  1. Oct 21, 2014 at 3:45 PM
    scocar
    scocar hypotenoper
    Dude.
  2. Oct 21, 2014 at 3:59 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Dumb question incoming. One Tail light turns off when braking. Bad bulb or something else?
  3. Oct 21, 2014 at 4:47 PM
    alumaman
    alumaman Well-Known Member
    Yukon
    95 Tacoma
    Header, cold air intake 2" body lift
    New leaf springs and bilstein rear on the rear. I'll get the front shocks installed next and level it out. Nerf bars will be next on the list...
  4. Oct 21, 2014 at 5:12 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Replaced an outer tie rod! Just had an alignment the other day and it was already pulling to the side after I accidentally BFHed the poor thing. Now I got to get back to college for my welding class!
  5. Oct 21, 2014 at 5:29 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    accelerated, up-hill, in 5th gear. It felt nice.
  6. Oct 21, 2014 at 6:38 PM
    NoTown98Yota
    NoTown98Yota Whiskey Throttle FTW!
    Scott
    Reno, NV
    '98 Tacoma 3.4L V6 W/E-Locker
    -Leer shell with Yakima MegaWarrior -K&N FIPK -18" Magnaflow dumped after axle -Clear headlights -Blacked out bumpers, wheels, badges, mirrors, fuel door, door handles, tail lights, corner markers and turn signals -White LED gauge lights -SpiderTrax 1.5" Spacers -Pinch Weld Mod -Ultra Gauge -6 Switch Plate under single din stereo -Custom Battle Born bedside decals -Eibach 620# coils -Bilstein 5100's -Dakars -Toytec 1" Lift Shackles
    Where did you get them? Which ones are they? Me want!
  7. Oct 21, 2014 at 6:57 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Got them from Super Bright LEDs
    Works for me as far as "flood" lighting goes. I can see a lot more than I did before. I'm not saying they are better than actually putting a light back there.
    It's a much cleaner "white" too, the bulbs I had were yellow.
  8. Oct 21, 2014 at 7:04 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Sounds good to me. No problem with alittle rice.
    let me know when you find something.
  9. Oct 21, 2014 at 8:03 PM
    NoTown98Yota
    Scott
    Reno, NV
    Good shit, thanks!
    Thanks! I think doing both might be the way to go.
  10. Oct 21, 2014 at 8:10 PM
    NoTown98Yota
    Scott
    Reno, NV
    Must be true if the king says so. Thanks for the info! I need to get something back there. Just put the shell back on for winter and seeing through those tinted windows at night is damn near impossible.
  11. Oct 21, 2014 at 8:17 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Who know's a lot about clutches or can point me in the right direction?
    As far as I know, I'm at 223K on the stock clutch. PO didn't mention anything about it. Wheeling on Sunday I smoked it pretty good. Now its engaging later (very late) on the pedal. I haven't felt it slipping as of yet, I thought I smelled clutch faintly a couple of times the last two days, but that could just be me worrying.
    Anyways, don't know exactly what's going on, but I'm guessing there's not very much life left on it. So, what are the best options for replacing it, and any good write ups on doing it myself? I've read a little about the Marlin Crawler setup, but they always seem to be out of stock.
  12. Oct 21, 2014 at 8:20 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    That clutch has lasted a pretty good while. How much does toyota want for one?
  13. Oct 21, 2014 at 8:24 PM
    LSC15
    Logan
    2008 TRD D-Cab
    Exactly what I was thinking
  14. Oct 21, 2014 at 8:28 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Mine did the same thing last time I went off roading, but mine has less than 10k miles. It chatters really bad now too. I'm pretty sure it's about junk. I'm not sure what I'm going with next. Probably a metallic clutch from LC Engineering.
  15. Oct 21, 2014 at 8:30 PM
    tomtom
    The Desert SW
    2012 FJ
    I like Marlin Crawler over the stock one. They mix and match components from the same vendor that sells to Toyota. Has a better pedal pressure feel.
    Here's the Camelback search result for "clutch":
    http://parts.camelbacktoyota.com/parts/2003/Toyota/Tacoma/DLX/index.cfm?siteid=214329
    You'll be wanting the pilot bearing, pressure plate, disc and release bearing.
  16. Oct 21, 2014 at 8:31 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    You're hella gonna like me if we where meet up dude.
    I was hearing the QC was going down before they stopped.
  17. Oct 21, 2014 at 8:36 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
  18. Oct 21, 2014 at 8:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So far my trail gear ceramic one is doing great. I love that it never fades when offroading too
  19. Oct 21, 2014 at 8:39 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'm happy with the 20" ers I have in my grill, but it seemed that a bunch of people were complaining about water.
  20. Oct 21, 2014 at 8:43 PM
    NoTown98Yota
    Scott
    Reno, NV
    Thinking about maybe mounting 2 cubes to the roof rack on my shell. Any reason this is a bad idea vs. the 6" bar?
