  1. Sep 22, 2013 at 6:18 PM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    Getting ready for some fall wheeling trips.
    Replaced axle seals, wheel cylinders, both outer tie rods, both lower ball joints, put skids back on, new Optimum battery, new alternator, replaced power steering boot.
  2. Sep 22, 2013 at 6:20 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Removed old bumper cleaned up and painted with flat black.
    Installed Brute Force Hybrid bumper.
    Welded up slider plates, supports and installed sliders.
  3. Sep 22, 2013 at 6:24 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I used VHT and a very small eyelid on mine, came out well took all of 20 minutes
    :woot:
  4. Sep 22, 2013 at 6:33 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Damn, looks clean!
    Have you heard of many guys getting stopped?
    :laughing:
    :spy:
  5. Sep 22, 2013 at 6:40 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Thanks man! And I mean "he who must not be named" :rolleyes:
  6. Sep 22, 2013 at 6:49 PM
    Jonyd182
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Thanks for all the help bud....I would probably still be breaking sh*t instead of fixing it if you didn't show up.
  7. Sep 22, 2013 at 7:35 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    So I just replaced my clutch. I made sure to bleed it and the pedal still feels soft and I am getting a very slight throw out bearing cherp when the pedal is all the way out. When I press it in just a bit it goes a way. Do I just need to keep adjusting everything?
  8. Sep 22, 2013 at 7:45 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Mine chirps a at idle too, did before i did the clutch and after.
    Might need to re bleed it if its too soft.
  9. Sep 22, 2013 at 8:01 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Anyone have any ideas to fix, or recommend a new one that's not to pricey?
    Edit: I also changed out my battery cables today, Toyota really goes hardcore with the black electrical tape on the wires, it was like fort knox on that bitch
  10. Sep 22, 2013 at 8:14 PM
    theHunter
    theHunter New Member
    Hunter
    GA
    2001 Red SR5 TRD Double Cab
    I hope I'm doing this right, this is my first post.
    That happened to mine. I drilled a hole through the plastic on the same side as the original clip and that eventually broke as well. Today I drilled a hole on the other side but who knows how long that will last. Eventually I'll just get a new one.
  11. Sep 22, 2013 at 8:14 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Alright. I'll bleed it tomorrow again.
    Almost done with my rebuild.
    Total Chaos Front Bushings (Uppers and Lowers)
    FK 1” uniball (2)
    Lower Ball Joint (2)
    Vacuum Hose
    OEM Wheel Bearing (2)
    OEM Hub seal (2)
    OEM Axle seal (2)
    New Steering Rack
    FK 7/8” Rod Ends (2)
    New Complete Clutch
    OEM Clutch Hose
    Tranny mount - Ordered
    New King valve Shims for Coilovers (4)
    Lucas Oil Syn Shock Oil 1 gal
    New 600 lb Coils (2)
    New 2.5” Fox triple bypass (2)
    OEM Outer CV boot (2)
    930 inner CV boot (2)
    OEM CV grease (4)
    Falkin Tire (4)
    Misc Nuts and Bolts
    Syn Oil in Motor
    Syn grease in Drive Shaft
    New Rotors
    Brake Pads
  12. Sep 22, 2013 at 8:36 PM
    yote
    Mark
    Tacoma, WA
    What is that even?
  13. Sep 22, 2013 at 8:36 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    key fob, it unlocks the doors wirelessly.
  14. Sep 22, 2013 at 8:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hate it for sure.
  15. Sep 22, 2013 at 8:40 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Manual trans problems :p
  16. Sep 22, 2013 at 8:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    eh. Similar to the auto "thunking" problem.
  17. Sep 22, 2013 at 8:43 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Mine makes no noise. How bout yours brent? haha
  18. Sep 22, 2013 at 8:43 PM
    PcBuilder14
    Brent
    Nor Cal
    :confused:
    No noise to speak of :D
    Except when I hear the sweet sound of my 4x4 engaging :p
  19. Sep 22, 2013 at 8:45 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Yeah uh...I've never needed to lock my 4wd in...
  20. Sep 22, 2013 at 8:49 PM
    PcBuilder14
    Brent
    Nor Cal
    Haha yeah, that's why :rolleyes:
