  1. Feb 8, 2015 at 9:39 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Those are slick rigs jack. I've liked them since they were still concepts.
  2. Feb 8, 2015 at 9:54 PM
    McFlywannabe
    McFlywannabe Well-Known Member
    Jonathon
    Evansville
    08' TRD Sport
    2008 TRD Sport. Leer cap, OMEGA 2.5" suspension lift, ARB off road bumper with Warner winch, 17" American Racing Wheels, 275/70r17 Cooper, cat back exhaust.
    What are the specs on those tires and wheels? Did you lift it also?
  3. Feb 8, 2015 at 11:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    seeing as to how that post is 4 years old..i doubt the OP is still super active..
    but..i can tell you those are Wheeler Type B rims.
  4. Feb 9, 2015 at 10:32 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :burnrubber:
  5. Feb 9, 2015 at 8:03 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Changed my oil
  6. Feb 9, 2015 at 8:07 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    It works better if you put it IN the engine, not on it :thumbsup:
  7. Feb 9, 2015 at 8:08 PM
    LSC15
    Logan
    2008 TRD D-Cab
    I may try that next time and see how it does
  8. Feb 9, 2015 at 8:17 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Remember, look for the correct cap and be sure to use a funnel. :thumbsup:
  9. Feb 9, 2015 at 8:18 PM
    LSC15
    Logan
    2008 TRD D-Cab
    Ok buddy and I'll put the antifreeze in the cap that says 5w-30 right lol
  10. Feb 9, 2015 at 8:20 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    5w-30? That's the size of the engine, right? :notsure:
  11. Feb 9, 2015 at 8:20 PM
    LSC15
    Logan
    2008 TRD D-Cab
    I believe so. Could be wrong though
  12. Feb 9, 2015 at 8:24 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    No that's how many gallons dummy.
  13. Feb 9, 2015 at 8:25 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah, although I don't know what a genie lamp has anything to do with it. It's all Japanese mumbo jumbo, I don't pay attention to that shit anyway. :cool:
  14. Feb 9, 2015 at 8:26 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    due to the generosity of a fellow TW, these showed up on my doorstep today:
    Now I need to get that fuel pump done and the 2.2" back on to match.
  15. Feb 9, 2015 at 8:28 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I feel stupid. :frusty:
    Thanks for the clarification.
    :jellydance:
  16. Feb 9, 2015 at 8:39 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    My truck is a 2 stroke. That's the ratio of oil to gas I mix to put in that hole in that engine. Becaus that's where gas is burned...in the engine. It only makes sense to fill it up there. Those japs are so smart!
  17. Feb 9, 2015 at 8:40 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    my mind is full of fuck
  18. Feb 9, 2015 at 8:46 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Okay, so is it 5 gallons of gas to 30 quarts of oil... or the other way around??
  19. Feb 9, 2015 at 9:21 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Well crawled under the truck and looks like my rack is leaking at the steering shaft input. I'm assuming this means a new rack soon? It's not dripping on the ground yet, but the rack itself is pretty wet. OEM racks run around 800-900$ correct?
  20. Feb 9, 2015 at 9:53 PM
    SeekingZero
    SeekingZero Well-Known Member
    Ben
    Sierra Mountains, CA
    01 Xtracab 4x4 SR5 TRD Supercharged
    Thanks guys. I got em from a fellow TW member. They are Doug Thorley and URD sells them too. Monte is of course right, S/C pulley would be undersized, however that is an idler pulley (much larger), because why not.
    I had them installed because I didn't feel like finding out! ;) After talking with the guy I had do it, the biggest issue was removing the stock manifolds and crossover. They were a PITA for him and he ended up cutting the crossover out. The transmission dipstick had to be moved over slightly and he made a custom bracket to do so and the first Magnaflow Cat had to be cut to fit since it was designed for the shorter stock crossover connection.
    They definitely look odd. I never would have imagined spending the money on a full exhaust on a V6. The power is noticeable and the sound is much more free flowing! Its louder in the cab because you can hear the exhaust flow more through the thin walled tubing as opposed to the cast manifolds. The increase in exhaust flow has also up'd the boost from 6 PSI to 8PSI! Therefore, I'm not going to get a smaller S/C pulley.
