  1. Nov 17, 2013 at 1:02 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What's that?
  2. Nov 17, 2013 at 2:55 AM
    Revco
    Revco Got that PMA
    Austin, TX
    '01 Reg Cab 4x4
    stock-ish
    I've been using Redline's "Water Wetter" for 20 years. Mostly due to having overcarbed, overcammed, & undercooled hot rods in South Texas...you try everything to keep the engine temps down. The Redline stuff never made a noticeable difference to me on the gauges, even with high dollar digital gauges, but I still put it in anyway to atleast keep everything lubricated in the cooling system and it keeps the air bubbles down.
    The "Jiggle Valve" is a check valve to bleed air out of the cooling system that is built into most thermostats. Some people think that when installing a new t-stat, the valve, or pin, needs to be installed in a certain position, but it doesn't make much of a difference if you bled the system properly and filled it with the right stuff. Others claim that clipping the jiggle valve off will help reduce temps. Kinda the same thing as drilling holes into the flange of a thermostat. I've done both, I couldn't ever tell a difference.
  3. Nov 17, 2013 at 4:08 AM
    Bobert14
    Bobert14 .
    Played tow truck for a solid 25 miles. A buddy's transmission took a crap up in the hills. Glad I bought a fairly long tow strap. haha.
  4. Nov 17, 2013 at 9:57 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Toyota says the reason is thus. The dual electrode plugs are used in the Taco for longevity reasons. The "wasted spark" system of 3 coils/6 plugs fires each plug every rotation instead of every 2. Thus a single electrode plug would last only half as long. That's straight from Toyota.
    Toyota says put the valve in the 6 o'clock position on the 1st gen V6. Countless folks on this and other forums have documented an average 10 degree running temp increase from putting the valve in the 12 o'clock position. The increase returns to normal when the valve is returned to the bottom. This does not follow historic wisdom but is is non the less the case. They also have a specific position for the 4 cyl that is different than the 6, near but not 12 o'clock.
  5. Nov 17, 2013 at 9:59 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    last time I played tow truck... i had a 20ft strap :(
    I have since bought additional straps!
  6. Nov 17, 2013 at 11:29 AM
    Motoman423
    Motoman423 Well-Known Member
    Alex
    SO CAL
    2001 Tacoma PreRunner DC
    TKO off road wheels Biltstien ZA HD shocks front and rear Flowmaster Delta flow 40 series cat back Flowmaster exhaust tip Full tint Truck Champ running/nerf bars 265/75/ LT16 tires Falken Rocky Mountain ATS tires Blacked out TRD emblems 2006+ Tacoma emblems/Badges tough country traction bars etc...
    hey you guys I keep getting mixed reviews online. I have axle wrap on my 01 4 door taco and I just broke my tough country traction bars. Would you go with bud built or pro comp ladder bars? Also I hear that people put on bilstien 5100's and the stiffer shocks do away with ale wrap is this true? Any advice is greatly appreciated.
  7. Nov 17, 2013 at 11:30 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    5100s are shocks.
    shocks won't really help axle warp..they provide no lift..
    getting a new leaf pack will..and judging form you sig pic..your suspension is shot..
  8. Nov 17, 2013 at 1:07 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Took some sick poser pics
  9. Nov 17, 2013 at 1:12 PM
    whiteneck
    whiteneck Active Member
    Michael
    Oakville, ON
    02 V6 Stepside TRD 5-speed manual
    For the first time since I bought my '02 Xtracab 5-speed stepside 11.5 months ago, the dash is cleared of all warning lights.
    Today, thanks to cmack and his thread here http://www.tacomaworld.com/forum/1st-gen-tacomas/44039-emergency-brake-fix.html and a few of the other links off this thread, I fixed my e-brake so the light doesn't stay on. Took a quick spin around the block and I kinda miss the ( ! ).
  10. Nov 17, 2013 at 1:20 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
  11. Nov 17, 2013 at 1:22 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    C02 FTW! :p
    Just kidding. I plan to get a compressor as well. Mainly for air locker, but a good back up as well.
    Between those two I recommend the 440P. Faster air up times.
  12. Nov 17, 2013 at 1:24 PM
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    also on the hunt for one, after the meet yesterday I had to borrow someones to fill up
  13. Nov 17, 2013 at 1:26 PM
    yote
    Mark
    Tacoma, WA
    There is a lot of win w/ CO2.
    Compressor is nice if you're not racing to air up w/ your pit crew.
    My pre-boot camp Xmas is looking oh so nice, it's nice to experience a little bit of heaven before you knock on hell's door
  14. Nov 17, 2013 at 2:09 PM
    Motoman423
    Alex
    SO CAL
    Thanks for the info. The 5100's do provide lift at least the set I am looking at and I dont think my stock suspention is shot i put 31.5in tires on so it took up more of the clearance my truck only as 107,000 on it. So you think go with a leaf pack like deaver? instead of a bud built or pro comp traction bar?
  15. Nov 17, 2013 at 2:16 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    5100s only provide lift in the front by either pre loading your stock coils, or by using longer/ higher spring rate aftermarket springs. The rear 5100 shocks do nothing for lift. They are longer to accommodate a lifted rear end, but don't do anything for the lift itself.
  16. Nov 17, 2013 at 2:16 PM
    PcBuilder14
    Brent
    Nor Cal
    No shocks provide lift. Period. The shocks you're are looking at probably say something along the lines of "Works with 0"-3" of lift"
  17. Nov 17, 2013 at 2:18 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    5100s in the rear do not provide lift. They can accommodate up to a 3" lift, but don't give you a 3" lift. You need a new leaf pack, shackles, or blocks to lift the rear. And FWIW, my stock suspension was shot at less than 70k miles.
  18. Nov 17, 2013 at 2:19 PM
    PcBuilder14
    Brent
    Nor Cal
    I have axle wrap as well now that my leafs with an add-a-leaf have began to sag again. I'm hoping new leafs will remedy most of my problems, and maybe somehow my shaking at 50mph.... :eek:
  19. Nov 17, 2013 at 2:19 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    I got my uncle to re-fiberglass my sub/bench box and it's hardening as we speak!! Can't wait to finally get my truck back together and get my thump back
  20. Nov 17, 2013 at 2:19 PM
    PcBuilder14
    Brent
    Nor Cal
    :popcorn:
