  1. Jul 13, 2011 at 8:06 AM
    #2841
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    nah man, you'll notice an improvement in steering when you hit the dirt. the poly urethane is much better than the crappy stock rubber
    i know they take a long time to install... at least it's a cheap part and you dont have to pay yourself for your time on the clock
  2. Jul 13, 2011 at 10:11 AM
    #2842
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    does anyone know the size of the rear diff drain and fill plug? i was fighting with it last night and lost.
    finally this morning i gotta 15/16" on it and got it off but its all rounded and messed up so im thinking about replacing it. im thinkin maybe my diff breather is plugged up cuz it was so ridiculously tight maybe there was a bit of a vacuum? does that make sense?
  3. Jul 13, 2011 at 10:42 AM
    #2843
    Tony Tacoma
    Tony Tacoma Member
    Frank
    Orlando
    01 Prerunner
    Line-X Bed Liner Diamond Plate Tool Box
    It was $580 after tax, over the rails. $469 pre tax under the rails...
    Thanks for the welcome TacomaZach
  4. Jul 13, 2011 at 10:43 AM
    #2844
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    They should both be 24mm. 15/16" is a little smaller than 24mm so that's probably why it worked... I would replace it if I were you.
    Yeah, the vacuum idea makes sense but I dont think it would be strong enough to make a noticable difference when trying to loosen the plug because it's such a small area. Have you tried ttwisting the breather to make sure it's loose? If you can twist it around with your fingers, than it shouldn't be clogged.
  5. Jul 13, 2011 at 4:02 PM
    #2845
    scocar
    scocar Scouting the perimeter for weakness
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Back to square one after the 2001. So...
    They can often be an unholy bitch to get off, especially if they have not been maintained, or someone used the wrong crush washer (or no washer) or overtorqued it. The 30k mile regular service interval and the location also allows a lot of corrosion and filth to seal it up between changes. The first time I ever did it on my 93, I swore A LOT.
    In the future, try hitting it with a small wire brush to take of any surface corrosion and then some PB blaster. You can also tap it with a hammer to help break corrosion. You'll likely need at least a breaker bar, if not a cheater bar, too. A six-point socket is also a good idea to avoid slipping and rounding.
  6. Jul 13, 2011 at 4:32 PM
    #2846
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    You're right man, it's great. My shudder is gone, my steering is tight, and it feels like a brand new truck. Thanks again for all the help!
  7. Jul 13, 2011 at 8:26 PM
    #2847
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    Gettin a magnaflow glasspack put on tomorrow morning... I hope
  8. Jul 13, 2011 at 8:26 PM
    #2848
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    Gettin a magnaflow glasspack put on tomorrow morning... I hope It sounds pretty good !
  9. Jul 13, 2011 at 8:43 PM
    #2849
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    just replaced my driver side cv axle. had a long time with that...not even gonna go to details. :mad::mad::frusty:
  10. Jul 14, 2011 at 1:29 PM
    #2850
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Plasti-dipped my chrome door handles, this stuff is freaking addiciting! Haha
  11. Jul 14, 2011 at 1:33 PM
    #2851
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    ive been wanting to do this for a while im just too lazy...did you tape anything off?
  12. Jul 14, 2011 at 1:34 PM
    #2852
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's not that bad after the first one next time it should be simple :D
  13. Jul 14, 2011 at 1:36 PM
    #2853
    PcBuilder14
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Taped all around just the handle, not the piece that houses the handle. And then used paper to cover the surrounding area from overspray, you don't have to worry about overdoing it, if it does get on the paint it will rub off when you wash your truck. I'll post pics in a second...
  14. Jul 14, 2011 at 2:13 PM
    #2854
    PcBuilder14
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Passenger side
    Driver side
    Passenger side came out smooth while the driver side came out rough (like bedliner) Be sure to shake it up a lot when using because apparently I didn't shake it enough! Still turned out nice though, amazing how much of a drifference it made!
  15. Jul 14, 2011 at 2:16 PM
    #2855
    JLee
    Jerry
    Bay Area NorCal
    :facepalm:Man you guys have commitment issues just paint them at least it wont rub off opening the doors.
  16. Jul 14, 2011 at 2:24 PM
    #2856
    scocar
    Dick
    2015 DCLB 4x4 SR5
    :rofl::rofl::rofl:
  17. Jul 14, 2011 at 2:24 PM
    #2857
    PcBuilder14
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    This also isn't my truck, it's owned by my parents. My dad is all against painting any stock parts, and this was my best alternative. He'd rather me keep it stock except for a small lift and slightly larger tires.
    Plus This is a good idea for me to see whether I thought my truck would look good with different areas black, this way if I don't like it I can remove it. So for me this is a good way of doing this...
  18. Jul 14, 2011 at 2:26 PM
    #2858
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Holy crap, this may actually be a legit use of plasti-dip! :eek:
    Alert the media!
  19. Jul 14, 2011 at 2:26 PM
    #2859
    JLee
    Jerry
    Bay Area NorCal
    Okay that's understandable i didn't know it was your dads truck :)
  20. Jul 14, 2011 at 2:31 PM
    #2860
    PcBuilder14
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Mhm, it was bought for me to drive, but it's one of things where I'll have to buy it if I want it as my own. Which I have no problem with. For example he want's me to get 265/70/16's on stock rims, but I want 33x12.50x15's on pacer rims.
Products Discussed in this Thread
