  1. Mar 9, 2013 at 7:50 PM
    RGosen
    RGosen Well-Known Member
    Christ would now agree, don't get yourself nailed to a tree
    Kamloops B,C CANADA
    2000 toyota tacoma 4x4 2.7
    Cold air intake
    New tires and rims, struts and shocks, and clutch...:eek:
  2. Mar 9, 2013 at 7:51 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    x2
    I did mine just a few days ago, and the stuff that came out was nearly black.
  3. Mar 9, 2013 at 8:01 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yeah... :( Haha when I did my 02 Chevy with it 130,000 miles it looked like that. Looks like another weekend to-do! :rolleyes:
  4. Mar 9, 2013 at 8:21 PM
    vette6991
    vette6991 Well-Known Member
    Flexin' today
  5. Mar 9, 2013 at 8:21 PM
    scocar
    scocar hypotenoper
    Yeah, I need to do this too. I have no idea if the PO ever did, although I do have a few dealer service receipts, including the T-belt and H20 pump. He took care of it, but who knows... closing in on 130k now.
  6. Mar 9, 2013 at 8:26 PM
    PcBuilder14
    Brent
    Nor Cal
    Haha you and I pretty much did the same thing today after installing our lift!
  7. Mar 9, 2013 at 8:29 PM
    vette6991
    :eek: that's stock sadly :(
  8. Mar 9, 2013 at 8:30 PM
    PcBuilder14
    Brent
    Nor Cal
    Fooled me! Good flex for stock! ;)
  9. Mar 9, 2013 at 8:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    My buddies tacoma would not start the other day. He was so relieved when it turned out to only be a clogged fuel filter. He had changed it once in the past and the replacement only had 90K or so on it. This prompted me to do mine. The junk that came out of his was much worse than mine tho.
    Got me to thinking about the fuel pump inside the tank. Maybe an old, partially clogged filter makes the pump work harder and potentially shortens its life.
    It ends up being a fairly easy and inexpensive job. Worth the $26 and 20 minutes.
  10. Mar 9, 2013 at 8:34 PM
    scocar
    scocar hypotenoper
    Yeah, it is very acessible on the 5ZV-FE. On my old 93 22re, it was tucked under the intake mani back near the starter. Nightmare.
  11. Mar 9, 2013 at 8:39 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Doing mine tomorrow
  12. Mar 9, 2013 at 9:15 PM
    Murph
    Murph Go Pack Go!
    Tyler
    Fox Valley, WI
    2000 Extra Cab TRD O/R
    3" lift. American racing 15'' rims. 33x12.50 BFG A/T tires. tool box. ARB bumper, mile marker winch, kc highlights. No carpet inside sprayed with bed liner. Kicker door speakers. Alpine head unit.
    Changed my transfer case fluid, and replaced my broken drives side door handle & down stream 02 sensor. And turned 190K :p. Also changed oil / filter on my buddy's 98 taco.
  13. Mar 9, 2013 at 9:22 PM
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    Painted the outer ring black and installed back into the truck. Haven't taken it out for a drive yet.
    Painted the radiator and behind the grille and also installed the new headlights at Philips X-treme Power bulbs. Damn they're bright! :eek: but not necessarily white. I still need to aim them but idk what tool to use that fits behind there to get to the 2 bolts per side :notsure: My socket wrench with the step down adapters don't fit back there.
    These are the low beams, but are aimed up way too high. Need to adjust.
  14. Mar 9, 2013 at 11:55 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    mike you are just reminding everyone to do this. I should add it to my list of to dos to prep for moab
  15. Mar 10, 2013 at 3:08 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Went exploring again
    B417B19A-78D8-42E6-B230-70673732EED7-247_2aff1b67beec8b162acf46325f8202cb89523286.jpg
    A1357C7A-EFFF-4FFB-BA5F-96B0B5252475-247_c3430114dc31a4eaf9028d374ffab43f98ca1999.jpg
  16. Mar 10, 2013 at 3:09 AM
    ffirg
    mike
    Anchorage, Alaska
  17. Mar 10, 2013 at 8:18 AM
    Madjik_Man
    Colorado Front Range
    I have no idea if my fuel filter has ever been changed.. probably hasn't
    163,000 miles
  18. Mar 10, 2013 at 8:38 AM
    GunnyCO
    GunnyCO Well-Known Member
    Colorado Rockies
    98 Tacoma TRD SR5
    ^do it! Quick simple and cheap and I swear my truck ran better. Brown fuel ran out of mine too.
  19. Mar 10, 2013 at 11:56 AM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    Took it for a ride and a swim
  20. Mar 10, 2013 at 2:56 PM
    smuook
    smuook Daily Driver "Plus"
    Smuook
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    That's quite a view. Not something you see here in Florida... but it was 72F here today. :p
