  1. Mar 31, 2014 at 9:27 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    where has this thing been all my life... :drool: build?
  2. Mar 31, 2014 at 9:45 AM
    Ferber
    Ferber New Member
    Utah
    v6 4x4
    Where do you got the clear tail light lens?
  3. Mar 31, 2014 at 9:47 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Jeeezus, how many nissians a day do you feed it !! Nice truck BTW....
  4. Mar 31, 2014 at 10:14 AM
    scocar
    scocar hypotenoper
    Well, question is, is that the problem? No point trying to solve it if it isn't. Compression test and borescope.
    And, the knock sensor should be tested and replaced if necessary. I'm pretty sure it is just a simple in-place resistance test, but don't have manual handy (or time right now).
    Check and do all the easy PM stuff first, PCV valve, then MAF and TB and IAC cleaning. Check all your vacuum lines for cracking/brittleness, too.
    Just for kicks because it is good PM and easy too, when is the last time the fuel filter was changed? You might want to do this, then run several batches of Techron fuel system cleaner (not injector cleaner, the system cleaner has a higher concentration of solvents) through it.
  5. Mar 31, 2014 at 10:17 AM
    DarkShark
    DarkShark Well-Known Member
    Clark
    Medford/Southern Oregon
    03 DCab 4wd
    Icons, Camburg and custom stuff......
    Where did you order that box from?
  6. Mar 31, 2014 at 10:19 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    35s on a 10'' rim. Believe he put them on last month..
  7. Mar 31, 2014 at 10:21 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Have you calibrated trip gauge? 20 mpgs is crazy good with those tires.
  8. Mar 31, 2014 at 10:30 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Ebay.
    And super coincidence I saw this, because this is the first time I have logged in in about a month or so.
  9. Mar 31, 2014 at 10:33 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    im impressed he saw it..was from 2011..haha
  10. Mar 31, 2014 at 10:42 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Love the color of your truck Jonathan
  11. Mar 31, 2014 at 10:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    He sold it...the traitor...
  12. Mar 31, 2014 at 11:17 AM
    scocar
    scocar hypotenoper
    No, you would see higher than stock spec compression. Basically, carbon builds up on the top of the piston, decreasing the volume of the combustion chamber and therefore increasing compression over stock spec at TDC, and potentially leading to predetonation, which is a premature ignition of the A-F mixture before the sparkplug is timed to fire.
  13. Mar 31, 2014 at 11:33 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Might need a new grommet too for the valve cover if you see lots of crud around it
  14. Mar 31, 2014 at 11:36 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Do most of you guys run the shock cover down??? when i installed mine i did it with the cover up
    Should I switch it? I was doing some trimming yesterday and noticed water from my last wheeling trip coming out of the cover :eek:
  15. Mar 31, 2014 at 11:39 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Ya ever run sea foam thru the vacuum lines at the intake? It will clean the intake valves and hopefully most of the carbon buildup in the cylinder. IMO the compression test would be a good idea too, but if it was my truck I'd run some sea foam thru first cuz it's cheap.
  16. Mar 31, 2014 at 11:42 AM
    NoTown98Yota
    NoTown98Yota Whiskey Throttle FTW!
    Scott
    Reno, NV
    '98 Tacoma 3.4L V6 W/E-Locker
    -Leer shell with Yakima MegaWarrior -K&N FIPK -18" Magnaflow dumped after axle -Clear headlights -Blacked out bumpers, wheels, badges, mirrors, fuel door, door handles, tail lights, corner markers and turn signals -White LED gauge lights -SpiderTrax 1.5" Spacers -Pinch Weld Mod -Ultra Gauge -6 Switch Plate under single din stereo -Custom Battle Born bedside decals -Eibach 620# coils -Bilstein 5100's -Dakars -Toytec 1" Lift Shackles
    :rofl::rofl::rofl:
  17. Mar 31, 2014 at 11:44 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I run my OMEs shock body down. The boot is more of an open ended sleeve and would hold water if I ran shock body up.
  18. Mar 31, 2014 at 11:46 AM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Is this the same regardless if they are gas or oil filled? I had a TJ that had horrible axle hop. I flipped my struts and the problem went away.
  19. Mar 31, 2014 at 11:48 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    hmmm, so no harm in running the boot down?
    any harm if i keep it the way it is now? boot up?
  20. Mar 31, 2014 at 11:48 AM
    NoTown98Yota
    Scott
    Reno, NV
    X2, that is really my only reasoning for doing it that way. I haven't heard a real strong argument for it being better one way or the other, you should be fine.
