  1. Dec 27, 2014 at 4:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haha I almost put my 1.5s on just to see haha thought I'd have to for a minute since my rims didn't clear the calipers.
  2. Dec 27, 2014 at 4:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wait why are you wanting spacers?? You have skinny tires..
  3. Dec 27, 2014 at 4:47 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Scrub radius applies to all vehicles, not just LT (although depending on the Kit, it can be more noticeable). See below for a visual (even if it is a strut setup instead of dual arms...same concept applies). Essentially imagine an imaginary line between the upper and lower ball joint pivot points. Extend that line to the ground. Ideally you want as close to neutral as you can get so the line would intersect the center of the tire contact patch on the ground. This would provide equal load distribution on the tire. Pushing the tires outboard (reducing backspacing...either by spacers or just different wheel offset) will introduce positive scrub radius and put the load more on the inside of the tires. Aside from the obvious tire wear ramifications, turn initiation, stability, and driver felt perception are all negative effects of scrub radius. And along with that, extra stress on the lug studs and hub bearings.
  4. Dec 27, 2014 at 4:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    And increase in over all good looks...can't forget that...
    Lol
  5. Dec 27, 2014 at 4:51 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's what we refer to as "wide travel" as opposed to "long travel" :luvya:
  6. Dec 27, 2014 at 4:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It works the same doesn't it? :cookiemonster:
    :laugh:
    I..still don't get why you want them..
  7. Dec 27, 2014 at 5:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Spacers/shorter backspacing is not all bad by any means. In fact it can help scrub radius when stepping up in tire size. Everything else being equal (wheels, suspension, blah), if you went from a 29" to a 35" tire, you'd actually introduce negative scrub radius as the tire is taller and the imaginary line will contact the road at a different point. Reducing the backspacing can put that back into check. It's all a tape measurement game.
  8. Dec 27, 2014 at 5:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Whatever pulls the bitches...lol
  9. Dec 27, 2014 at 5:10 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    What spacers are you guys running now? I'd like 1.25 because it's actually noticeable
  10. Dec 27, 2014 at 5:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Not at all. Kings are a giant dick magnet instead. Bro's be striking up conversations.
    Spidertrax or Bora.
    Just make sure to get hubcentric spacers specifically for Toyota hubs.
  11. Dec 27, 2014 at 5:13 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Ha well i meant the size (should've clarified)
  12. Dec 27, 2014 at 5:14 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Seen everything from .75" to 2" in this thread.
    Most commonly used (IMO) are 1.25"
  13. Dec 27, 2014 at 5:15 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Played around w/ some extended bump stops and got them installed the way I want 'em
  14. Dec 27, 2014 at 5:15 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's what I'm looking for, but haven't found any good deals....
  15. Dec 27, 2014 at 5:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have 1.5" allpros. Well..did..still do out back. Not up front anymore.
    Extended thread lugs are also something worth investing in when running spacers.
  16. Dec 27, 2014 at 5:43 PM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Had those also. About to put them on the for sale thread
  17. Dec 27, 2014 at 5:43 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Lug studs right?
    ARP makes some that fit our trucks. They are listed for a Lexus, but work perfectly on ours. I'm not at home to dig up the part number, but google search will tell ya.
  18. Dec 27, 2014 at 5:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Studs would be the more correct way. But extended thread lugs is another easy way to ensure they stay torqued. I check mine every year least twice and they have always been 90ft/lbs no issues. Really helps with the shorter front studs.
    Here is a ET nut next to a standard thread nut
  19. Dec 27, 2014 at 6:01 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Ahh, yeah the Allpro nuts.
    For the both of you going LT with big ol tires...do the studs. Frank will thank you later.
  20. Dec 27, 2014 at 7:03 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Sure you don't want to??? :rofl:
