  1. Mar 9, 2025 at 4:24 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Pitman puller is the way to go.
    Reh5108 likes this.
  2. Mar 9, 2025 at 5:16 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Dumb question, but is there an easy way to check if there's R134 in the AC loop? I don't have a AC gauge set handy, and wasn't really planning on getting one - no space for a proper recovery setup, etc.
    The compressor has been seized for 4 years on my truck, and I'd rather not pay someone to evacuate air from it.
  3. Mar 9, 2025 at 5:26 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can just put one of those cheapo gauges that come with the fill cans from the auto parts store on it. Or just push the Schrader valve for a half second and see if it sprays
    SpencerTacoSC[QUOTED] likes this.
  4. Mar 9, 2025 at 6:40 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Ditch lights finally installed...
  5. Mar 10, 2025 at 3:46 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Looks great! Which brackets are those? I have some on my ‘99 that attach to the hood mount.
  6. Mar 10, 2025 at 5:19 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Interesting bracket location. No issues sealing with it against the rubber? Share a link if you have it...
  7. Mar 10, 2025 at 7:03 PM
    LanceRN
    Lance
    Amazon!
    Amazon.com: ROMELACK Ditch Hood Mount Bolt Brackets Upper LED Light Bracket Compatible with Toyota Tacoma 1996-2004 Fit 4runner 1996-2002 (Black) : Automotive
    I didn't use their screws, I bought some flat head self tappers at Ace hardware. The backside where they screw in I put some silicone.
    Weatherstrip goes right back on. Door closed fine, and you can't see the lights from the driver's seat.
    kuntry09[QUOTED] likes this.
  8. Mar 11, 2025 at 12:06 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Lubed up the sticky door handle syndrome (pull handle from an unlocked position, door opens slightly and then lock tab shifts down, thereby locking door).
    Added Kilmat, Shit is sharp..
    Cleaned up and added butyl rope putty (O'Reilly's 8612) to vapor barrier.
    Not new but much better.
  9. Mar 11, 2025 at 5:33 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Removed the glovebox reached up and packed the farthest right hand dash pin and socket with pieces of rubber glove. I used a bent piece of wire to really pack it in the socket. Seems to have stopped the dash rattle. I hope!!
    loudboy and Phessor like this.
  10. Mar 11, 2025 at 7:58 AM
    noodles93
    Charleston, SC
    How did you put the sound deadener on the door? Against where the interior piece sits or on the inner shell?
  11. Mar 11, 2025 at 10:53 AM
    darth_bronchioles
    darth_bronchioles Well-Known Member
    California Central Coast
    1999 Supercharged Tacoma 4x4 Limited
    TRD Supercharger URD 7th injector kit K&N intake 4Runner Mirrors Dog Light Mod
    Installed a URD short shifter and 4Runner center console. No more whacking my knuckles on the radio or spilling my coffee every time I brake.
  12. Mar 11, 2025 at 11:03 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    best to do both.
  13. Mar 11, 2025 at 6:03 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Got some oem tundra rotors ready to go
  14. Mar 11, 2025 at 6:03 PM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
    Can get gauges and even a compressor and recovery tank net $0 rental at LAPS. Don't think there should be any fee to evacuate old refrigerant but would be owed a credit if there's anything in there.
  15. Mar 11, 2025 at 8:39 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Tried to help a friend flush the coolant on her 5VZ 4Runner today. We never got it to burp fully. The truck ran for 30+ minutes at idle, radiator cap off, maintaining operating temperature, but with no heat in the cabin. After that, we put the radiator cap on and started driving. The temperature immediately started to climb so we stopped driving but left it idling and the temperature returned back to normal within a few minutes. Still no heat in cabin.
    I know it's probably an air bubble but I'm unsure what else to do to evacuate it. Any suggestions? Are there quirks to be aware of when burping a 5VZ cooling system?
  16. Mar 11, 2025 at 8:45 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Were you using one of those nice funnels? Squeezing all of the hoses in/out of the radiator? If the thermostat was replaced, was it clocked at the correct position? (6 o'clock)
    Those were the main things I did when I was doing it.
    You need to get the engine up to temp so the thermostat opens up and allows everything to flow through the system; sometimes if the thermostat is at 12 o'clock, that can be tough(er). And sometimes you gotta rev a bit, just to warm things up.
    unstpible and Yetimetchkangmi like this.
  17. Mar 11, 2025 at 9:17 PM
    6P4
    Colorado Springs
    No funnel but we did keep adding water regularly. Just water, not coolant. We had a new thermostat installed but went back to the old one while trying to troubleshoot the lack of heat. It seemed like the new one wasn't opening, but maybe we were fighting bubbles then too. Thermostats were installed with the jiggle valve at 6.
    Hoses were squeezed and revs were revved, but maybe not aggressively enough?
    After reading a bit online, I'm wondering if a few hot/cold cycles of the engine will sort things out.
  18. Mar 11, 2025 at 9:41 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    My vapor barrier was bit flappy and generous with the dust freedom.
    I had enough room to fit sheets in, fingernail indent, take it out, cut to size, apply, then roller.
    I gently pulled back the butyl from the plastic and cleaned it all up with a wire brush and then reapplied new butyl putty.
  19. Mar 12, 2025 at 2:20 AM
    Toyota Dude
    Have you tried inclining the front?
  20. Mar 12, 2025 at 5:56 AM
    6P4
    Colorado Springs
    Yeah, the truck was parked on a hill with the front elevated while idling. The short drive was also up and down a very steep road.
