  1. Apr 12, 2013 at 1:46 PM
    Alpha Q Up
    Alpha Q Up Well-Known Member
    Ruben
    San Jose
    2003 4WD DC Tacoma
    I right there with ya!
    A646F11B-2CDA-47E2-B9C8-D4064D0A9843-139_71b9d0a844a04f24af44cbba25f03864cc51d207.jpg
    Are you doing the relocation mod?
  2. Apr 12, 2013 at 4:10 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Pulled my trans for the clutch install & also removed the factory windshield washer reservoir and put in a 92 pickup reservoir under the hood and made it to use my factory pump and low level sensor.
  3. Apr 12, 2013 at 4:17 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    That wicked. Did you make it yourself? And are you willing to make another....
    Edmundston isn't that far... Elite and the likes are too far to go get one.
  4. Apr 12, 2013 at 4:19 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Well I got my skid plates done... Formed backward though. At least I know it fits I guess.
  5. Apr 12, 2013 at 4:33 PM
    sbsurfer
    sbsurfer Well-Known Member
    2000 Reg Cab 4x4 4cyl 5spd
    Well when you're behind people it will atleast read correctly in their rear view mirror :D
    Looks good!
  6. Apr 12, 2013 at 4:37 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I'm not keeping this like it is. Either I'll sell it cheap if someone wants it and DGAF, or I'll cut and weld the letters the right way.
  7. Apr 12, 2013 at 4:41 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    Looks good though. At least it fits:D
  8. Apr 12, 2013 at 4:45 PM
    42boxer
    42boxer Well-Known Member
    Brannon
    Mcguire AFB, New Jersey
    2000 Toyota Tacoma TRD
    Plenty to come
    So i dont want to make a new tread but my trucks running weird for the first 10 mins of driving, Its sluggish and bogging down when accelerating. I just installed an aFe intake and everything was put on correct. No CEL. I have new spark plugs(only on prong tho, which apperently you need two prong) new spark wires, new MAF, oils good and everything. The truck will eventually run normal but takes quite a while. Could it be my CAT or what?
    Thanks
    2000 3.4 automatic 4x4
  9. Apr 12, 2013 at 4:55 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    When I bought mine it never had a skid so I'm down for cheap. :D
  10. Apr 12, 2013 at 5:10 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I actually did redo that connection this morning when I was still tinkering with it because it came out when I plugged the connector back in. I took it out and did turns in dirt etc and the locker never engaged. I then tried in 4lo just to see if it would. It never did. And to be honest I'm not sure if I ever had it engaged before and I know the previous owner never wheeled. I found that I am going to look into next.
  11. Apr 12, 2013 at 5:10 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
  12. Apr 12, 2013 at 5:34 PM
    makou99
    makou99 Well-Known Member
    Marc-Andre
    Edmundston
    96 Tacoma
    yes i made it myself and im in moncton now so its even closer!
  13. Apr 12, 2013 at 5:54 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    washed her up all nice like
  14. Apr 12, 2013 at 5:54 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Gonna look awesome when I get the new one made.
  15. Apr 12, 2013 at 6:04 PM
    figaroni
    figaroni Well-Known Member
    10 4Runner TE
    K&N Cai, Borla Catback,Toytec coilovers, 5100s, 33" GY ATs, more to come
    No it's just a lightweight pulley. The oem pulley was like 10 or 11lbs and this one is 2lbs. It doesn't do much as for power but its does rev a little faster and get it up in the power and quicker. Kind ofa waste but I had to try it. Noone makes an undetdrive pulley for the 3.4 or I woulda been all over it
  16. Apr 12, 2013 at 6:41 PM
    42boxer
    Brannon
    Plenty to come
    Bump?
  17. Apr 12, 2013 at 6:44 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    pics of my diff drop i copied from my build in case anyone cared.
    tear i was worried about before diff drop
    tear after diff drop
  18. Apr 12, 2013 at 6:44 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
  19. Apr 12, 2013 at 6:44 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Did it start after the new spark plugs? There are some trucks that hate those single electrodes.
  20. Apr 12, 2013 at 6:50 PM
    42boxer
    Brannon
    Plenty to come
    No not really. I had a CEL before and after spark plugs, turned out to be my MAF for the CEL. It started after my intake
