  1. Mar 26, 2014 at 1:36 PM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Yes, I can however, right now I am at work, and don't have the truck with me today. I measured the body of the strut and it was 10.5 inches long. With the window closed I think it was like 12 inches long from eyelet to eyelet. I didn't know if I was supposed to measure it with the window shut or open. I was just seeing if anyone knew which way to measure it, so that when I go home I can take care of it and order them tomorrow. Or if anyone had a snugtop and already knew the measurements then I could just give that to redline and order today!
  2. Mar 26, 2014 at 2:03 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    VVVVV
  3. Mar 26, 2014 at 2:22 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    So just starting today, when I press my brakes my right turn signal bulb in the dash lights up ?! also if I'm in cruise control and hit my turn signal CC shuts off. Gonna go check my trailer harness first. Maybe its because I have LEDs in stock housings and stock wiring ?
  4. Mar 26, 2014 at 2:26 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Did you ever install a new relay or any resistors for the LED's?
  5. Mar 26, 2014 at 2:35 PM
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    Nice truck. Did you paint or derp your rear bumper? I'm still debating on what to do.
  6. Mar 26, 2014 at 2:37 PM
    sennasixty8
    sennasixty8 DoubleCab Lurker
    SF Bay Area
    Unlimited Pavement Patroller
    New Michelins AT2's and Bilstein 5100's on the way.
  7. Mar 26, 2014 at 2:39 PM
    Kennyperez
    Kennyperez Well-Known Member
    Kenny
    Yucaipa
    Tundra
    Plastidip!! No prep need just clean it and 2 layers
  8. Mar 26, 2014 at 2:43 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    ya and if you want to change back to chrome just peel it off. make sure to do lots of coats.
  9. Mar 26, 2014 at 2:45 PM
    bellassaiw10
    Currituck NC
    I swapped my relay out to get rid of the hyper flash but the problem just started :confused:
  10. Mar 26, 2014 at 2:48 PM
    PcBuilder14
    Brent
    Nor Cal
    Hmm, okay. Just wondering if you hadn't because the excess power the LED's wouldn't have used could have gone to other wiring.
    But since you did, I don't know...
  11. Mar 26, 2014 at 2:52 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I sold it and bought a Hypertherm plasma cutter :D Then grandma paid for half of the Softopper soooooo...
  12. Mar 26, 2014 at 2:53 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Yea man for sure, im sure shipping would be killer but im not looking to make any money off it. I think most the stock parts are claimed otherwise id send them too lol I think plating and welding it would be fine. id gouge that crack out somewhat beveled then weld it up then grind it smooth and plate over that for re assurance.
  13. Mar 26, 2014 at 5:15 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Fix the rattle in my exhaust and found that the drivers side steering boot is torn so that the retainer clip can no longer hold it in place.
    Exhaust fix:
    Steering boot:
  14. Mar 26, 2014 at 5:40 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    How the hell do I do that lol? I have resistors installed at the ends of the wire where the blinker is so I can just take the resistors off and cut the wire back a little..
  15. Mar 26, 2014 at 5:42 PM
    PcBuilder14
    Brent
    Nor Cal
    What are you talking about? Haha
  16. Mar 26, 2014 at 5:46 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    ^ how do I use the excess power of my led (hyper flashing) for other wiring?
  17. Mar 26, 2014 at 5:52 PM
    scocar
    scocar hypotenoper
    *DCSB plus le skewp de faqué
  18. Mar 26, 2014 at 6:00 PM
    PcBuilder14
    Brent
    Nor Cal
    You don't... Excess power isn't a good thing... It can run back down the power wire to the source (your fuse box in the cab) and go to any other item ran from the fuse box and cause random power surges or issues.
  19. Mar 26, 2014 at 6:24 PM
    Bobert14
    Bobert14 .
    I'm used to shipping being a violating experience haha. That's the plan for the temp fix.
    I'm trying to track down a complete, straight frame for a pull yard. The severity of that crack in the cross member kind of makes me doubt the whole frame. It would be nice to start with an unmolested frame and beef it up before it goes under the truck. Plate it, box it, all that good stuff. I don't know, just depends on if a new cross member pops up before a frame and how much work getting the cross member in will be.
  20. Mar 26, 2014 at 6:30 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Was that heat shield making a god awful rattle at idle? Mines downright embarrassing at drive thru's and the gate comming onto base lol
    Any more details?
