  1. Jul 28, 2014 at 7:45 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    My bad, didnt realize it was stick
  2. Jul 28, 2014 at 7:49 PM
    96 tacomaPtown
    96 tacomaPtown Well-Known Member
    Bryan
    Oregon
    96 ext cab 4x4 taco
    3 inch spacer lift,pro comp addaleaf, 1 inch diff drop kyb shock/struts, Lc engineering header, stock muffler, hollowed cat, 2 1/4 exhaust, o2simulator , 31 10.50 15 wranglers on stock. Hella 500 headlamps, bug gaurd, vent visors, bed caps, bed liner, Volant cai intake.
    Just finished swapping out wheel bearing cv axles seals and upper balljoints big project . Pain in ass for sure.
  3. Jul 28, 2014 at 8:40 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I dont know enough about alignments to kbow if this is good or not. Drives strait which is all I really care about but I'm curious, anybody have input?
  4. Jul 28, 2014 at 8:51 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I put my speaker behind my center console, it's not mounted just placed there and it sounds good. Doesn't roll around either
  5. Jul 28, 2014 at 8:59 PM
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    Looks half-assed to me. A lot of shops will only adjust the toe if it that is all it takes to get the numbers to "turn green". Notice how the camber and caster are unchanged. With some effort, the tech could have gotten you a little more caster and evened the camber out. It could definitely be better, but you will have to tell them what you want.
  6. Jul 28, 2014 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You guys are light-weights for sure.
    See what I mean. :p
    Last summer when we were all in Powell, we all weighed our trucks on the same scale, one after another.
    Ben and Mark (IDtrucks) were by far the lightest at 4400, Monte was the heaviest at 5600 and Joey (tonto27) and I were below fat frankenstien a little at 5400. We were all loaded for bear tho, headed for Lander and then the Alpine loop.
  7. Jul 28, 2014 at 9:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Are you lifted at all? Still with stock control arms?
    As these guys have mentioned, a toe and go alignment is designed to make the shop money because it does not take long to execute and doesn't tie up the equipment or the tech for very long.
    Assuming there are no wear issues with your suspension components, a competent tech could get better results for you.
  8. Jul 28, 2014 at 9:41 PM
    Bobert14
    Bobert14 .
    Let it live the easy life and haul bikes instead of getting abused this weekend.
  9. Jul 28, 2014 at 9:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Based on the results I get when I use the truck scales around here, I agree those numbers were high. Maybe as much as 4-500 lbs. high.
  10. Jul 28, 2014 at 9:50 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Thanks guys! I might take it to a different fire stone and tell them what id like done. Glad I bought the life time alignment though
  11. Jul 28, 2014 at 10:06 PM
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Sweet did you paint the grill since I saw you last? It's been a long ass time... Sorry I couldn't make pc
  12. Jul 28, 2014 at 10:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I've probably used my 'lifetime' alignment 10 times in the last 3 years. They don't even bother to ask me any more if I want that courtesy check. Also on a first name basis with their best tech.
    I'm sure they say, look, here comes that picky, pain in the ass, guy again. :D
  13. Jul 28, 2014 at 10:31 PM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Positive caster is what you are after correct? Between 3-5* that will help with straight line stability from what I understand yeah?
  14. Jul 28, 2014 at 10:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :p
  15. Jul 28, 2014 at 10:40 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    No sir...just washed her before the meet...lol...no worries brotha, ill catch u soon
  16. Jul 28, 2014 at 10:53 PM
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    Got my basic kit today and hooked up the lights and still have to heat wrap the wires and tuck them better so it doesn't look like a "spaghetti factory" as Brad would say.
    Big thanks to Brad for a great quality product and basic and simple preparations and installing.
  17. Jul 28, 2014 at 11:10 PM
    SR5Tac0
    SR5Tac0 Well-Known Member
    Los Angeles
    98 SR5 V6 4x4
    Replaced my fuel filter today. Nothing special. Just looking for a little more MPG's.
  18. Jul 29, 2014 at 1:26 AM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    I havent had them try and sell me anything yet, the first time I went in I had just changed all of my ball joints myself so I dont think they were gonna bother. After getting like 4 alignments already this year I think its been worth it!
  19. Jul 29, 2014 at 7:11 AM
    Project1stGen
    Project1stGen Active Member
    Tony
    Texas
    01 tacoma prerunner sr5
    Roll bar Led light Kc lights Hid lights Headlights Nfab bar Extreme offroad sticker Subs Head unit MUDs Rims 3 inch lift Exhaust Cool air intake Bushwhackers seat covers Floor mats Steering cover Tint *bedliner Old all terrain Powdered coated front bumper Uni chip
    Did my halos
  20. Jul 29, 2014 at 7:23 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Firestone hates me, I go in there all the time though its a much easier job for them now than before.. I to know them by name and vice versa, and only let a select few do the alignment work.
