  1. Aug 19, 2011 at 6:27 AM
    #3681
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    All this getting installed tomorrow! Woohoo!! :yay::yay::yay:
    -Front and rear Bilstein 5100's
    -Rancho HD Coils-Not as good as Eibach or OME, but hopefully better than OEM...we'll see
    -1.5" Wheelers AAL & extended length U-Bolt Kit
    -(1) 1/4" Toytec top plate spacer to help alleviate any driverside lean.
    -New top plate studs
    -Most importantly, brand new BFG 285/75/16 T/A's ;)
  2. Aug 19, 2011 at 7:37 AM
    #3682
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    :woot: 285's FTW
  3. Aug 19, 2011 at 8:06 AM
    #3683
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Looks good they look a little high just make sure you open the doors after there tacked on before you burn everything up.
  4. Aug 19, 2011 at 8:52 AM
    #3684
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    went from this
    to this
    flexin on level ground :cool:
  5. Aug 19, 2011 at 8:56 AM
    #3685
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Flushed transmission fluid and coolant. Did an oil change got a new catalytic converter and fixed an exhaust leak. Changed both differential fluids and hit 95k miles :)
  6. Aug 19, 2011 at 5:25 PM
    #3686
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    Deck plated the airbox on my 2.7. I had removed the elbow to the fender previously, as an intermediate kind of step, and think I noticed a slight difference there, mainly in the form of 4th/5th gear pickup on the freeway. So I decided to spend the $15 and put in the deck plate (the diameter of which is an inch larger than the stock piping), and put the elbow back on. Silicone still drying, so tomorrow I'll pop the battery cable off before I leave and give 'er a test.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=112679&stc=1&d=1313799919
  7. Aug 19, 2011 at 5:34 PM
    #3687
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I had to say goodbye (for now) to my baby. Set her up in a carport tent at home, to be taken out every so often by my father. Moved up to a different island for college.
  8. Aug 19, 2011 at 7:13 PM
    #3688
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Drove it 670 miles to its' new home!
  9. Aug 19, 2011 at 9:07 PM
    #3689
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek: I'll bet that had an effect on your ride...
  10. Aug 19, 2011 at 9:13 PM
    #3690
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Washed, waxed, installed a Yakima fairing, did the deckplate mod, then got it really dirty after testing out the deckplate mod. Shouldn't have washed it first :frusty: Deckplate definitely added some noticeable sound to it. I drove up a mountain road and it was not trying to shift as often as it used to, which is good. So far I'm happy :D
  11. Aug 19, 2011 at 9:20 PM
    #3691
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    yea just a little:rolleyes:
    the billies that replaced them gave me 4+ inches over them:eek:
  12. Aug 19, 2011 at 9:40 PM
    #3692
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    You mean the Eibach coils
  13. Aug 20, 2011 at 11:21 AM
    #3693
    MTgirl
    Weesa
    Bob's secret mod lair
    washed and waxed...and took the bug deflector off. it looks nekked now..
  14. Aug 20, 2011 at 12:02 PM
    #3694
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    Good day for wash and wax. did the bike also.
  15. Aug 20, 2011 at 12:45 PM
    #3695
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
  16. Aug 20, 2011 at 4:12 PM
    #3696
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    Just washed, waxed, and detailed my truck. I also fixed an annoying squeaking noise that occurred every time I closed a door. Turns out the damn front bumper was coming a tiny bit loose. Tightened that up and took care of the problem.
    I also fixed my rear bumper. Had an incident in a parking lot a few weeks ago, so rather than buying a new one I fixed it with a hammer and a hand winch. Looks good as new!
  17. Aug 20, 2011 at 5:27 PM
    #3697
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Wired up a switch and a relay in preparation for my off road lights.
  18. Aug 20, 2011 at 5:49 PM
    #3698
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
    ^Awesome job on the bumper pull^
    Changed the oil/filter, sanded and painted the wheels, stock skidder, front & rear hubs and started debadging but ran out of time. I guess "Take all the fuc*ing time you want" really means something else:confused::D. CHEERS!
  19. Aug 20, 2011 at 8:02 PM
    #3699
    tonyde443
    tonyde443 New Member
    tonyde
    socal
    05 taco pre 2 wheel
    just a muffler so far
    put on slotted rotors and so fleet pads.,thanks to Centric Parts in City of Industry.Any body know how i can get my 05 prerunner from topping out at 110?
  20. Aug 20, 2011 at 9:10 PM
    #3700
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
