  1. May 25, 2014 at 12:53 PM
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    :ohsnap:
  2. May 25, 2014 at 12:59 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    It's low key. I like it! :thumbsup:
  3. May 25, 2014 at 1:19 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I wanted something different than what everyone else has. My dual light bars will cover it up though.
    Which reminds me... Does anyone know where to get new end caps for light bars? One of mine is screwed. I saw one for like $60 but that's a little much.
  4. May 25, 2014 at 1:22 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I like it, definitely different than anything else I've seen.
  5. May 25, 2014 at 1:51 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Just giving you crap. :D As long as you like it, that's what counts. But if you want my .02, I'd make it smaller or black.
  6. May 25, 2014 at 1:54 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Thanks. Dislikers can dislike, but it's nice to have something you don't see on on 20 different trucks here.
  7. May 25, 2014 at 2:18 PM
    MOTACO
    MOTACO Well-Known Member
    SW Missouri
    Tacoma 4x4
    Proper air pressure in tires, clean windows, coins under seats.
    Finally finished the fix for my flapping fuel door. (Try saying that five times fast.)
    Did a write up in case anyone else wants to try it. Linky
  8. May 25, 2014 at 2:38 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
  9. May 25, 2014 at 3:46 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Try putting them in a coil wind up and rotate it around. May have to use a hammer to get them in and out.
  10. May 25, 2014 at 4:01 PM
    MOTACO
    SW Missouri
    Tacoma 4x4
    What kind of coil spring compressor are you using?
    You may already know this. If you are using this style coil spring compressor,
    then you can disassemble the fulcrum end of it, which will allow you to manipulate each arm to more easily attach it to the coil spring. Once attached, reassemble and compress.
  11. May 25, 2014 at 4:02 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Did you rent the compressor from autozone or something? I had the same problem when I installed my OME. I managed to get the retaining pin like halfway on, but the 883s were making the comprssor bolts bend. :eek: Sketchy as hell!
  12. May 25, 2014 at 4:35 PM
    Madjik_Man
    Colorado Front Range
    Better save it and put it into the build fund.
  13. May 25, 2014 at 4:51 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    :laughing:
  14. May 25, 2014 at 4:54 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Attempting to follow here. Sorry if this is not helpful. You can't simply unload the coil by lifting that side off the ground then turn the collar?
    I've done this on a friends and it wasn't that hard. Is the collar seized, maybe?
    I could see where using the heavy-duty handcuff zipties might work. Maybe put them on with the side loaded and then unload it?
  15. May 25, 2014 at 4:59 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
  16. May 25, 2014 at 5:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah my 881's were similar. Thought I was going to die with those vatozone compressors.
    I would go with the zip ties but make sure they're heavy duty and have the metal tabs.
  17. May 25, 2014 at 5:02 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Temporarily mounted my hi-lift and picked up my Memorial Day project along with rebuilding my injectors.
  18. May 25, 2014 at 5:24 PM
    tacotundra
    tacotundra Well-Known Member
    when did felpro change there color to blue? Must be other update again?
  19. May 25, 2014 at 6:23 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Felpro rubbers have been blue for the last 4 years at least..?
  20. May 25, 2014 at 6:46 PM
    Redneck92
    Concord, NC
    Not all have. Some are black and some are blue.
