  1. Jun 9, 2025 at 4:19 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Gonna have some semi truck kinda throw now
    Ro1024[QUOTED] likes this.
  2. Jun 9, 2025 at 4:52 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Yes, except those lol. Those guys are easy by comparison, I always have a bitch of a time getting the knuckle separated from the uniball
  3. Jun 9, 2025 at 6:00 PM
    Ro1024
    Ro1024 Member
    Vancouver Island
    2001 Tacoma 2.4L 5-speed (Paloma)
    AirLift
    Haha, yes!
  4. Jun 9, 2025 at 6:01 PM
    Ro1024
    Ro1024 Member
    Vancouver Island
    AirLift
    I like it that way. It is comfortable up there.
  5. Jun 9, 2025 at 7:27 PM
    CA-Taco
    CA-Taco Well-Known Member
    Santa Cruz Mountainss
    1999 PreRunner TRD
    1999 PreRunner TRD 5VZ 3.4 V6 AutoTrans 4x4 Swap ADS Coilovers w/adjusters New OEM Bushing UCA and LCA @210k Mi Stock LCA, SPC UCA REH5108 Coilbucket Gussets Total Chaos Spindle Gusset DuroBump Front Bump Stop Alcan Springs +800 lbs +2" ADS w/adjusters Rear Shocks U-Bolt Flip-Durobump DuroBump 4.25” Bump Stops Custom Shock Relocation 4.88 Yukon Gears Eaton Front Locker SCS Ray10 16x8 Bronze 255/85R16 Cooper Discoverer S/T Maxx Dakota Digital SGI-100BT Speedometer Interface Stock Front Bumper with Custom Hidden Winch Warn M8 w/Synthetic Rope w/Factor55 Flatlink E Nguyen Works Bumper w/Dual Swing Outs (Greasable KP Off-road LCA Bolts for Swing Out Bearings) BAMF Sliders 4x Innovations Front and Transmission Skid Plates Dometic CFX 55im Fridge/Freezer Big 4 wiring Mod Singer 128.5MM Denso hairpin style (6 phase) 180 A (200 A Max, 150 A Idle) X2Power AGM Group 35 Battery Renogy Deep Cycle AGM 12 Volt 100Ah Battery Renogy 20A DC to DC Battery Charger Victron Energy SmartShunt 500 amp Battery Monitor BlueSea Bus Bar on Custom Engine Bay Mount Victron Energy SmartSolar MPPT 20 amp Solar Charge Controller Renogy 100 Watt Eclipse Foldable Solar Panel Osram Super Bright 100/90w 2900 lumen H4s Headlight Services Harness 13WL Brake Calipers Braided Steel Brake Lines OBDLink MX+ OBD2 Bluetooth Scanner & OBD Fusion App Kenwood DMX958XR Soundproofed Cab - Dynamat and Second Skin Wet Okole Seat Covers Rebuilt Engine when Head Gasket Failed (215k Mi) Hayden 699 Transmission Cooler (Replaced B&M 70264 Cooler) Magnetic Inline Transmission/Power Steering Filter 4 x 4 Conversion w/Yota1 Rebuilt AT, ECGS Rebuilt Front Diff, '99 Taco TC, Manual Hubs GFC Camper V2 LSPV Delete Funky Home Made Mud Flaps and Hangars (1/4” Conveyor Belt Material; 12” x 18”)
    I'm impressed (or maybe disappointed?) with the maturity of this group. I fully expected this conversation to descend in an off-color direction.
  6. Jun 9, 2025 at 7:31 PM
    betterbuckleup
    Ian
    Concord, CA
    Just don't bring up bed tie downs or LBJs and you'll be fine
  7. Jun 9, 2025 at 8:13 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Moved the windshield washer fluid reservoir out of the way of my front tire (really dumb place to put that) and more in the engine compartment. PXL_20250607_212159588.jpg New location.jpg
  8. Jun 9, 2025 at 8:19 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You forgot blue dash lights.
  9. Jun 9, 2025 at 9:06 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Is your cruise control actuator ok? Lol
  10. Jun 9, 2025 at 9:48 PM
    K_Caustic
    K_Caustic New Member
    Kyle
    1998 Tacoma SR5 4x4
    Gotta know bumper is that??
  11. Jun 10, 2025 at 6:39 AM
    LanceRN
    Lance
    Yup.
    Just dusty from a trail run here in Tucson.
  12. Jun 10, 2025 at 8:46 AM
    Laxtoy
    Maltby, WA
    IMG_5080.jpgSolo lca’s installed
  13. Jun 10, 2025 at 10:45 AM
    betterbuckleup
    Ian
    Concord, CA
    I like your mounting of the resis. Do they clear the skid plate well? Any tire rubbing on the hoses?
  14. Jun 10, 2025 at 12:00 PM
    Laxtoy
    Maltby, WA
    The aluminum bar I used is very rigid, about 1/4” of play if you’re really giving it a go- skid, bottom of radiator, crossmember/mount, everything clears by about 3/8”.
    The tire rubbed on the hose a bit until I put that big zip tie on. Hoping with the Solo arms pushing the wheel forward an inch I can take some stress off the hose and re-zip tie it with a bit less tension.
  15. Jun 10, 2025 at 12:37 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Addicted offroad, easily my favorite tube bumper made for my truck.
    [​IMG]IMG_2129 by MJH Creations, on Flickr
    TacoSauce04, jubei and tacomakid96 like this.
  16. Jun 10, 2025 at 1:19 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I actually took it for some light wheeling this past weekend, was a good trip.
    [​IMG]IMG_3377 by MJH Creations, on Flickr
    [​IMG]Untitled by MJH Creations, on Flickr
    Def happy with the STT Pro's at 10 psi.
    Hard to tell if solar is performing like I hoped yet, the AGM in there is like 6 years old now and the fridge is having voltage issues of it's own.
    jubei, BYJOSHCOOK, roboturner and 3 others like this.
  17. Jun 10, 2025 at 4:29 PM
    JR_Roams
    JR_Roams Well-Known Member
    2002 Tacoma TRD-OR EXC 5MT
    @LanceRN was this a kit? can you link if so. Scarab kits are out of stock and looking for possibly another option.
  18. Jun 10, 2025 at 4:34 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    So did you like glue that thing to your hood or what?
  19. Jun 10, 2025 at 5:34 PM
    Laxtoy
    Maltby, WA
    I’ve had a lot of hot or miss with fridges, the ARB I bought used was a piece of shit, the Edgestar I got 10 years ago was still running strong when I got the ARB but now is too old (and moldy) to trust- I got an Iceco that has all the tech because it was the exact footprint as the ARB and didn’t want to rebuild the fridge slide.
    A 100 watt panel made a huge amount of difference, now I’ve got a 200 watt panel, about to do a 9 day trip, we’ll see how it performs.
    I’m about ready to recommend the Iceco if it has a successful trip, the price is great compared to ARB, Dometic
  20. Jun 10, 2025 at 7:20 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It uses 3M tape to attach to the hood. It was a kit Cascadia 4x4 sold for our trucks but I guess wasn't popular enough for ours to go in the V2 version. I'm hoping it can hold me over till I get a dual battery setup and considering I have been doing okay without one this long I do have high hopes it will.
    This Dometic has been running strong since 2018. It seems to only have issues when the truck isn't running and is happening in both the Tacoma and Bronco intermittently lately. It doesn't happen on 120v only 12v. I thought it was the 12v cord but replaced that on this trip mid trip and it did work again but then had issues again. I came across a post about the 12v connections inside the fridge coming loose overtime so that is my next place to dig.
