  1. Sep 2, 2014 at 3:39 AM
    x Taco
    x Taco Member
    Marcus
    Covina/San Gabriel
    Prerunner
    Lsk bumper bilsteins 2.0 10 7100 12 kicker fabtech coilovers kenwood head stereo etc Check out my build http://www.tacomaworld.com/forum/1st-gen-builds/342757-sasquatch-build.html#post9116255
    I just finished putting a 6 inch led bar on my main bar put a bar of angle iron to support the led bar and to protect my HIDs. Going to be putting a second led bar inside my skid plate soon. What do u guys think?
  2. Sep 2, 2014 at 5:32 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Headers are getting put on now
  3. Sep 2, 2014 at 6:26 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I simply welded the flange to the pipe so now all I have to do is unscrew the o2 sensor instead of fighting with those stupid studs. I'm pretty sure I did it on both of them, as well.
  4. Sep 2, 2014 at 6:53 AM
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    Changed the plugs and fuel filter, and did the deck plate mod over the holiday.
  5. Sep 2, 2014 at 8:41 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Yes we leave from CoR Wednesday morning.
  6. Sep 2, 2014 at 8:46 AM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    just ordered some CVJ's w/ silicone boots & the ECGS bushing fix, diff seal, removal tool, and install tool. Also going on the hunt for a low mile 3rz engine today.
  7. Sep 2, 2014 at 8:50 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Sticking with the 3rz?
  8. Sep 2, 2014 at 8:54 AM
    Chinle
    Chinle Active Member
    Tom
    Wichita, KS
    02 Red X-cab 3.4 5-speed SR5 3" OME lift
    ARB bar, XRC2 9500lb winch, Full OME set-up, 882's w/ JK spacer, dakar w/ D6XL AAL, Camburg UCA's, extended brake line, Snugtop Rebel, Weathertech mats, extended rear breather, Rigid Dually D2's, Odyssey Dual battery, Blue Sea ML-ACR, Blue Sea Fuse Block, Dometic CFX65DZ more to come, albeit slowly.
    Just had the shop put my new OME kit on. 833, dakar w/ AAL, camburg uniball UCAs, BPV, cut off the exhaust since that bracket seemed to put the tail pipe right in the way of the leaf. Drives nice, just a bit stiff in the front. Next up, some kind of bumper/winch combo. Before and after shots to start.
    DSC_0895_zps13f4dcc2_41d1259b4f8bf0735a7eb5bbfc034328cee69a46.jpgDSC_0945_zpsa385b8dd_e418b5092fd7d301fe3f656d1872e15ee2e48829.jpg I got some vibrations after the install. 90% sure it's the center carrier. Put some washers on as a makeshift drop and it helped slightly. The bearing is shot, so it and a new stake nut are on the way. I've also ordered the drop bracket to help. Debating a single piece drive shaft now. It's only money, right?
    DSC_0946_zps88dcbd7a_9e66f74b11396c3233ee993728e8dd73559d2b4e.jpgDSC_0939_zpsa9220ac4_e97746096396bcc28aa273af188a54ef3207d3e2.jpg
  9. Sep 2, 2014 at 9:00 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    yea. I figure it will be the best route to go. Considering my truck is already a 3rz it would probably cause my mechanic a lot of headaches and would cost me a lot more $ if i went with a 5vz. If I still am lacking power after i regear i will probably throw a supercharger on it. I don't need a crazy amount of power to make me happy.
    Anyone know where i should begin looking for a low mile japanese import engine?
  10. Sep 2, 2014 at 9:13 AM
    NoTown98Yota
    NoTown98Yota Whiskey Throttle FTW!
    Scott
    Reno, NV
    '98 Tacoma 3.4L V6 W/E-Locker
    -Leer shell with Yakima MegaWarrior -K&N FIPK -18" Magnaflow dumped after axle -Clear headlights -Blacked out bumpers, wheels, badges, mirrors, fuel door, door handles, tail lights, corner markers and turn signals -White LED gauge lights -SpiderTrax 1.5" Spacers -Pinch Weld Mod -Ultra Gauge -6 Switch Plate under single din stereo -Custom Battle Born bedside decals -Eibach 620# coils -Bilstein 5100's -Dakars -Toytec 1" Lift Shackles
    Truck looks awesome man!
  11. Sep 2, 2014 at 9:16 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Are you swapping it yourself? If so let me know if you need any help.
  12. Sep 2, 2014 at 9:21 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    thanks bro. Im having my mechanic buddy do it for me. I think he knows what he is doing. That project is a little beyond my experience level.
  13. Sep 2, 2014 at 9:29 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    1jz twin turbo 30-50k miles $1310
    http://www.jdmenginescorp.com/engin...o-2.5l-1989---1993-toyota-supra-engine-only--
  14. Sep 2, 2014 at 9:33 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Ordered a AFE Pro Dry S filter and Currie EZ tire deflator. Let the off-roading continue! :mudding:
  15. Sep 2, 2014 at 9:33 AM
    TashcomerTexas
  16. Sep 2, 2014 at 9:55 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    882s and nitrochargers up front with new rack bushings and APEX leaves in the rear with 10" Billy's and longer shackles. Fighting the drive shaft vibrations now. Just did the CSB.
  17. Sep 2, 2014 at 10:17 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
  18. Sep 2, 2014 at 10:18 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Did you put axle shims in? What is CSB?
  19. Sep 2, 2014 at 10:21 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thanks!
  20. Sep 2, 2014 at 10:37 AM
    TashcomerTexas
    No prob.
    Here's another 3rz, this ones in Texas $1399 OBO
    http://m.ebay.com/itm/351154410294?nav=SEARCH
