  1. Oct 24, 2011 at 9:28 PM
    #5241
    oracle
    oracle Member
    Calgary, AB, CANADA
    03' DC 4x4 TRD, Ltd and Moonroof 3.4lt Taco
    bunch of miles, scars and dirt..
    Hi,
    What is 'acidize'? I ask because I need to do exactly that... those wheels looks new..
    Thanks!
  2. Oct 24, 2011 at 9:45 PM
    #5242
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I'm assuming he is talking about some sort of acid wash. I sell some stuff where I work that is mostly oxalic acid that works really well on aluminum boats, I might try to use it. Spray it on and let it sit for a few minutes and rinse with water. I just don't know if it will damage the rubber...
  3. Oct 24, 2011 at 9:48 PM
    #5243
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    he does have a paint (get it paint not point). the paint is scratched.
  4. Oct 24, 2011 at 9:52 PM
    #5244
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Does that one have a manual bypass like the stock one?
    Sounds like the relay is not strong enough to handle the loads.
    reason i ask i just got mine put on but im running a manual switch to run them in case it gets too warm.
  5. Oct 24, 2011 at 10:21 PM
    #5245
    homelandtaco
    homelandtaco Member
    Tyler
    Riverside, CA
    02 DoubleCab SR5, Icon Coilovers
    Icon 2.5 Coilovers, Pro Comp AAL, Rear Bilstein 660's, Deck PLate Mod, Flowmaster
    I used rustoleum paint semi gloss back.. First I used easy off oven cleaner to strip the polish and any other stuff off the rims for a good base. Then I sprayed three coats of primer 15 min to dry between each coat then repeated that with the black semi gloss.
  6. Oct 25, 2011 at 12:40 AM
    #5246
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Its the box that you mount up in the engine bay that has a turn knob for pre set temp control, Also it is set to auto come and stay on with AC and Defrost.
    It works like a charm when not off roading.
  7. Oct 25, 2011 at 4:57 AM
    #5247
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Taking it in for the rust recall any minute now :/
  8. Oct 25, 2011 at 7:20 AM
    #5248
    MTgirl
    Weesa
    Bob's secret mod lair
    :eek: no more taco?
  9. Oct 25, 2011 at 9:26 AM
    #5249
    malander
    max
    01 limited trd 4x4
    They're sending the case in to Toyota corporate today so we should know by the end of the week hopefully. I kind of fucked my chances since I was painting over everything, but there are still two holes inboard of the spring hangers
  10. Oct 25, 2011 at 11:38 AM
    #5250
    gatorboyy13
    gatorboyy13 Well-Known Member
    Brian
    Corvallis, OR
    2016 TRD OR DCSB Black
    CustomCarGrilles Small Perf & "TOYOTA" Grille Insert CaliRaised 31" Light Bar w/ ApexFab Stealth Mounts Header Rail w/Bike Mount
    What program is that?
  11. Oct 25, 2011 at 11:42 AM
    #5251
    MTgirl
    Weesa
    :popcorn:
    AutoCAD
    So you're at risk of having your leaf springs break free? Not good...
  12. Oct 25, 2011 at 11:46 AM
    #5252
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Not only that, but aired down gives a better tread contact patch on the ground, which in turn yields more traction.
  13. Oct 25, 2011 at 11:54 AM
    #5253
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Hooked up some new 7" lights that were fitted with 5k HIDs and put a old "toyota" emblem on in place of my custom emblem! I also re-painted the grill surround. The roll on bedliner idea just didnt work out to well!
  14. Oct 25, 2011 at 12:01 PM
    #5254
    malander
    max
    01 limited trd 4x4
    yeah pretty much. I would imagine the spring hangers would go through the frame and my rear tires would eat my bed.
  15. Oct 25, 2011 at 3:17 PM
    #5255
    Dwill817
    Dwill817 Well-Known Member
    Drew
    Alabama
    1981 Toyota Pickup 4x4
    HA! My "new" rims! I like em though!
  16. Oct 25, 2011 at 4:34 PM
    #5256
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Man wish I could do something to my Tacoma, after that last flood, my garage is filled with all kinds of crap. had to go to my friends gas station just to change the oil and rotate the tires.
  17. Oct 25, 2011 at 5:00 PM
    #5257
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
  18. Oct 25, 2011 at 5:12 PM
    #5258
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    looks sweet!!!
    thanks man :thumbsup: Cant beat the lights for $9!! haha just need to find some clear covers for them instead of the black ones
  19. Oct 25, 2011 at 6:15 PM
    #5259
    hayabusa3303
    florence sc
    95.5 taco 4x4
    electric fans are up and running. fuse block is up and running also.
    New hood installed but i going to have to work on it more tomorrow ran out of day light again. ( hate that is gets darker sooner now )
    On tap tomorrow pulling the ARB bumper and winch out of storage getting the bumper ready for mounting.
  20. Oct 25, 2011 at 7:04 PM
    #5260
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Lowered my tire pressure some to even out tread wear, and painted my rear hubs black. They guy that repaired my truck supposedly did an alignment, buy the inside of my tires show that they don't even touch the ground. (Inside of tire still has dirt marks on it after driving on pavement while the rest doesn't.) Maybe it's just because I have stock UCA's, and they settle after an alignment?
