  1. Sep 30, 2014 at 1:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This. It is basically covering the inner tie rod as well.
  2. Sep 30, 2014 at 1:25 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    It has nothing to do with the inner tie rod.
    That is, if he talking about the umbrella shaped rubber part directly under the vise grips in this pic.
  3. Sep 30, 2014 at 1:31 PM
    ChrisPayne
    ChrisPayne Active Member
    Nevada
    Murdered out 04 sitting on 35s
    6 inch IFS lift w/ full coilovers
    Unfortunately not. It is above that. lemme run to truck and take pic
  4. Sep 30, 2014 at 1:32 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Added a pic to the previous post.
  5. Sep 30, 2014 at 1:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I read it wrong thank you for clarifying.
  6. Sep 30, 2014 at 1:41 PM
    ChrisPayne
    Nevada
  7. Sep 30, 2014 at 2:11 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Yeah I figured but it was but it was Sunday night when I was ordering so I just went with Amazon.
  8. Sep 30, 2014 at 2:19 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
  9. Sep 30, 2014 at 2:25 PM
    Dirty Pool
    99 XCAB V6 MT TRD
  10. Sep 30, 2014 at 2:32 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Also fits the 3.4 and the 4.0. On my 3.4 the D3 is close/rubs the oil cooler hose so I use the D1.
    Originally I wanted to "stock" just one filter (D3) for my 3.4 and 4.0.
    Just happen to have a handy pic.
  11. Sep 30, 2014 at 2:33 PM
    ChrisPayne
    Nevada
    Do you know if i can undo those bolts, disassemble, then re-install everything? I would be surprised if i had to take off the whole rack and pinion set up
  12. Sep 30, 2014 at 3:01 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    A complete rebuild as shown in the links aren't necessary but can be better for you in the long run if you're taking the s/c off anyways. Depends how many miles you got on it, etc.
    A simple oil change is just a matter of taking off the nose cone which should be a walk in the park.
    And happy 1000 posts to me.
  13. Sep 30, 2014 at 3:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also fits the 7mgte. Im sure they fit a lot of toyota motors really.
  14. Sep 30, 2014 at 3:59 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    No need to remove the R+P.
    Heck, pretty much any filter with a 3/4" 16TPI will fit, with in space limitations. I studied up on this once when considering a remote filter set up.
  15. Sep 30, 2014 at 5:04 PM
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
  16. Sep 30, 2014 at 5:13 PM
    ChrisPayne
    Nevada
    Awesome. Then looks like all i have to do is undo a few bolts and slide off! :D
  17. Sep 30, 2014 at 5:14 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yea, I was tired of it on my 1st change at 500 miles and yes on the additional POFs. I had it all sorted out with SS braid hose and AN fittings but kept reading about leaky this or that and hit and miss quality on the adapters.
    So, at my second change I made up a drip catcher for the filter and convinced myself that pulling the skid plate for an oil change was just part of good off road PM to otherwise "inspect things".
    The little notches in the flattened edge of the funnel are for the lip of the oil pan. The whole thing wedges between the pan and diff. All that is required is a single wipe of the dribble from the filter mount. Something no baggie will ever catch.
    For my money, there is just too much wheeling to be done.
  18. Sep 30, 2014 at 5:30 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    No. I wish! I still need to learn to weld. I had my friend who made my front bumper, wrap arounds on my rear bumper, and rock rails make it.
  19. Sep 30, 2014 at 5:35 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
  20. Sep 30, 2014 at 5:44 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    That cage looks sweet, no gussets... But most likely better than mine (none lol) Is it at least tied into the frame in a few spots?
