  1. Sep 22, 2013 at 11:08 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Threw the canopy back on
  2. Sep 22, 2013 at 11:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    LT:
    Need new UCAs
    LCAs
    Steering extensions
    Limit straps
    Tundra modified cv axles
    And most expensive 2.5x8 coil overs
    Then extras:
    Cam tab gussets
    Spindle gussets
    Coil bucket gussets
    Engine cage
    Secondary hoops
    Secondary shocks
    That's sorta a list for the front.
    So...about 8k or so give or take..
  3. Sep 22, 2013 at 11:14 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Thanks for the list (i was to lazy to type it up)
    don't forget to add, the possibility of adding a triple bypass shocks on the front (or is that 2nd gen only?)
  4. Sep 22, 2013 at 11:15 PM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    Again I reiterate... What you NEED to do to have a decent LT setup is not going to run you 8k. Not everyone runs secondary shocks and full cage.
    I'm not saying that everyone should go LT. I'm just saying for me personally, I would save up and do it the first time. I've heard of too many people who went mid travel and then decided they want more, spent way more money than they had to.
  5. Sep 22, 2013 at 11:18 PM
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
    I hit a spike last night, he didn't make it tho!
  6. Sep 22, 2013 at 11:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's what I meant by secondaries.
    For the basic kit, the top half of my list, about 4-5k depending on kit and shock choice.
  7. Sep 22, 2013 at 11:25 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Sounds about right for the top of the line kit and shocks. MCM offers a kit for $2600, including ADS coilovers, brake lines, and steering extensions. I figure an extra grand in add-ons like glass, bumps, and straps
  8. Sep 22, 2013 at 11:26 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    it may seem expensive. but if u LT the front then u have to LT the rear. with mid travel the rear is a lot cheaper and In most cases more efficient for bed storage. And not everyone wants to run fiberglass and to be and extra 7 inches wider.
    Exactly. mid travel isn't as expensive but could be made better with stock length LCAs but not as much as LT
  9. Sep 22, 2013 at 11:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Coilovers are extra 600 for ADS. Also axles are included.
    And I forgot about glass! Damn and bumps. :facepalm:
    So no..still 4-5k
  10. Sep 22, 2013 at 11:32 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Kit is 2200... +600 puts it at 2800. And I'm 2wd so I don't have to worry about CV's.
    MAYBE.... 4k at the most. For ME. Everyone's different, everyone has different needs and wants. :)
  11. Sep 22, 2013 at 11:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah yes. For a prerunner tis cheaper.
    I'd still put it at 4k. Better to budget high cause everything ALWAYS cost more then the initial costs.
    And plus..once you LT...then you just start breaking stuff haha
  12. Sep 22, 2013 at 11:35 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    exactly. for me I like the way my truck corners and with mid travel it would still corner pretty well. I imagine it would not corner as well with LT
  13. Sep 22, 2013 at 11:39 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Definitely won't corner as well. And will lean on takeoff and stopping, etc... not the ideal situation for a street car. But then again... its not a street car. Haha
  14. Sep 22, 2013 at 11:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What??? :der:
    Please explain your logic...cause..LT makes you wider..ie, more stable..and is designed to go fast on very rough roads...including corners...
  15. Sep 22, 2013 at 11:45 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Im not talking about offroad. seems like it wouldn't handle as well being a bit higher up and with no sway bar
  16. Sep 22, 2013 at 11:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ride height can be up to you..adjustable coil overs man..
    And who still uses their sway bar anyways :p
  17. Sep 22, 2013 at 11:50 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    true, and I still have mine on. I drive roads with corners a lot of the time and I like to be able to take them fast. I had it off at one time but I put it back on to tow a trailer.
  18. Sep 22, 2013 at 11:50 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    A lil bedside work, finish up tomorrow.
  19. Sep 23, 2013 at 5:47 AM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Thanks for the input, i drilled a hole through the top and bottom so I'll see how long that lasts
  20. Sep 23, 2013 at 6:30 AM
    TRDEAN
    TRDEAN Too bad it’s a PreRunner
    Austin
    Dobbins, CA
    04 Prerunner
    Speedometer, tailights (going to change), sub and amp, Kenwood Head unit Bilstein 5100 on rear CB RADIO smoked tail lights eagle wheels Kenda Klever MT Icebeam bulbs (superwhite) I WANT RETROFITS!
    INDEED IT IS. hahaha i was just messin around putting that there. hoping and wishing i had a mount for it. :(
