  1. Nov 11, 2013 at 4:36 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Not even a little? We've had snow in Austin, Tx about 2 years ago and about 2 years before that. It's seems that every 2-3 years we get a good "dusting". The snow from 2 years ago was a good inch or 2. Typically we get snow 1 day out of the year and it typically melts the next day. Anyway, I can't believe it hasn't snowed in Georgia since 89 and it has in south/ central Texas.
  2. Nov 11, 2013 at 5:06 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    It's not the snow that makes things rusty, it's the salt they treat the roads with that's killer
  3. Nov 11, 2013 at 6:38 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Its snowed in atlanta, augusta etc but i live in brunswick about 30 mins north of the florida line we usually only freeze a couple nights a year
  4. Nov 11, 2013 at 6:47 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Not today but put my stocker to work on Saturday with some other Tacomaworld guys:
    6659CF63-9ABF-4AB5-85E7-666F30C2C824-295_c0b77b250634dfb0e8a54692596da41b3c3b6ce1.jpg
  5. Nov 11, 2013 at 6:49 AM
    linked2002
    linked2002 Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    Turned mine into a death machine hahaha
  6. Nov 11, 2013 at 7:21 AM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    It's the V6. Just trying to figure out if the engine is a lost cause or not. The seller parked it the moment he found the water. Normally I wouldn't bother with it, but he has about 80% of the trail mods I want already done to it. For the price he's asking I would be comfortable putting almost 2k into the engine as I would still be way ahead.
  7. Nov 11, 2013 at 8:38 AM
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    Sprayed the moving parts on the ebrake stuff under the truck with some penetrant because the E-brake light was staying on so going to attempt to adjust the cable later, just need to figure if it needs tightened or loosened :confused:
  8. Nov 11, 2013 at 9:00 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Mine did that too, sprayed all moving parts and added a second return spring to the cable underneath, I can post a pic if you need it. I did not need to adjust any cables, they just needed some help in my case.
  9. Nov 11, 2013 at 9:21 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Probably tighten. It should pull out about 12-14 clicks if I remember correctly.
  10. Nov 11, 2013 at 9:29 AM
    Mrogers33
    Columbus, OH
    Yeah i get 4 or 5 clicks at most, it seems like the spring underneath should be pulling with more tension away from the cab
  11. Nov 11, 2013 at 11:17 AM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    I ordered some new blinker assemblies, so when they came in I decided to cut the light mounts off the old housings and move them to the corner lights. Worked like a charm! Now I'm trying to find some LED spots to mount in the old location. I may even figure a way to mount them IN the old housing to keep the beautiful factory look. Anybody got any suggestions?
    Then I took her out in the woods to clean up some brush, couldn't resist the photo op.
  12. Nov 11, 2013 at 11:43 AM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    Might want to check the brake fluid as well, as the e-brake light is also an indicator that your fluid is low. Mine did that too, filled it up to the line and she's golden
  13. Nov 11, 2013 at 11:56 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    mine goes 12-15 clicks, functions as it should
  14. Nov 11, 2013 at 12:30 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Ugh, usually when your brake fluid is low...that usually means you need brakes. Unless you have a brake fluid leak... As your pads wear, the level of fluid in your resevoir will drop. Now, since you added fluid...when you compress your caliper piston back...you gonna have brake fluid run out and all over the ground.
  15. Nov 11, 2013 at 1:30 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Kind of like this lol
    8E8A9A58-4A82-45D1-B373-BCED2B54297D-332_08230ec4183468994ba0a506ddf33a5d7f436d66.jpg
    I thought it was e brake messing with me again because it gets loose too. Nope.
  16. Nov 11, 2013 at 1:41 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    :eek: That looks like a leak!
  17. Nov 11, 2013 at 1:46 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Waiting for it to come out of the shop all aligned
  18. Nov 11, 2013 at 2:03 PM
    TIPICOTACO
    Tyler
    nw nj
    pulled the trigger on the RYNO GB !!
    DON'T TELL MY WIFE!!!
  19. Nov 11, 2013 at 2:05 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Good, i want the price to drop another $10.
    And if she asks tell her your stock ones are broken and you need new ones, and these are cheaper than OEM. Honestly it could be true for the front skid.
  20. Nov 11, 2013 at 2:12 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    I love mine. If she asks/ notices just tell her they protect very expensive and near irreplacable components underneath the truck...:D
