  1. Oct 2, 2013 at 11:52 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    4 bolts and a screw. :)
    Can't remember if the center dash console trim needs to be pulled or if there is enough room to slid the clock bezel out.
  2. Oct 2, 2013 at 11:54 AM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Fixed it for ya ;)
  3. Oct 2, 2013 at 11:55 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Haha knew if I was wrong somebody would know! :thumbsup:
    I had enough room to remove the panel without removing the dash console trim, but it would probably be easier with it removed.
  4. Oct 2, 2013 at 12:07 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    Thanks bro! I remember seeing that one a while back too, looks sick!
  5. Oct 2, 2013 at 12:08 PM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah man, if I didn't love the blue so much I'd go with the mgm.
  6. Oct 2, 2013 at 12:31 PM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    After I had my truck lifted, I noticed a vibration from 0-30mph. It turns out that it changed the pinion angle. What I did to troubleshoot/fix it was add a stack of washers above the carrier bearing bracket, effectively dropping the carrier bearing by about an inch. This caused the angle of the drive shaft to not be as great, and the vibration went away.
    The best fix seemds to be to use angled shims under your leaf pack to get the pinion angle correct again instead of the washer route. Dropping the carrier bearing changes the angle of the first part of the drive line, which could create other issues.
  7. Oct 2, 2013 at 12:33 PM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    How much did you pay for your shims and where did you get them? I need to pick up some
  8. Oct 2, 2013 at 12:36 PM
    stikle
    Seth
    Call Dan at . They were like $20 for the two.
    He's the one that sold me all of the stuff for my lift, so he knew what to recommend for my exact situation. The shims come in different degrees of angles. You need to figure out what degree you need to correct your specific situation. That requires a protractor or something similar. I was too lazy to do that, so we'll see if 3 degrees was enough for me.
  9. Oct 2, 2013 at 12:45 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Hm OK. That isn't bad at all. I might tackle that this weekend when I rotate my tires.
  10. Oct 2, 2013 at 12:46 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, after the first or second time of removing the pieces it's gets pretty easy haha
  11. Oct 2, 2013 at 12:51 PM
    ffirg
    mike
    Anchorage, Alaska
    Well I took it off to install my ultragauge so I'm familiar. Also took it off to mount my parking brake bypass switch for my double din...:anonymous:
  12. Oct 2, 2013 at 1:00 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Thanks! learn something new everyday!! annnd seeing as I have no driveline vibes that's one less thing I gotta to buy for the truck!!!!
  13. Oct 2, 2013 at 1:53 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    :jerkoff:
  14. Oct 2, 2013 at 3:01 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    MGM first gen mmmmm :drool:
  15. Oct 2, 2013 at 3:12 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    What happened to it?
  16. Oct 2, 2013 at 3:22 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    I think i found a new favorite color for first gens
  17. Oct 2, 2013 at 3:41 PM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    That doesn't come on first gens just fyi
  18. Oct 2, 2013 at 3:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Cool metallic silver is the best
  19. Oct 2, 2013 at 3:50 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    Obliviously, but i think you get what im saying
  20. Oct 2, 2013 at 4:18 PM
    Madjik_Man
    Colorado Front Range
    Tell me about it.
    According to my Nike Fuel Band, I masturbated for 4 miles looking at this truck.
