  1. Jan 28, 2013 at 9:04 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Wheelers sells two leaf packs for our trucks. Stock and +1.5". Check the part number on the leafs and confirm with your invoice and whats on the website.
  2. Jan 28, 2013 at 9:05 PM
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    yall know if 2nd gen factory coil springs will fit our shocks? mine are kinda saggy and i want not so saggy ones.
  3. Jan 28, 2013 at 9:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Get the AAL Wheelers makes for the leaf pack. Popped mine right up.
    They are 5 packs..therefore 1.5'' lift. 4 packs are stock.
  4. Jan 28, 2013 at 9:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    as in stock shocks? No.
    5100s? yes, OME883s coils will and are now recommended over 882s.
    Stock 2nd gen coils..no. Don't bother. Just get all new coils.
  5. Jan 28, 2013 at 9:11 PM
    DSully72
    Daniel
    Appling, GA
    gotcha... just lookin for a cheaper route =P. realr leafs springs saggin too but WAYYYY out of my budget
  6. Jan 28, 2013 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    just hold out and get some nice stuff that'll last a while.
  7. Jan 28, 2013 at 9:15 PM
    scocar
    scocar hypotenoper
    Hm. After settling and with a Snugtop and heavy rubber bed mat (prob ~150-200 lb), mine were at 1.25 inches.
  8. Jan 28, 2013 at 9:22 PM
    96Tacoma4WD
    96Tacoma4WD Well-Known Member
    So Cal
    1996 Toyota Tacoma V6 2dr Extended Cab 4WD SB
    Alpine head unit and CD changer
  9. Jan 28, 2013 at 9:31 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Thanks!
  10. Jan 28, 2013 at 9:33 PM
    DSully72
    Daniel
    Appling, GA
    and as long as they are factory replacement, they should work with any shocks that use factory replacement coils right? i have the skyjacker 3" kit.
  11. Jan 28, 2013 at 10:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Something about imitation being the highest form of...
    :p
  12. Jan 28, 2013 at 10:41 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    camper shell is a good 200lbs....that can for sure cause a decent amount of sag.
    Like monte said, add a wheelers 1.5 AAL, that what I am going to do to get a bit more lift/load resistance.
  13. Jan 29, 2013 at 9:36 AM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
  14. Jan 29, 2013 at 10:34 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I'm either goin with the wheeler 5 pack or the ome dakars. I think I'm leanin towards the dakars. Anyone have any thoughts of which is better?
  15. Jan 29, 2013 at 10:41 AM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    I got dakars ? I like them ........
  16. Jan 29, 2013 at 12:08 PM
    TacoMX
    Jonathan
    Deltona, Florida
    depends on what you are going to do. If you are going to be hauling a lot, or having a lot of gear in your bed...then the dakars are for you.
    I have the wheelers 5 pack, and it rides great...but I rarely haul anything in my bed other than a dirtbike once in a while.
  17. Jan 29, 2013 at 12:13 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Well during the summer i do pull a boat every weekend. But it doesn't make my stock crappy leafs sag hardly at all. I've just seen some people say they haven't gotten the amount of lift they wanted out of the wheelers
  18. Jan 29, 2013 at 12:15 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I am not sure exactly how much lift I got from my 5 pack, because I have shackles too...but I will be adding a 1.5'' AAL to get more lift, and I am getting rid of the shackles.
  19. Jan 29, 2013 at 12:18 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    I gotcha. Well I'm leanin more towards the dakars
  20. Jan 29, 2013 at 12:54 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    replaced my old air filter..that thing was nasty...truck feels better
