  1. Feb 9, 2014 at 12:51 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Finished the 4:88 swap today. Now to break them in....
  2. Feb 9, 2014 at 12:54 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    With my 255/85-16 I need the spacers to push the tires out a bit. Yoru truck looks good as it sits. When I go to 35's I probably will not run them...
  3. Feb 9, 2014 at 2:14 PM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    Got to play in the snow a little bit on the way to Hot Springs, AR. Even made a little snowman hood ornament!
  4. Feb 9, 2014 at 2:31 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Forgot about those toolbox lights you have. What lights are they again?
  5. Feb 9, 2014 at 2:43 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Get the AAL now. You'll regret it when you realize you should have installed it to begin with. I have the same setup and I sit pretty much level. The rear is a sagging a little but I think I abused the shit out of the leaf springs this summer. I'll be adding 1.5" shackles soon.
  6. Feb 9, 2014 at 2:54 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Finally remounted the cb. Cut out the back a little bit. Looks a lot cleaner now. Also add the mic mount and ran my aux cable up through the shifter boot.
    Also ran some seafoam through the a vacuum line had a heck of a little smoke cloud. Maybe it'll help mileage a little but unsure.
  7. Feb 9, 2014 at 3:32 PM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Diff breather relocate mod.
    Now next time it's time to go all Puddles Jacques Cousteu, I'll watch someone else do it and know that I would have been fine.
  8. Feb 9, 2014 at 5:38 PM
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
    Replaced drivers side front axle seal after 5 trips to town to get the right seal!
  9. Feb 9, 2014 at 5:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    none. Looks. I only ran the spacers with my 33s cause with my 33s they are on 4''BS rims and that rubs the frame. I already owned the 1.5'' spacers but only need .75'' so said screw and ran em.
    for the 35s..i need them period to keep the tire off the fender.
    You'll need them to keep the tire off the frame.
  10. Feb 9, 2014 at 6:07 PM
    PcBuilder14
    Brent
    Nor Cal
    Talk to BoxRocket. He did a ton of research before he finally bought the one he did.
  11. Feb 9, 2014 at 6:10 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Used the remaining lights from the bed under the hood. Love these led strips!
  12. Feb 9, 2014 at 8:52 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    made up a switch plate to hold a bunch of switches.
  13. Feb 9, 2014 at 9:04 PM
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    Not sure where to ask this but for you guys with ultragauges what does your temp usually run at? seems a little high but maybe its normal
  14. Feb 9, 2014 at 9:15 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Mines at 194 most of the time.
  15. Feb 9, 2014 at 9:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That does seem a bit high. Im usually around 200*F
  16. Feb 9, 2014 at 9:22 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Mine is usually around 180-195. Although "usually" is what I've observed over the past week since I got mine.
    Edit. Also, over the past week, I've only been driving to and from school. That's a <2 mile one-way trip. Starting to think my input is less than valid for this question. Lol
  17. Feb 9, 2014 at 9:34 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    damn the temp outside is in the low 30's also so its not like its hot out, also it has a brand new radiator and fluids, i bought the truck and it supposedly had all the scheduled maintenance done im at 193k now, i might just need to tear into it is there anything i can do besides waterpump and thermostat
  18. Feb 9, 2014 at 9:46 PM
    CascadesTacoma
    CascadesTacoma Well-Known Member
    Seaside, CA
    '14 DCSB TRD OR
    2014 DCSB TRD OR
    I rewired the Hella 500ff lights because I burned out the switch when I did it the first time. Bought a 3.99 switch from O'Reillys. Put it just under and to the right of my hand break release because I plan on putting in a switch panel at some point and wanted the hole out of the way but easily accessible.
    Oh yeah, having your own soldering iron makes life easier. They cost next to nothing on ebay and with just a little shrink tubing allow you to really clean up the wiring in your truck. Plus, really helps fix mistakes when you get your wires confused because there are 8 different colors and black means power and blue means ground and who can remember that?
  19. Feb 9, 2014 at 9:52 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Took her wheelin after an oil change... All my bed liner fell off the chrome on the front bumper after pressure washing her... Hella whack,... Anyways, today was fun
    On a good note, the wife said" why don't u just buy an aftermarket bumper"..... I wish..lol
  20. Feb 9, 2014 at 11:21 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    203 before and 190-193 after jiggle valve mod.
