you're saying.
  15. Mar 3, 2025 at 2:23 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Anyone ever attempted a solar panel bi or tri-fold bed cover? Seems like standard dimensions will limit me to 2x200W panels and maybe squeeze a skinny 100W panel in front but thinking that final panel's probably not worth the trouble. Wondering more about slider solutions that are fairly watertight.. I'm got some ideas but looking for more... possibly some that allow tilt on different axes
  16. Mar 3, 2025 at 2:33 PM
    Sudog
    Sudog Member
    01 regular cab 2.7 5 speed 4x4
    Touched up the wheels with some satin black
    BYJOSHCOOK, Jiveydude and tacomakid96 like this.
  17. Mar 3, 2025 at 2:34 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    When do those new tires go on the truck?
    Sudog[QUOTED] likes this.
  18. Mar 3, 2025 at 2:35 PM
    Sudog
    Sudog Member
    I wish they could. Maybe one day with a sas, those came off my 84 k30 chevy
  19. Mar 3, 2025 at 4:16 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Was going to wait until next weekend to replace the caliper but the leak was getting worse. Another reman caliper swapped out at NAPA. Let’s hope this one lasts more than 8 months.
  20. Mar 3, 2025 at 4:18 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Wait, #4 or 4/0? What the heck kind of loads are you guys running that you need wire that big?
    treyus30 likes this.
