  1. Feb 21, 2014 at 10:03 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I sent King an email phishing for info on if it's normal for them to clunk when it's cold. They were brand new a month ago. I just want to hear what they have to say.
  2. Feb 21, 2014 at 10:08 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    The 3 bolts that go through the coil bucket. If they get even a tiny bit loose it allows space in between and the top adapter will slap into the coil bucket
  3. Feb 21, 2014 at 10:08 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    If you had a pick up truck you could have made it in one trip.
    owait. :p
  4. Feb 21, 2014 at 10:12 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Got the big brake kit from LCE. VERY happy with it. it replaces all he rubber lines with solid and/or braided. only had to do a minor amount of bending to the passenger side dust shield but the driver's side required none. 60 - 0, 50ft. 0 - 60, 3 miles.:rolleyes:
    20140219_125943
    20140219_130101
    20140219_130548
  5. Feb 21, 2014 at 10:15 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Kinda goes together but switching shocks would eliminate the shocks if it still clunks, but if the clunk goes away its not 100% the shocks. The Kings will have more compression dampening to them and can make noises surface where the less valved shocks may not. Same with the cold, it may not be the shock, but since it was super cold the fluid is thicker and putting more stress, making the bj pop (or whatever may be clunking)
  6. Feb 21, 2014 at 10:17 AM
    Trim taco
    lemme try this again
  7. Feb 21, 2014 at 10:24 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Those look massive in that car!
  8. Feb 21, 2014 at 10:26 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    haha
    Totally worth it :D
  9. Feb 21, 2014 at 10:29 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ha I bet. I love your build so it's just the jealousy talking.
  10. Feb 21, 2014 at 10:30 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    There may not be any sign and this may not be your issue but if your shocks use regular schrader valves, they are notorious for slow leaks and usually leak just nitrogen (seals leak shock oil). Most of these valves are only rated for around 200psi at the get go. I solved the issue in mine by replacing the "gasket" in the valve cap with thicker "Viton" (trade name) material and tightening the cap pretty well with pliers.
    For the other guy, border line low nitrogen pressure can show up at lower temps first.
  11. Feb 21, 2014 at 10:55 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Check with your shock manufacturer for the correct pressure. Mine need every bit of 200psi and that is the default pressure the local shop uses unless you specify something else. Some shocks are more tolerant of pressure variations than others. SAWs are the bitch in the kitchen.
  12. Feb 21, 2014 at 11:10 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Assuming they are holding pressure, 175 should be fine. Kings have better flow characteristics than lesser shocks, like mine:(.
  13. Feb 21, 2014 at 11:36 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Well, I probably should but most of my stuff was done in the days of film cameras and scanning old photos is a pain.
    I don't have all that much going on, it is all listed on the bottom of the name/location/avatar area, what ever it's called. I will just have to pay my dues with the occasional write up. Got a new one in the works right now.
  14. Feb 21, 2014 at 11:52 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  15. Feb 21, 2014 at 11:54 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Yes but as blackdog says why wouldn't you. I'm sure I could do it with enough time but it my DD. Just getting all the parts would take forever.
    Any suggestions on anything else I should do/replace while the transmission is out.
    I remember someone else saying this, but he was wrong:rolleyes:
  16. Feb 21, 2014 at 11:54 AM
    MatthewMay1
    Matthew
    Lone Star Republic
    3' firestik? Is it the FireFly model?
  17. Feb 21, 2014 at 11:57 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I believe its a 4 footer. Honestly, I dont know much. My buddy with a 2nd gn ordered his stuff first. I just replicated his order
  18. Feb 21, 2014 at 12:00 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Ah. I have the 3' FireFly model in black on a spring. I've whacked it on trees pretty good and it's held up to the abuse. Sticks up well above the roof of the cab, too.
  19. Feb 21, 2014 at 12:05 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Cool, Im excited to get this thig mounted. Did you get yours tuned after the install?
  20. Feb 21, 2014 at 12:10 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Yeah I have an swr meter, but I was having problems with the coax connection at the radio so I had a shop re-do the connector and tune for me. You have to tune it in order to not fry the radio
