  1. May 30, 2013 at 5:55 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    So I was checking the psi in my tires and doing a visual inspection before I drive 500 miles tomorrow night, and I noticed that there is some grease or something on the transmission above the seal between the transmission and the pan. Not sure what it could be or why it would be going up the side of the trans if it was leaking or something?
  2. May 30, 2013 at 5:58 PM
    04TacomaLimited
    04TacomaLimited Active Member
    San Diego
    Bone Stock Tacoma Limited
    Just got done installing my wade wind deflectors. That's about all for now. More to come!
  3. May 30, 2013 at 6:00 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    No pics, but I installed a push-button start today, just for kicks.
    This would have come in handy in my rock-crawling days (carburetor), when I would stall while climbing rocks. Using the starter can get you over the rocks until on level ground.
  4. May 30, 2013 at 6:10 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Got a ticket and a tank of gas. Very expensive day I have to say
  5. May 30, 2013 at 6:12 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Put on some Magnaflow 50 state converters! Makes me want to get headers and finish off a stainless exhaust. Don't know if they will keep the cel off yet! (fingers crossed)
    Also wired up a blitzpro reverse light, relay and all, helps a ton at night
  6. May 30, 2013 at 8:05 PM
    PcBuilder14
    Brent
    Nor Cal
    How do they sound?
  7. May 30, 2013 at 8:16 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Picked up a 50lb c02 tank today
  8. May 30, 2013 at 8:18 PM
    PcBuilder14
    Brent
    Nor Cal
    Haha I understand. I'm debating going with speakers like those for the back. I plan to amplify all four speakers plus the door tweeters. All kicker...
    Looking at these for the rear right now.
    http://www.sonicelectronix.com/item_36641_Kicker-DS68-with-NVX-Sound-Dampener.html
    And these for the front.
    http://www.sonicelectronix.com/item_64190_Kicker-CSS684.html
    Amp.
    http://www.sonicelectronix.com/item_22573_Kenwood-KAC-8405.html
    :eek: That's insane!
  9. May 30, 2013 at 8:19 PM
    MyTacosBetter
    MyTacosBetter Well-Known Member
    Angie
    Oregon
    TRD SR5
    Seat warmer & Line-X
    Yeah, that's probably what the intended use was meant for huh? :)
    Push button starts are wonderful. I use mine when I'm in my snowboard boots and want to fire it up as soon as I open the door!
  10. May 30, 2013 at 8:39 PM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    Put a deposit on an full OME lift I found :D:D:D
  11. May 30, 2013 at 9:18 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    My truck always drives better after a bath! :D
  12. May 30, 2013 at 9:25 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Got it back from the shop. Went in for an alignment after the lift and had them install my new steering rack bushings and new outer/inner tie rods ends on my driver side. Steering is super tight now. Then I went for a drive to test out the new suspension. It's definitely more stiff, but hopefully it breaks in a bit.
    3C7BE1F7-B90F-4EA1-94DD-343D7BD0C3EC-288_a8ee0b43127018ed7b159032a40606b6e74f4ca7.jpg
  13. May 30, 2013 at 9:25 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    bump this to get you some help ;)
    Damn lol. I just picked up a 20lb co2 tank. Pics? lol CameraZOOM-20130528173619276_zps884a44eb_55ca693e70c67a4c0e2836be2ca1a76fad493bfb.jpg
    I have a kenwood amp for my subs and I really like it. Pioneer 6x8s in the doors and the back panels. I usually check reviews and specs on crutchfield and reviews on Amazon before I buy stuff like that.
  14. May 30, 2013 at 9:59 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    truck Looks Great!
  15. May 30, 2013 at 10:23 PM
    ffirg
    mike
    Anchorage, Alaska
    Thanks! I'm starting to really think about 33s now haha.
  16. May 30, 2013 at 10:26 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Finally finished and installed my jerry can holder in the bed. I'd take a picture, but it's raining. :(
  17. May 30, 2013 at 10:31 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    It Would Look Much Better:D
  18. May 30, 2013 at 10:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you have to use speaker adapters to fit those in the stock locations?
  19. May 30, 2013 at 11:24 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Ya its huge! Not sure im going to keep it. I got it for free so i might try and trade it for a smaller one.
  20. May 31, 2013 at 2:01 AM
    Widespread Panic
    Widespread Panic Active Member
    Darin
    Fla
    04 V6 4X4 Xtra cab TRD
    Bronze clutch pedal bushing,
    881 springs. Located in Cocoa.
    Wheels and tires are short term, they came off my 99 when Toyota bought it back for frame rust. I put the outlaws and BFG's on because they ride better than the crap tires it came with. Waiting on procomp 7069 and terra grappler 285's.
