  1. Jul 13, 2014 at 11:22 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Holy mother fuck dude!! Oh my god! Im so sorry that happened to frank :(
    what a nightmare. You are going to make me nervous to even drive mine now!!
    I dont see how at all. he has only been running them just this summer.
  2. Jul 13, 2014 at 11:27 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yea I think LBJ replacements are in my future. I doubt mine have done so its time for some preventative maintenance
  3. Jul 13, 2014 at 11:38 AM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Never said it was exclusively to 35's. Just pointing out that those of us with 35's that actually wheel our tracks need to be more diligent.:smack:
  4. Jul 13, 2014 at 2:04 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    On page 2 of my build! :goingcrazy:
  5. Jul 13, 2014 at 2:07 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    heres some shots of the bumper. I used the all pro bumper as the "base". Its not pretty but hey it will worked. I need to add some angled square tube behind the tailight and it will be done. It was 330am on Friday when i finished this so i decided this will be for another day.
  6. Jul 13, 2014 at 2:09 PM
    Madjik_Man
    Colorado Front Range
    I've seen deep underwater cave shrimp with more pigment than Monte.
  7. Jul 13, 2014 at 2:13 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    Pretty don't get you down the trail. I could care less about looks it's all about function. Unless your a mall crawler then it's all about the bling bling. If that bumper works then who cares how pretty it is.
  8. Jul 13, 2014 at 2:25 PM
    slander
    Hickory, NC
    Yea, the sheet metal that you see in the pics is just a taste of what the rest of the truck looks like. My mantra is 100% form follows function, i ran without the rear bumper sides and caved in the pax side rear bedside and almost took the tailight out, so i made this.
  9. Jul 13, 2014 at 2:29 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    :D
  10. Jul 13, 2014 at 2:31 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I have 3.5'' of shaft showing on the shock and 6'' between the bump and pump pad on the frame.
    How long should I make my bump extenders? 2.75'' or 3''?
    I don't know how much the stock bumps compress.
  11. Jul 13, 2014 at 2:39 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    Are your shocks in Stock location? What length shocks ? Any pictures of your setup?
    I am running expo's u bout flip kit with 10" Bilstiens custom mounted with stock bumps ..
    I have no problems with flex or bottoming out my shocks.
  12. Jul 13, 2014 at 2:49 PM
    95 taco
    95 taco Battle Born
    Yes, stock location, 9'' stroke 5125's. I can get some in a little while
    Compressed length 15.11"
    extended length 24.35''
  13. Jul 13, 2014 at 3:13 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Applied penetrol to my flairs:
    Before:
    After:
  14. Jul 13, 2014 at 3:23 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    [​IMG] So I got the LC Engineering headers installed. The issues I had installing was that the ending of the headers didn't match up to my 2nd cat. So I had to move the entire exhaust system closer to the front of the truck. The transmission dip stick was also in the way and I had to take the top half of it off. After I install the header I had to try and fish it threw the pipes to put it back. The dip stick does rub against the header pipes. When I started the truck after the install there was an obvious increase in power and it has a slight deeper tone coming out of the tail pipe at higher RPM. But I still haven't test drove it yet. I will keep you guys posted after I do. O yeah I have the 3RZ engine.
  15. Jul 13, 2014 at 3:24 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    How often do you have to reapply?
  16. Jul 13, 2014 at 3:36 PM
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    :popcorn:
  17. Jul 13, 2014 at 3:57 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Forced my smashed in front fender back out. Not perfect, but much better. At least I can open my drivers door all the way.
    Before:
    na5ejaje_657ad2aa7a146e8bb655fde76ca55e52a6c997c1.jpga2y6evuq_589d96495c4ee4d9b96372da6defd9a9f3e5a29c.jpg
    After:
  18. Jul 13, 2014 at 4:10 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It lasted a couple months last year but I want to try to reapply every month and see how it works.
  19. Jul 13, 2014 at 4:20 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    went and had some fun yesterday
  20. Jul 13, 2014 at 4:26 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Nice Jace!!!!!
