  1. May 20, 2013 at 10:05 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nice! exactly what im im doing with my other set of doors.
  2. May 20, 2013 at 10:36 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Riding around with this guy
  3. May 20, 2013 at 10:42 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Got the lifetime alignment done at my local Firestone. Buddy is a tech there and had no problem doing it even with Light Racing upper control arms.
  4. May 20, 2013 at 2:00 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    New brake pads?
  5. May 20, 2013 at 2:17 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I thought they were included as well. Dan emailed me saying they are installed on the springs, but I don't see them. I see what looks like a bushing, but it's only about an 1/8" thick. Maybe that's it and I'm dumb, but I don't see how it would be snug on the shackle bolt that way.
  6. May 20, 2013 at 2:34 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    ? Nope, this is about grinding the caliper to clear most 15" rims on a 2003 Tacoma.
  7. May 20, 2013 at 2:38 PM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    Yeah, not too impressed by their sidewall durability that's for sure. Had a set of Duratracs prior that i had run on these trails 5-6 times without issue at lower PSI.
    Dropped the tire off at the local Discount Tire, i'm out $33 for a new warranty on the replacement, and 3-4 days of driving on the spare while i wait for the new one to arrive and be siped.
  8. May 20, 2013 at 2:45 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I have just about the exact same setup with 15x8 wheels but with 33x12.50 KM2's. I put 1/4" wheels spacers up front but I'd much prefer to just slightly grind the caliper. Could you take a pic of your calipers by any chance?
  9. May 20, 2013 at 2:49 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    If you grind the rimsthemselfs you won't have to worry about replacing a frozen caliper. Won't effect balancing and if you paint them right they won't rust.
  10. May 20, 2013 at 3:09 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Depending on the kind of shackle, they will come with a metal sleeve that goes over the bolt. Are your shackles greasable?
  11. May 20, 2013 at 3:11 PM
    PcBuilder14
    Brent
    Nor Cal
    I feel like I'd prefer to do the caliper as it would be a lot easier. If I did the wheel I'd have to grind a whole lot more, plus I'd have to do all 4 wheels just so I can rotate the tires versus grinding a little bit on 2 calipers.
  12. May 20, 2013 at 3:18 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Yea takes more time now. 15 mins a wheel. But get a frozen caliper and try to change it on a trail. I feel its worth the extra time to be able to just slap stock parts on and never worry about it.
  13. May 20, 2013 at 3:50 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    yeah you can take a grinder to your wheels all you want. I would rather take my chances with a caliper failing rather than my rim failing doing 70 down the highway
  14. May 20, 2013 at 3:58 PM
    BradyT88
    BradyT88 Well-Known Member
    I know of several people killing Duratrac sidewalls though. I'm still impressed with mine and have seen them take beatings. I just had some bad luck and took damage in the same spot twice. I'm going for the kevlar sidewalls next though just to see how they hold up. A lot of people like the MTR's better than the KM2's.
  15. May 20, 2013 at 4:03 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Rims are solid steel your grinding the dimple on the back. The reason the pro comps don't rub is they cut out the hole. Cragar uses a dimple die. There is no way in hell it would structurally effect the wheel. However bringing your caliper to thin could cause it to fail. I'd rather put in time than lose pressure in my brakes. Where you grind is very thin and many people have gone through and hit oil. I don't like fucking with safety systems.
  16. May 20, 2013 at 4:04 PM
    BradyT88
    I wanted to grind my calipers down to fit 15's but have never been brave enough to even attempt it... I am also a 2nd gen so I have more grinding to do than you guys...
  17. May 20, 2013 at 4:07 PM
    ffirg
    mike
    Anchorage, Alaska
    Yep they're greasable with zerk fittings. I'll double check when I get off work.
  18. May 20, 2013 at 4:13 PM
    4banger4x4
    Eric
    Whorelando, Fl
    you see brakes as a safty system, I see wheel structure as an important feature. but ill just keep my mickey thompsons and never worry about this
  19. May 20, 2013 at 4:24 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Nothing beats the correct rim for sure. But im just saying that trimming a tenth of an inch off of the back of dimple on a wheel that adds to zero structural integrity is better than brakes.
  20. May 20, 2013 at 4:25 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Someone should just make low profile brakes for these trucks:p
