Discussion in '1st Gen. Tacomas' started by SlimDigg, Feb 7, 2011.
  1. scocar
    scocar Not one of the 10,000 Baja Edition Elite Guard
    Glitterdick
    In close proximity to an undisclosed location
    01 Xcab TRD 4x4 V6 Man. SR5
    OME 881s, Dakars, greasable shackles, Nitrocharger sports, extended exhaust hanger, BAMF BPV relocate, Wheeler's extended brake line, rear diff breather mod, swaybar removed, Pilot backup lights, Redline hood struts, 4Runner 5-stars, Hidden Hitch Class III, 7-pin marine-grade wiring
    They can often be an unholy bitch to get off, especially if they have not been maintained, or someone used the wrong crush washer (or no washer) or overtorqued it. The 30k mile regular service interval and the location also allows a lot of corrosion and filth to seal it up between changes. The first time I ever did it on my 93, I swore A LOT.
    In the future, try hitting it with a small wire brush to take of any surface corrosion and then some PB blaster. You can also tap it with a hammer to help break corrosion. You'll likely need at least a breaker bar, if not a cheater bar, too. A six-point socket is also a good idea to avoid slipping and rounding.
  2. YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    You're right man, it's great. My shudder is gone, my steering is tight, and it feels like a brand new truck. Thanks again for all the help!
  3. tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    Gettin a magnaflow glasspack put on tomorrow morning... I hope
  4. tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    Gettin a magnaflow glasspack put on tomorrow morning... I hope It sounds pretty good !
  5. ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    just replaced my driver side cv axle. had a long time with that...not even gonna go to details. :mad::mad::frusty:
  6. PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Missouri
    2003 Tacoma TRD/SR5 4x4
    Suspension: Front - Bilstein 5100's/Eibach coils Rear - All Pro Expo Leafs/Rear Icon Remote Reservoir Shocks Wheels & Tires: 33x12.50x15 KM2's/Summit Racing 85 Black 8 Series Wheels/15x8/3.75" Backspacing [U]Armor:[/U] - [URL="http://www.tacomaworld.com/forum/relentless-fabrication/152694-just-released-re
    Plasti-dipped my chrome door handles, this stuff is freaking addiciting! Haha
  7. malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    ive been wanting to do this for a while im just too lazy...did you tape anything off?
  8. JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's not that bad after the first one next time it should be simple :D
  9. PcBuilder14
    Brent
    Missouri
    Taped all around just the handle, not the piece that houses the handle. And then used paper to cover the surrounding area from overspray, you don't have to worry about overdoing it, if it does get on the paint it will rub off when you wash your truck. I'll post pics in a second...
  10. PcBuilder14
    Brent
    Missouri
    Passenger side
    Driver side
    Passenger side came out smooth while the driver side came out rough (like bedliner) Be sure to shake it up a lot when using because apparently I didn't shake it enough! Still turned out nice though, amazing how much of a drifference it made!
  11. JLee
    Jerry
    Bay Area NorCal
    :facepalm:Man you guys have commitment issues just paint them at least it wont rub off opening the doors.
  12. scocar
    Glitterdick
    :rofl::rofl::rofl:
  13. PcBuilder14
    Brent
    Missouri
    This also isn't my truck, it's owned by my parents. My dad is all against painting any stock parts, and this was my best alternative. He'd rather me keep it stock except for a small lift and slightly larger tires.
    Plus This is a good idea for me to see whether I thought my truck would look good with different areas black, this way if I don't like it I can remove it. So for me this is a good way of doing this...
  14. scocar
    Glitterdick
    Holy crap, this may actually be a legit use of plasti-dip! :eek:
    Alert the media!
  15. JLee
    Jerry
    Bay Area NorCal
    Okay that's understandable i didn't know it was your dads truck :)
  16. PcBuilder14
    Brent
    Missouri
    Mhm, it was bought for me to drive, but it's one of things where I'll have to buy it if I want it as my own. Which I have no problem with. For example he want's me to get 265/70/16's on stock rims, but I want 33x12.50x15's on pacer rims.
  17. PcBuilder14
    Brent
    Missouri
    Haha! :D I will probably redo it with bedliner material someday anyways and take my chances with my dad, because I like the matte black color of it.
  18. MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    :woot: Eibach, 5100, and diff drop arrived!
  19. malander
    max
    Missouri
    01 limited trd 4x4
    same situation here...not mine until i buy it but until then i can dump as much money as i want into it as long as there is an equal amount going towards college
  20. CocoaBeachTacoma
    CocoaBeachTacoma New Member
    Greg
    Cocoa Beach, FL
    04 Toyota Tacoma SR5 Ext. Cab 3.4L V6 4WD
    H.I.D. 6000K lights, exact fit seat covers, URD Short throw shifter, OEM 3 Inch lift
    Installed a 3" OEM suspension lift with the 883 coils and rear aal
    Before...
    and after....
