  1. May 1, 2025 at 5:23 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Guess I'm just anticipating issues I don't even need to worry about having haha
    betterbuckleup likes this.
  2. May 1, 2025 at 5:49 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I have hydros on all 4 corners. They’re loud as hell. Constantly clicking as you’re loading and unloading the suspension through fast stuff.
    Guess I need to turn the radio up.
    chrslefty likes this.
  3. May 1, 2025 at 5:56 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm sure all the extremely loud music in my youth may help in this situation.
    However... my wife is not deaf like I am... she doesn't hear them either.
  4. May 1, 2025 at 8:55 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm sure there are cheaper options. My quick search came to king and fox and I think they were $400 per can.
    yes, fox DSCs. No, about an inch to the bumper.
  5. May 2, 2025 at 10:15 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    yours being long travel, I would think the bumps are engaged a lot less frequently than a MT setup.
    Interesting. That makes me want to check mine and compare. Then again I would have to cut out a lot of the apron to clear the 35's past the point of my current max uptravel. I'm sure the CV's could handle fine. iirc at full bump they're at less of an angle than they are at full droop.
    @unstpible perry bumps showed up today. Excited to swap those out and see how they compare to the durobumps.
  6. May 2, 2025 at 10:25 AM
    unstpible
    Derek
    Cedar City, Utah
    @betterbuckleup
    Be brutal on then my friend, I'm interested to see what you think
  7. May 2, 2025 at 10:39 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Even with LT, the way the bumps get mounted to the frame, the LCA only moves up about 1/2~3/4 of an inch before it hits the bumpstop.
  8. May 3, 2025 at 8:20 AM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    I love seeing 3d printed stuff make its way into the auto world. I'm curious how those will hold up. Really cool.
    They have a lot to show for the details on their site, if anyone is interested:
    https://www.perryparts.com/aboutprocess
    unstpible and Logans2001[QUOTED] like this.
  9. May 3, 2025 at 3:48 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Welp. Chasing a bit of a phantom power steering leak. First fill dripped all over my carport, swore a lot, cleaned the carport, filled it back up to find the leak, and... no leaking. So that's fun. Refilled it Tuesday, still no leak.
    Did the transfer case & front diff oil, too. God almighty, I used to think nothing smelled worse than diesel oil. Every time I pop a differential open I relearn this lesson.
    Reciever/drier is on, and AC loop is buttoned back up. Whoever put the lug nuts on previously really pounded them on with the air wrench. Still, penetrating oil & a breaker bar got them free. Naturally, wheels were seized. Rubber mallet solved that problem... eventually.
    Did the pry bar check & the service manual check with a dial indicator. Both showed LBJs are good! Under one thousandth up and down on both sides. I'll keep checking them every time the wheels come off.
    Naturally, things immediately went sideways while I was putting the torque on the lug nuts (I always get them hand tight in the air then give it the old clicky-clicky on the ground.)
    Wonderful sinking feeling when all resistance suddenly vanishes.
    I'll be honest - I just don't want to deal with putting a new stud on. I'm going to have a mechanic deal with it since I have an appointment already to get the AC system charged.
  10. May 3, 2025 at 6:31 PM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
    Great work! Why not vacuum and charge the system yourself with free loaner tools and refrigerant / oil at the LAPS?
  11. May 3, 2025 at 7:31 PM
    beefsteak taco
    beefsteak taco Member
    Justin
    2005 silver Tacoma TRD
    ireymon, BYJOSHCOOK, JPinFL and 10 others like this.
  12. May 3, 2025 at 7:37 PM
    beefsteak taco
    Justin
    Not bad for an old truck with 320,000 miles if I don’t say so myself
    robm7 likes this.
  13. May 4, 2025 at 5:32 AM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Same reason I'm not replacing the stud myself. I don't want to. Plus if for some reason it won't hold vacuum, they're better at figuring out what's broken than I am.
    And even if I wanted to, all of my wrenching time right now is going into fixing the coolant leak on my brother's A4.
    roboturner likes this.
  14. May 4, 2025 at 3:44 PM
    Fx13
    Fx13 Well-Known Member
    2003 2.4l 4 cyl tacoma
    20250504_174712.jpg [​IMG]Soyupgrade Tonno cubre luces traseras y luces de placa
    Y las letras de TACOMA.
    :soldado:
    SpencerTacoSC likes this.
  15. May 4, 2025 at 5:54 PM
    unstpible
    Derek
    Cedar City, Utah
    Just wait until you smell CVT fluid, makes used gear oil smell like roses
  16. May 5, 2025 at 8:58 AM
    ben20004x4
    ben20004x4 Well-Known Member
    TAMU
    2000 SR5 130k miles
    Put the tacoma on the flex ramp the other day. No sway bar. Didn't push it too much, didn't even get to rub the driver rear tire so clearly had more room... lol.
  17. May 5, 2025 at 6:25 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Had the AC charged today. And immediately there are a bunch of short hisses from behind the glovebox, and the AC got steadily less powerful as I drove home.
    I gotta admit, hard not to feel defeated, even though the compressor seems good - it blew ice cold when I got in at the shop and for a good chunk of the drive home. They did put a UV dye, so I suppose I need to get a black light and start hunting a radioactive-pee glow. I'll also try to clean the evaporator drain. Maybe I'm lucky and that's the only problem left.
  18. May 5, 2025 at 7:04 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Replacing the evaporator is actually an easy job
  19. May 5, 2025 at 10:12 PM
    ophlee
    ophlee New Member
    Jo
    Torrance, CA
    White 2001 Tacoma PreRunner V6
    Changed valve cover gaskets, cam plugs, half moons etc. (What the hell is the point of the half moons??) Valve covers have been very slowly leaking oil for at least 2 years now and I finally got the courage/cash together to tackle this job. First time I've really done any work on an engine before so this was a great intro experience. Took yesterday to disassemble, then let some parts soak overnight before reinstalling everything today. I thought it would take forever to finish until all of the sudden I was done and I heard the beautiful sound of the engine cranking and coming to life again.
    I am like 70% sure I've screwed up the spark plug tube seals on installation. I scratched the hell out of the tabs on the cover and tore through a bit of the rubber seal it seems... Also I think I ended up dumping a nice bit out of coolant out of a couple hoses and into the passenger side camshaft housing. Tomorrow I'll change the oil.
    Apparently I decided grilling the valve covers was the best way to dry out any moisture after having soaked/cleaned them. Smelled pretty good and felt very wrong.
    Next on the laundry list is to replace my hoses that are almost all split and cracking.
  20. May 6, 2025 at 5:44 AM
    Reh5108
    Idaho
    The half moons are part of the marching process to line bore the cam towers.
    Laxtoy and ophlee[QUOTED] like this.
