  1. Dec 14, 2013 at 9:16 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Look what I found!!!
  2. Dec 14, 2013 at 10:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you running all-pro leafs? I was unable to find 1.5" longer (5" bolt to bolt) shackles from anywhere except all-pro and those will not fit springs that take OEM type bushings like my alcans.
    I ended up going with 2" longer (5.5" bolt to bolt) shackles from toytec.
    I would not be happy with those numbers. The worst number is actually the left caster, way to low. Also, the camber numbers should be more similar as well.
    2" of lift is enough to diminish how much caster you can get with stock upper control arms. When I was first lifted and still running stock UCAs, the best caster I was able to get was similar to yours on the right side but it was that way on both sides.
    Unless your lower control arm bushings are worn out or the adjuster cams are frozen, a competent alignment tech should be able to set the toe and camber very close on 0 degrees and the caster as high as possible. Without aftermarket UCAs the best caster you can expect is ~+1.5 degrees.
  3. Dec 14, 2013 at 10:38 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Ok thanks for the reply... I was under the impression that I wanted all numbers to be as close to 0 as possible. So I want my caster to be over 1 degree? New UCAs aren't really in the budget right now, will these numbers cause any problems or will I be ok for a while?
  4. Dec 14, 2013 at 10:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I read your build thread after I wrote that.
    For shackle options, you have no choice actually. Other brands will be a PITA to make fit. AP springs use non-standard bushing and bolt sizes.
  5. Dec 14, 2013 at 10:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Caster normally does not impact tire wear, only handling, But yours being pretty uneven side to side may have more of an impact.
    The ideal numbers are 0* toe. 0* camber on both sides. Or as close as possible.
    Toyota states the "in spec" range for a non-lifted truck is -.65* to +.85* for camber, 1.28* to 2.78* for caster and -.08* to +.12* for toe.
    *=degrees
  6. Dec 15, 2013 at 11:56 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Three wheel motion
  7. Dec 15, 2013 at 11:59 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Does anyone have the link to the ebay reverse lights for a 95.5-00 models
  8. Dec 15, 2013 at 1:24 PM
    mrschulte
    mrschulte Well-Known Member
    Indiana
    95 v6 Ext Cab Tacoma Dlx
  9. Dec 15, 2013 at 1:41 PM
    LSC15
    Logan
    2008 TRD D-Cab
  10. Dec 15, 2013 at 1:47 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    Washed it, did some touch ups. While looking around found my driver side main eye bolt nut to be finger tight and coming off :O
  11. Dec 15, 2013 at 2:11 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    :headbang:
  12. Dec 15, 2013 at 2:11 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Painting the new bumper today
    Cheating with my heaters..
  13. Dec 15, 2013 at 2:13 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    :jellydance:
  14. Dec 15, 2013 at 2:15 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Looks pretty cold to be painting
  15. Dec 15, 2013 at 2:26 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15Âş clocking
    ^I didn't know this
  16. Dec 15, 2013 at 2:27 PM
    Madjik_Man
    Colorado Front Range
    Yeah those are tough conditions. You could actually make the steel (facing the source) too hot with heaters.
    And other parts of the steel might be too cold.
  17. Dec 15, 2013 at 3:58 PM
    30coupe
    30coupe Well-Known Member
    Russ
    Iowa
    '04 SR5 TRD 4x4 ExCab 5 spd.
    Did the Sea Foam treatment through the booster hose and into the tank today. I'm a couple months and 2200 miles away from an oil change, so I'll wait on the crankcase cleanup. It smoked and choked while I was letting it sip the SF. Let it sit for about 20 minutes then left in a cloud of smoke for Christmas get together with the in-laws. After a mile or so the smoke was gone. Seems to be running a little smoother. Hopefully I'll pick up a bit of a mileage gain. I'll switch to Amsoil at the next change. That usually gains me some mpg. At least it has with the other vehicles I've had. I know, it's a truck, so it's not going to get fantastic mileage. It's also my daily driver, so I want to squeeze what I can out of it. If I can average 18, I'll be okay with that. If I can do better, I'll be very happy! So far, I've done 17.6, 17.1, and 17.9. Close, but not quite there yet. Even with winter fuel, I should get 18 with good driving habits, which I have.
    Other than floor mats and a $50 aluminum topper (ugly but functional), I haven't done any mods. I'm not quite sure how you guys afford some of the stuff you are doing to your trucks. Not that I don't like your mods, I just can't afford them as a semi-retired teacher...whose wife is a semi-retired accountant (every penny gets pinched...twice).
    I still enjoy watching the builds though, so you guys have fun as long as you let me watch...hmmm that sounded kinda bad now that I think about it. :spy:
  18. Dec 15, 2013 at 4:00 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Credit cards... :D
    Nah I don't do that lol. Just takes a while to save up and build it up slowly.
  19. Dec 15, 2013 at 4:13 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Are stock shackles considered non-standard? I have the AP standard pack with stock shackles and they fit fine. Kinda on the same note.... would ordering just ONE extended length shackle (driver side) fix my taco lean?
  20. Dec 15, 2013 at 4:44 PM
    Domc20
    Domc20 Well-Known Member
    Dominic
    Baltimore, MD
    2001 Tacoma
    Retro Fitted headlights,HID headlights(80000k),Satoshi Grill Mod, LED tail lights, Magnaflow exhaust , Spectre CAI, 2.5inch spacer lift , Nitto Terra Grapplers 285/70/17, XD Revolvers ,2" blocks rear
    Got these things!
