  1. Oct 27, 2013 at 4:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ya know i have never really watched with my UG..i will though let ya know.
  2. Oct 27, 2013 at 4:26 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    Seems Ok, but I'm getting Coilovers :D
  3. Oct 27, 2013 at 4:55 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    my truck tends to run on the cooler side, between 176 and 192, even on a hot summer day it usually wont go over 200..
    Today I just did some interval fluid maintenance: oil & filter change, and a drain-n-fill on both front and rear diffs and the TC. The diff oil was kinda dark but the TC was pristine.. Used Lucas 75w 90.
    Doing rotors and pads on Wednesday - anyone got a solid one man brake bleeding method?!?!
  4. Oct 27, 2013 at 4:59 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Speed bleeders
  5. Oct 27, 2013 at 5:02 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
  6. Oct 27, 2013 at 5:20 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    My ultra gauge shows an average temp of 204-206. I've seen it hit 208 a handful of times and 210 once or twice. Doesn't seem to matter if it's 80 degrees out or 0. It shows cooler in the winter because I have my heater blowing obviously. But the needle on my dash has never moved. I haven't been too concerned about it.
  7. Oct 27, 2013 at 5:26 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    It's good to know that another person is running the same temp mine is. Everything is the same and the truck runs good but just wanted to make sure that I'm not the only one running in the 203-210 degree range.
  8. Oct 27, 2013 at 5:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea the subject has come up a few times in here. over 200 is normal from what people have reported.
  9. Oct 27, 2013 at 5:28 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Have you rotated your thermostat, jiggle valve mod. Mine was was running 203 and now it's 10-13 degrees cooler.
  10. Oct 27, 2013 at 5:31 PM
    Mainmoe02
    Moe
    Austin, Texas
    No I haven't, I didn't know that was a mod. First I'm hearing of this. I did have the thermostat replaced about 5k miles ago along with T- belt, water pump, pulleys and all. What exactly is the jiggle valve mod? Turn the thermostat around?
  11. Oct 27, 2013 at 5:33 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    My truck has never been above 200 according to my ultra gauge. The highest I've ever seen was 192 when sitting in traffic in the summer.
  12. Oct 27, 2013 at 6:03 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Today I pulled the instrument cluster out and lubed the squealing cable and the speedo gears for good measure. Won't know if it worked until it gets cold out.
    Took it for a drive and decided to disconnect the swaybar, (it had recently been removed so this was actually a easy task) tied it up out of the way and wow, rode much better. Cornering at highway speeds was a bit different, I might get used to it. I understand heavier rate coils make a difference, might try something different along those lines.
    I've searched a lot of threads here and found some very helpful information along the way. Thanks to all who have contributed. :)
  13. Oct 27, 2013 at 6:28 PM
    Dcpsychobilly
    Aurora Colorado
    04 dbl cab Taco
    I'm usually between 185 and 205. That's the lowest and highest on my UG
  14. Oct 27, 2013 at 6:47 PM
    DHwreckage
    DHwreckage Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
    thats the exact range my truck stays in, no matter when it was 120 in AZ or snow here in CO so i havent been to concerned either i have heard spinning the thermostat a bit will lower it but mehhh ill deal with it when i turbo my truck and get a cooler thermo!
  15. Oct 27, 2013 at 7:02 PM
    ffirg
    mike
    Anchorage, Alaska
    Yeah. What I found interesting is I'll be doing 70 on flat highway and it will read 208. Then I go up a really steep incline doing 70 the whole way at like 3500 RPMs to keep my speed up and it goes down to 190. Seems backwards or the thermostat doesn't open till 210 or something.
  16. Oct 27, 2013 at 7:08 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Well the higher your Rpm's are the faster the water pump is working
  17. Oct 27, 2013 at 7:23 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    More like what has my 1st gen done for me ;)
  18. Oct 27, 2013 at 7:26 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    ^ lol what happens when she's hideous?
  19. Oct 27, 2013 at 7:27 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Nothing wrong with that.
  20. Oct 27, 2013 at 7:34 PM
    Bobert14
    Bobert14 .
    hahaha always a gamble replying to those.
