  1. Nov 25, 2014 at 9:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    198-202* is pretty much normal for mine. Large swings in temps might indicate some trapped air in the system.
  2. Nov 25, 2014 at 9:55 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    The needle is in the middle somewhere
  3. Nov 25, 2014 at 9:58 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    This is exactly what happened to me after I had the dealer do the water pump and timing belt. Same exact temps you describe. The heater is way too freakin hot now but I have to keep it on or my UG shows 210 sometimes 212. Not sure what's up.
  4. Nov 25, 2014 at 9:59 PM
    GTB129
    GTB129 Well-Known Member
    Greg
    Lower Alabama
    2003 4runner V8 4WD
    Daystar lift, 2002 Tacoma wheels, 285s, more to come.
    I've been thinking this the whole time haha. :wave: Hi everyone.
  5. Nov 25, 2014 at 10:03 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Hmmmm.. yeah I was running around 193* or so before iirc. Weird that the book says to check drive belt tension. Wonder if it's too tight. I don't even see how that could affect it tho. Unless they mean if it's loose and slipping. Idk. It's like 50* out right now. I let it idle first for quite a while then took it for a drive. It stayed at a stead 208 most of the time. It went up to 210 after I ran her hard for a little stretch. Idk I'll see tomorrow on my drive to work and see how she does. Thanks again for all yalls help:) I'll keep u posted on my temps.
  6. Nov 25, 2014 at 10:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You've heard of idiot lights, right? The temp gauge in a Tacoma is an idiot gauge. :p
  7. Nov 25, 2014 at 10:06 PM
    ffirg
    mike
    Anchorage, Alaska
    Before changing mine it ran at 199-204 consistently. After the change it's in the 208-210 range pretty much all the time. Unless I get on the throttle heavy, then it drops to 194. But it spikes to 212 if I'm on a flat highway stretch for a while.
  8. Nov 25, 2014 at 10:08 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yeah, I've never seen mine go above the "just a hair under middle". Even when wheeling uphill stuff in 100* weather.
    Only time I've seen a Tacoma gauge go above middle is when I overheated my 96 from mud caked on the radiator... :eek:
  9. Nov 25, 2014 at 10:17 PM
    GTB129
    Greg
    Lower Alabama
    2003 4runner V8 4WD
    So I washed and quick waxed the truck for show and tell with the potential new buyer. We are meeting in a day or two
    I also took a vacation to Indiana to go bow hunting on a farm that friends of my family owned. Me, my wife, and my son took the Civic, but I got to follow my dads sexy DC red first gen the whole ride :D:D
    Edit: I see now that those pictures do not look as good as they do on my phone haha
  10. Nov 25, 2014 at 10:19 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    This.
  11. Nov 25, 2014 at 10:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Does the FSM say anything about what temp t-stat was standard?
    I seem to recall, that all the 1st gen Tacomas delivered to the Port of Portland were spec'd with a 10* higher t-stats that those delivered to desert climes. I'm pretty sure we installed a 190* unit with the new water pump and t-belt on mine.
  12. Nov 25, 2014 at 10:30 PM
    NightProwler
    Harlan
    Maricopa, Az
    Oh for realz!? Damnit. I read the book and it freakin said up and at no more than a 15* angle. Maybe I misread it. Bummer. Well that should be it then!! Yeah it seemed like it took a long ass time for the stat to open. Well I'll have to swap er around then probly Turkey day. Thank god I can easily do that!! Took me two days to get that shit done. Granted I took my sweet as time. Just got done cleaning up outside. Phew. Well now that I've done this job, I feel much better Better about my mechanical skills;) Learned a lot.
    Man I can't believe how much smoother she runs. Crazy. And glad I got that God awful water pump bearing racket/rattle/squeal gone. Doesn't sound like she's dying anymore. Ha.
  13. Nov 25, 2014 at 10:31 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Frame endcap mod in progress...
  14. Nov 25, 2014 at 10:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Interesting. Not sure how important 10* is, but it may be that harsher winters temps need it.
  15. Nov 25, 2014 at 10:37 PM
    NightProwler
    Harlan
    Maricopa, Az
    I just realized too, although I doubt it matters on the temp, but I'm using he torque app and I forgot I had it set up to my mom's 94 t100 2.7 when I was troubleshooting codes. But again I don't think it matters. anyone have any input that knows how the torque app works? I just started using it so I don't know much. I assume the temp it's showing can only show what the sensor is sending regardless of vehicle specs.
  16. Nov 25, 2014 at 10:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Oh yeah, I forgot. My truck never leaves it's heated garage either. :luvya: mr. moscow
  17. Nov 25, 2014 at 10:52 PM
    NightProwler
    Harlan
    Maricopa, Az
    Ha. Well at least I fucked up on something that's easily fixed;)
  18. Nov 25, 2014 at 10:55 PM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    need help with amount of oil in rear diff. alldatadiy says:
    2.7 qt short wheel base
    3.1 qt extra long wheel base
    didnt know there were different wheelbases? could someone check their fsm for me?
  19. Nov 25, 2014 at 10:57 PM
    PcBuilder14
    Brent
    Nor Cal
    Should be 3.1 qt IIRC :notsure:
  20. Nov 25, 2014 at 10:58 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Just fill till it starts coming out.
