  1. May 23, 2014 at 5:02 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
  2. May 23, 2014 at 5:21 PM
    tomtom
    The Desert SW
    2012 FJ
    Welcome to the candy crowd. :)
    Got the blinkers done up. Pictures and video to come later tonight. It actually worked out really well when SGT Taco showed me the right adhesive to use.
    I'm looking into the equivalent LEDs for it. The lenses do get a bit warm.
  3. May 23, 2014 at 5:31 PM
    Madjik_Man
    Colorado Front Range
    I got mine from superbrightleds (where else?)
    They're great.
  4. May 23, 2014 at 5:32 PM
    Madjik_Man
  5. May 23, 2014 at 5:52 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Ohs no what you painting now?
  6. May 23, 2014 at 5:53 PM
    Madjik_Man
    I'll give you a hint:
    There's a picture of the part, and it's written in all caps, in the photo.
    :p
  7. May 23, 2014 at 5:59 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    LOL shows how observant I am:D
  8. May 23, 2014 at 7:44 PM
    tomtom
    The Desert SW
    2012 FJ
    OK, video of the blinkers working. The "write-up" (actually just a bunch of pictures) is in my build thread.
    Also, got some more candy from Wheeler's (and some OME goodness):
  9. May 23, 2014 at 8:36 PM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    new starter, All Pro uca's, and working on manual hub conversion
    not the best picture but kinda hard to stop and take one lol
  10. May 23, 2014 at 8:36 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Did the jiggle valve mod tonight and WOW!!! I was wondering why everyone else was running in the 190's - low 200's and I was always in the 206-208 range with a 210 every now and then. Well after I rotated the thermostat I'm now running 190.4 constant while driving and 192.2-194 while idling. I'm hoping the 15 degree difference in temp will be a little easier on the engine.
  11. May 23, 2014 at 9:08 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Did you clip the jiggle valve or what did you do?
  12. May 23, 2014 at 9:33 PM
    Mainmoe02
    Moe
    Austin, Texas
    Yeah I just rotated it to the 6:00 position. The manual for the 3.4l Toyota engine says it should be I the down position and it's correct, especially after the degree change I've noticed.
    Another thing I did was replace plugs and wires with denso dual electrodes and denso wires. Trying to fight a thwarting sound and slightly rough idle which after having it tested today the tech found all signs to be good. Compression test came out good also.
    I had the timing belt done back in June of 2013 and the thermostat was installed at the 12:00 position which made my temps higher than they should have been. I wonder if having the engine always running at 206-208 degrees for the past 10 months could have caused any damage? It got up to 210* and 212* a couple times (212* maybe 5 times).
  13. May 23, 2014 at 9:37 PM
    Madjik_Man
    Is this something you can easily visual inspect? Is it as simple as removing the lower hose?
    If so, can you point me in the right direction?
  14. May 23, 2014 at 9:48 PM
    Mainmoe02
    Moe
    Austin, Texas
    I just unbolted the 3 bolts holding the thermostat housing on and then you can easily see if the jiggle valve is up or down. I didn't unhook the lower hose because there was plenty of room to pull the housing and thermostat. Most of the antifreeze leaked out anyway so after rotating it and bolting everything back up I refilled the radiator, had the heater on high, and burped it with the radiator cap off.
    If you've never replaced the thermostat and it's till the one from the factory then I'd guess its in the correct position. But if your unsure then I'd say take a look, it's an easy job that took maybe 20-30 minutes.
  15. May 23, 2014 at 9:52 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Changed oil, fixed wiper res hose leak :D also recieved deccals in mail !
  16. May 23, 2014 at 10:02 PM
    tomtom
    The Desert SW
    2012 FJ
    Proper tool for the proper job makes life so much easier.
  17. May 23, 2014 at 10:03 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Kind of my thoughts haha
  18. May 23, 2014 at 11:06 PM
    RyanC
    RyanC Well-Known Member
    Puyallup WA
    95 Tacoma 4x4
    Lifted, 33/1250/15's, canopy.
    Did a bit of exploring..
  19. May 24, 2014 at 12:59 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Nice pics, nice truck!
  20. May 24, 2014 at 2:34 AM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Sounds like a rough day.. I just drove for four hours cause some dumbass guy told me he had a 69" rear ford dana 60. When I got there I asked him to measure and it was 66"..
