  1. Jul 25, 2013 at 3:08 PM
    Madjik_Man
    Colorado Front Range
    Topper is off.
    Bed rack is on.
    About to load up the gear for the next two days of wheeling and camping.
    We haven't had so much a cloud in the sky for the past two months, but now all of a sudden the skies have opened up and it's coming down sideways. I damn near got stuck in the mud in my back yard :(
  2. Jul 25, 2013 at 3:09 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Got my new rims put on! They sure are shiney
  3. Jul 25, 2013 at 3:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Toe and camber are fine. Caster is not. Unfortunately, there may not be anything you can do about it until you install aftermarket UCAs. The lift is what has eliminated all of the caster adjustment.
    There are many choices for replacement UCAs. My choice was Camburg's unibal design. It adds 2 degrees of positive caster by default. Soooo much better to drive. Totally eliminates that loose steering feel and adds up and down range as the unibal is less restrictive than a ball joint design.
  4. Jul 25, 2013 at 4:07 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    I figured caster would be an issue from my reading. Can you explain what caster is and what it's effect is? I've read up on it some but the light bulb hasn't gone off yet. I understand toe and camber but caster is the one I'm not sure on. I'll keep UCA's in mind. What's a good number to shoot for on caster?
  5. Jul 25, 2013 at 4:17 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Simple explanation, pretend the part below is your spindle and not a strut
    More + caster makes your steering wheel want to return to center, or track straight. The same reason your wheel does not return to center when you are going backwards
  6. Jul 25, 2013 at 4:42 PM
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    It's those BFG All Terrains :D
    Also known as BFG All Terrains Except Mud
  7. Jul 25, 2013 at 5:01 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Installed my trail gear low pro. The light hoop will be goin on soon. Along with my blitz pro 21s
  8. Jul 25, 2013 at 5:04 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    crappy pic of pass. side shock relocation but its done anyway...
  9. Jul 25, 2013 at 5:19 PM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Ahh, it clicked now. I have seen that picture before and it didn't make sense because it's showing the strut, didn't think about the spindle lol.
  10. Jul 25, 2013 at 5:40 PM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Looks good Alex!
  11. Jul 25, 2013 at 5:43 PM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    I got leaf spring envy from this! Makes me want to go hunting through the junkyards :beer:
  12. Jul 25, 2013 at 5:53 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Thanks!
    Not yet. It took so long to get that light bar mount in and then all the stuff with my steering kind of snowballed so the grille stuff got put on the back burner. I promise I'll get to it eventually.
    Thanks!
    OMG every time I post them somebody says that lol. I've restored them a bunch of times and it comes back. I'm tired of doing it :bananadead: I want to get halo's eventually.
  13. Jul 25, 2013 at 5:55 PM
    Madjik_Man
    We're a subtle crew :notsure:
    Try using some kind of clear coat after you polish them down the next time (if there is a next time). It'll help it not haze so quickly.
  14. Jul 25, 2013 at 6:46 PM
    tls01taco
    tls01taco Well-Known Member
    Tanner
    Oklahoma
    2021 White TRD OR DCSB
    I've had this one a week and so far:
    Buffed
    Debadged
    Depinstriped
    Took tool box and mudflaps off
    deckplate
    My next update is a different bumper- I like the ARB, its just not "practical" for me and i like the prerunner style better. With that being said, if you're interested in swapping and willing too make a trip to northern OK we can trade straight across.
    And not too mention previous owner mods, bilstiens, leaf packs and fairly new wranglers
  15. Jul 25, 2013 at 7:45 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    :eek: want to send it to me? :D
  16. Jul 25, 2013 at 7:57 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    i can drive down to get :spy:
  17. Jul 25, 2013 at 8:15 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    :brianr: Don't worry ill buy you a 6 pac of your favorite brew if i get it :D
  18. Jul 25, 2013 at 8:36 PM
    DirtyDTaco
    Matthew
    Mississippi
    Says the 17 year old :D
  19. Jul 25, 2013 at 8:39 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    I said I would pay for it ;) not pick it up or buy it for him
  20. Jul 25, 2013 at 9:12 PM
    IanMitchy
    IanMitchy Member
    Ian
    NC
    '03 PreRunner SR5
    Straight Pipes, 3 inch spacer
    I didn't do this all today, but in the past week I put rims on my truck and painted my toolbox.
