  1. Jan 4, 2014 at 6:56 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Trying to find the post but what I gathered from reading a bunch is that they don't solve the problem where the failure point is right at the clamp. Better off just doing the boot slide mod that stretches it out so the first ridge isn't "pressing" on itself, towards the clamp. But, again, this is what I gathered from reading a bunch. No direct experience.
  2. Jan 4, 2014 at 7:18 PM
    tomtom
    The Desert SW
    2012 FJ
    Here's the inner boot on the passenger side, getting ready to tear:
    What I gathered, just have to move the clamping point further down the shaft, stretching out just to the right of the clamp, so it won't crack right there.
    125k miles on those boots so no complaints about the stock ones from me.
  3. Jan 4, 2014 at 7:22 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The boot slide mod I found just put more stress on mine at the clamps I found. But still held for a while
  4. Jan 4, 2014 at 7:26 PM
    tomtom
    The Desert SW
    2012 FJ
    Well, shit. Damn IFS lifting problems. :D
    Right now, I can't even get the tripod off the one I'm working on. Once I get to the point where I'm putting the boots on, I may just put them on like stock. The originals lasted quite awhile.
  5. Jan 4, 2014 at 7:34 PM
    jgilbreath
    jgilbreath Well-Known Member
    Kerrville, TX
    99 Tacoma PreRunner
    Husky floor liners, SAWs 2.0
    Very excited to see the fed ex man today. Other than husky liners, i have just been doing preventative maintenance since i got the truck last January.
    Edit: i guess picture isn't going to show up, 2.0 saws were delivered.
  6. Jan 4, 2014 at 8:31 PM
    jgilbreath
    Kerrville, TX
    99 Tacoma PreRunner
  7. Jan 4, 2014 at 8:36 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Ohh sweet!
  8. Jan 4, 2014 at 8:41 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    What're your guys feelings/suggestions about cleansing or power washing your engine, I went to the salt flats a bit ago and there's done dry salt I want to spray off, any suggestions?
  9. Jan 4, 2014 at 8:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not today, but over the past week I upgraded the alternator to a 140 amp GM CS144 model, welded on Mercer Fabrication frame reinforcement plates, installed a Trail Gear u-bolt flip kit and relocated the rear shocks.
    A huge thank you to Monte at Frankenstein Fabrication for all the expertise and help with doing all these mods. :thumbsup:
  10. Jan 4, 2014 at 8:56 PM
    tomtom
    The Desert SW
    2012 FJ
    Go to the do-it-yourself car wash and use low pressure.
    Any salt is bad. Corrosive, it is.
    Very water soluble. Just a good rinsing should take care if it.
  11. Jan 4, 2014 at 9:38 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    So you wouldn't pressure wash it? Just use the rinse setting? Would you cover the cold air intake filter and the battery? Also would you worry about the engine being hot when I spray it wi that coltish water?
  12. Jan 4, 2014 at 9:51 PM
    tomtom
    The Desert SW
    2012 FJ
    salt is very, very water soluble. A rinse or low pressure setting should do fine. High pressure in the engine bay is a bad idea in my opinion. You don't want to force water into places it shouldn't go.
    Don't know what FIPK filter you are using. The aFe one I use is actually recommended to wash using soap and water every so often.
    The battery, I wouldn't worry about. Should be sealed.
    If you are worried about the cold water on a warm block, open the hood and let it sit for 10-15 minutes. This time of year in Utah, won't take long to cool off.
    Rinsing off with low pressure water is about the same as plowing through a decent puddle. Hell, I still have mud stains on the underside of the hood from monsoon season.
  13. Jan 4, 2014 at 9:57 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Haha alright buddy, thanks for the help :D
  14. Jan 4, 2014 at 10:40 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yeah I usually just use the DIY carwash and use the pressure wash setting without pulling the handle to clean anything in the engine bay.
  15. Jan 4, 2014 at 10:44 PM
    PcBuilder14
    Brent
    Nor Cal
    x2
    Whenever I buy engine degreaser I just use the bag the gave it to me in haha
  16. Jan 5, 2014 at 4:43 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Yesssssssss! I've been searching for a high quality exploded view. Thanks!
  17. Jan 5, 2014 at 7:23 AM
    Yotafish
    Yotafish Well-Known Member
    Paul
    Wilmington, NC
    2017 TRD OR 4WD DC
    Same basic shit everybody else had 5 years ago.
    That is way better than that T4R you were looking at here in Fredericksburg, VA! Congrats on another fine truck.
  18. Jan 5, 2014 at 7:26 AM
    Yotafish
    Paul
    Wilmington, NC
    2017 TRD OR 4WD DC
    Put my Surco roof rack back on.
  19. Jan 5, 2014 at 7:31 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Thanks! And thanks again for the detective work! This truck has a fresh painted frame too. :rolleyes:
  20. Jan 5, 2014 at 9:14 AM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
