  1. Feb 28, 2015 at 5:30 AM
    Tanner757
    Tanner757 Well-Known Member
    Tanner
    virginia beach
    2003 tacoma v6 4door 4x4 swap
    new radio removed mudflaps weld typhoons bed lined bumper Cb radio air resenator removal flowmaster outlaw
    Sweet and that actually makes a difference
    Boutta pick some up after work
  2. Feb 28, 2015 at 11:11 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Wheeled it a bit today! More pics in build :D
  3. Feb 28, 2015 at 12:58 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Played in the snow today.
  4. Feb 28, 2015 at 2:16 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I made my bumper and garage door track kiss today. It did not go well for either.
  5. Feb 28, 2015 at 2:45 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Yup it sure does. You can isolate which specific fins are the culprits by taping them off and seeing which eliminates the whistle.
    Sweet, what shrouds?
  6. Feb 28, 2015 at 2:53 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Thanks!
    They are Apollo 3.0
  7. Feb 28, 2015 at 4:12 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Hmmmm, interesting. I think im going to ask them to install it on my civic instead. Its my dd and I travel on country roads.
    Cool, thanks for the tip brotha
    Very productive day today....back is killing me know
    Installed blue tooth speaker and LED bulb for my alarm. My buddy forgot them at work when he installed them. But now I'm having issues with my remote start. I must have pulled a wire or something. I'll have my buddy double check the wiring. Also installed a daystar switch for my led bar. And fixed that annoying hitch receiver
  8. Feb 28, 2015 at 4:28 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Looks good! Where did you go?
    Edit: nvm I saw in the az thread.
  9. Feb 28, 2015 at 5:20 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Sycamore creek
    (If anybody else wanted to know)
  10. Feb 28, 2015 at 5:52 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Replaced my belts today with OEM Toyota ones, topped off my fluids and got some parts in today. Will be changing LEDs, relocating rear diff breather, and switch holder this week
  11. Feb 28, 2015 at 5:58 PM
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    Changed from Dino oil to synthetic oil. I'm at 114,000 mi. I used a quart of Lucas oil conditioner and 4.5 quarts of Mobil1. While I was down there I took off my oem slid plate and sprayed that with bedliner paint. Looks great! Runs great! I will keep ya posted if anything leaks.
  12. Feb 28, 2015 at 6:14 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Bled my brakes again today. After installing SS extended front brake lines earlier in the wk, I initially had just bled the front lines, but the pedal didn't feel quite right. So I took another stab at it today bleeding all 5. Turns out my PR bleeder screw was all clogged up with rust and gunk and I couldn't get any fluid out of it. I removed it, used some fluid film and a sewing needle to clear it out and it was good as new. Got a nice pedal now.
    Also greased all the zerks (driveline, OTREs, and leaf spring bushings) topped off my fluids, and vacuumed the hell outta the interior.
  13. Feb 28, 2015 at 6:21 PM
    Tanner757
    Tanner
    virginia beach
    Awesome
    Well picked up some of the trim today and going to try and isolate the fin that's whisteling tomorrow and get it to stop
    Also today i finished swapping the the cs144 alternator
  14. Feb 28, 2015 at 6:59 PM
    EastBayTaco
    EastBayTaco Well-Known Member
    Carlos
    Bay Area, CA
    96 Tacoma 4x4 SR5
    OME Everything! (883 coils with Dakars), Light Racing UCAs, Wheelers SS brake lines, Toytec 1" lift shackles, Magnaflow muffler, CKMA12 ARB On-Board Air Compressor, Custom 80' Sliders
    Got my co workers trucks together.. Stock 3rd gen.. 96 with 3 inch lift.. 97 with 6 in lift! My truck looks so narrow compared to the 97.. Maybe the topper makes it look like that?!?
  15. Feb 28, 2015 at 7:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    He has fatter wider tires.
  16. Feb 28, 2015 at 7:02 PM
    EastBayTaco
    Carlos
    Bay Area, CA
    96 Tacoma 4x4 SR5
    Another pic
  17. Feb 28, 2015 at 7:03 PM
    EastBayTaco
    Carlos
    Bay Area, CA
    96 Tacoma 4x4 SR5
    Yeah he is running 295s.. Compared to my lil 32s
  18. Feb 28, 2015 at 7:04 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Didn't know they released 3rd gens already :anonymous:
  19. Feb 28, 2015 at 7:04 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Go 33s man and you can put some spacers on too
  20. Feb 28, 2015 at 7:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could be worse..
    Could be 32s next to 35s...
