  1. Oct 22, 2014 at 6:48 PM
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    New air filter, next week oil change, then week after that grease all the zerks......maintenance on a budget:cool:
  2. Oct 22, 2014 at 6:58 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That's my issue. I had a set of 55watt lights run into a relay off my reverse lights w/ a master switch but took em off. I think they're going back on at some point.
  3. Oct 22, 2014 at 7:06 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    What a beaut
  4. Oct 22, 2014 at 7:10 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Looks great. Mine will hopefully be here next week. How did you mount you license plate lights to the bumper?
  5. Oct 22, 2014 at 7:17 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    I believe the newer relentless fab bumpers come with cutouts for the stock licence plate lights. Or at least mine did, it came with some nuts and bolts to make it attach to the bumper.
  6. Oct 22, 2014 at 7:24 PM
    LSC15
    Logan
    2008 TRD D-Cab
    Ok thanks man
  7. Oct 22, 2014 at 7:25 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I did see with the one that you got that i didn't look like it came with the cutouts unless you asked for him to put them in for you.
  8. Oct 22, 2014 at 7:30 PM
    TashcomerTexas
    Y'all know if you can use the tow hitch on that? Armor is on my list.
  9. Oct 22, 2014 at 7:31 PM
    LSC15
    Logan
    2008 TRD D-Cab
    No you can't use your hitch but Eric can fab you one up that's welded to the bumper. He did that for me
  10. Oct 22, 2014 at 7:33 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    They can put one in the bumper. They have a hidden hitch behind the licence plate and one that goes under the bumper.
  11. Oct 22, 2014 at 8:30 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Looking good :) Your probably the last person I need to tell, but is your diff leaking?
    I read they are stopping production on the aluminum bumpers...
    I'm wondering if I can convince them to still make one for me.
  12. Oct 22, 2014 at 9:39 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I didn't do it but my truck did, was getting on the freeway in traffic, we came to a very slow roll and it shut off, I put it in park and it started right up again. I'm not sure if the power went or what, I think the radio was still on but I'm not sure as it got me by surprise, no power breaks/steering all the sudden kinda sucks.
  13. Oct 22, 2014 at 9:41 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Unless theres a crack I doubt thats leaking, otherwise it would be from the flange or bolt. Though good eye, I was just busy checking out the paint job:D
  14. Oct 22, 2014 at 10:35 PM
    paquu
    RI
    42" LED bar
    My diff fill plug came loose and the leak spread just like that.. even upwards. I've re tightened it and now its back to norm. Only reason I suggested it.
  15. Oct 22, 2014 at 10:44 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    You're right, now that I think of it while driving it could get spread like that.
  16. Oct 23, 2014 at 6:04 AM
    BamaToy1997
    Bill
    Navarre, FL
    Thank you!
    The bumper does come with cutouts for the license plate lights. The only thing that I had to do was use different screws since the factory bumper has larger square openings for the plastic spreader nut.
    Yes. The receiver is actually hidden behind the hinged license plate holder. I chose to get the hidden receiver for better ground clearance.
    Yes, it is a small bit of seepage I noticed when I installed the bumper. I think the seal for the fill plug is allowing a little fluid to come out. Good eye!
    And thanks for the comment on the paint job. Took a TON of work.
  17. Oct 23, 2014 at 6:32 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Mine is doing the same ever since I topped it off. I think anyway. I should just wipe the diff down and see.
  18. Oct 23, 2014 at 10:12 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Who's bright idea was it to use phillips head screws for the oil pump? :mad:
  19. Oct 23, 2014 at 10:45 AM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    The same sick individual who found the "perfect" location for the oil filter, starter, fuel filter...
  20. Oct 23, 2014 at 10:48 AM
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Just cuz everyone does it doesn't make it a good idea ;)
