  1. Jan 28, 2014 at 10:38 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Are you keeping the Toyota engine or going V-8?
  2. Jan 28, 2014 at 10:43 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I did that to my truck over a year ago and only kept it for a few weeks.
  3. Jan 28, 2014 at 10:45 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Just took tint off front windows and dropped it off for inspection
  4. Jan 28, 2014 at 10:47 AM
    Box Rocket
    Adam
    Syracuse, Utah
    New steering rack is installed. Alignment done this morning.
  5. Jan 28, 2014 at 10:53 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Turbo charging the 3RZ
    Does the handling feel any different?
  6. Jan 28, 2014 at 11:29 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'm looking at getting the Ultraguage, I found the OBDII connection under the hood, is there supposed to be one under the dash as well for a '96?
    If not is the supplied cable long enough to reach under the hood?
  7. Jan 28, 2014 at 11:30 AM
    LSC15
    Logan
    2008 TRD D-Cab
    It's under the dash above the gas pedal. Like right beside your cd player
  8. Jan 28, 2014 at 11:38 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Found it! Thank you! Looked right at it several times and didn't register..
  9. Jan 28, 2014 at 11:38 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Don't have a plasma cutter but
    :p
  10. Jan 28, 2014 at 11:39 AM
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    I don't know if the UltraGauge is worth it for the older trucks. I have an OBDII reader and there is a lot of info that is missing... Says I get 45mpg or some crap like that. Also reads the temps strange.
  11. Jan 28, 2014 at 11:42 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Needs to be calibrated. Read the owners manual. And what is "missing"
  12. Jan 28, 2014 at 11:44 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    One more UG question, does anybody order any of the mounts or just the bracket only?
    I was planning on mounting it like some of you guys did on the steering column. I got the memo about the velcro...
    Any particular mounting option needed?
  13. Jan 28, 2014 at 11:46 AM
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    I don't have an ultragauge, I have an Amazon bluetooth reader. When I plug it into the newer work trucks it has all of the data. I have tire size and engine size entered, I just think that there is less data for the older trucks. I could be 100% wrong though, wouldn't be the first time.
  14. Jan 28, 2014 at 11:47 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I used Velcro. Specifically the 3m dual lock, same stuff used on easy pass transponders. Stiffer/ stronger than Velcro, lasts longer too. You can pick up a pack with 3 1x3" strips for like $3 at target.
  15. Jan 28, 2014 at 11:51 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Cool, are you using the optional Horizontal Surface Mount with the UG?
  16. Jan 28, 2014 at 11:59 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thanks! I took another look at the column, looks like you guys are setting it in the molded"groove" on the top of the column right up against the instrument cluster...So I guess no need for any extra mounting brackets.
  17. Jan 28, 2014 at 12:00 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Just Velcro. I have a strip on the bottom of the back panel of the UG and the mating strip on the front of the cluster trim. The gauge basically sits between the steering column and cluster.
  18. Jan 28, 2014 at 12:02 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thanks everybody, I got it figured out now.:)
  19. Jan 28, 2014 at 12:02 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Probably just the obd reader you are using. My UG and kiwi Bluetooth obd reader thing with torque app both read all the parameters of the ecm.
  20. Jan 28, 2014 at 12:04 PM
    Box Rocket
    Adam
    Syracuse, Utah
    Yeah it's definitely tighter. It would get pretty "darty" on the freeway with grooves in the road. Doesn't do that anymore. I was impressed with the quality of the Safari LTD steering rack so far. Looks to be a really good piece. Time will tell if it will hold up any better than other ones.
