  1. Jan 2, 2014 at 8:08 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    What vehicle was this washer fluid reservoir from?
  2. Jan 2, 2014 at 8:10 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Put in the rear diff, I'd agree with you. In the front diff, run the truck in 4WD w/o the rear drive shaft and I'd think it'd make for a fun drift truck. :D
    My experience with a locker up front, I wouldn't want to be stuck with a nonselectable locker using the truck as a DD and having to occasionally use 4WD on the roads. I'd have way less heartburn about popping one into the rear diff. They serve a purpose, increasing traction on a budget.
  3. Jan 2, 2014 at 8:11 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    pull the headliner down and look it will be cheaper than going thru the roof LOL i assume the 2nd gens have a cardboard headliner covered in cloth?
  4. Jan 2, 2014 at 8:12 PM
    tomtom
    The Desert SW
    2012 FJ
    Too bad you pulled the 12V outlet. Could've just plugged it in there. :D
  5. Jan 2, 2014 at 8:54 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Got some new toys :)
  6. Jan 2, 2014 at 9:17 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    What in teh hell is going on with this truck?!
    Are you doing a salvage yard weld it together crawler project?
  7. Jan 2, 2014 at 9:24 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I believe it was a 97 Geo Tracker but its still denso
  8. Jan 2, 2014 at 9:31 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Almost done installing my LR UCA's and OME kit, just one ball joint away…too bad its getting to late to be beating a hammer in my neighborhood :annoyed: have to finish it in the morning.
    p.s. how do you like that e-brake cable ;)
  9. Jan 2, 2014 at 9:45 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'm not even sure what to call it anymore. :anonymous:
  10. Jan 2, 2014 at 10:10 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I had a few words from my neighbor the day after I was cutting the old U-bolts off with an angle grinder at midnight...haha. The 21 hours of daylight made me forget what time it was lol.
    Also, what's going on with that e-brake cable?
  11. Jan 2, 2014 at 10:13 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    that is a really good question :confused:
    the e brake lever should be well below the leaf and parallel with the other one
    i wonder if he took that side axle out and put it back in wrong? but then i dont think his breaks would work right. still looks like it needs to be rotated clock wise
  12. Jan 2, 2014 at 10:23 PM
    ffirg
    mike
    Anchorage, Alaska
    Well mine goes over the leaf packs, I think it changed after 02, not sure though.
    B2BCED7C-0CCF-487A-A009-981D2D29CF16-264_c429d77696d28351c71f1486e7c28f7297f75aac.jpg
    But the ones I've seen that go under are not crooked like his looks in the picture earlier. It looks like it goes around the driver side shock or something.
  13. Jan 2, 2014 at 10:27 PM
    Jiveydude
    Micah
    OH
    04Taco
    I remember those days, two years living in Haines. The left drum is from a 98 and the right one is stock 04. Works fine for a rig job, I'll fix it when i track down an e-locker for a swap.
  14. Jan 2, 2014 at 10:27 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i believe you are right. after 02 like you said they went lower on the hub. i know that because my hubs are from an 04 and my e brake cable wasnt long enough to reach them because it was a different design
  15. Jan 2, 2014 at 10:31 PM
    ffirg
    mike
    Anchorage, Alaska
    Well that makes sense lol. Thanks for clearing that one up.
  16. Jan 2, 2014 at 10:33 PM
    ffirg
    mike
    Anchorage, Alaska
    Anybody have the dust boot on their OME shocks fall down? My passenger side rear boot fell down and no longer covers the shaft of the shock. Happened probably a week or two after installing it...
  17. Jan 2, 2014 at 11:32 PM
    flash9588
    flash9588 Well-Known Member
    Alex
    Abbotsford, BC
    It's red.
    I don't suppose you could make a write up for this once you're done could you? Same truck, same problem...looking for ideas.
  18. Jan 2, 2014 at 11:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If your thinking of dual batteries with one on the passenger side..do the PVC pipe tank. Cheap and easy.
  19. Jan 2, 2014 at 11:59 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    X2 I've been meaning to do this mod just to do it haha
  20. Jan 3, 2014 at 6:59 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Last night during my hunt for a P0172 I took out my upstream o2 sensor to clean and swap with my downstream o2 and noticed it had a loose nut, well went to re-install the o2 and the stud busted. Used one of my old framing clamps and clamped that some bitch down to get me to work. Getting new stud welded on today but what an ordeal. Cel hasn't returned but does go into open loop mid shift some times and causes a stumble.
