  1. Mar 11, 2015 at 4:13 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    That's how you gap dual electrode plugs!!! Genious!!! Haha
  2. Mar 11, 2015 at 4:15 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    On mine I just disconnected it and left it on the old reservoir. Works fine.
  3. Mar 11, 2015 at 4:31 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Not what I ment, but that too .lol
    Hmmm, but then how do u connect the sensor to the pump?
  4. Mar 11, 2015 at 4:38 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Finished my bumper! f634e02f16064699bdc87ab95726298b_7e49135e422c2f162a94ca2e4b073a7183a6dfe9.jpg181ed6bd9069e2edd6c2a35915230dd1_2ed6ef78bec562d08e87111b403598dbb4a60e62.jpg
  5. Mar 11, 2015 at 4:50 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Looks good Ryan! Dig the light bar too.
  6. Mar 11, 2015 at 6:02 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    :yes: looks mean!
    Nice job man. The light bar brings it together perfectly
  7. Mar 11, 2015 at 6:10 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Thanks bro!
  8. Mar 11, 2015 at 7:31 PM
    Sconce93
    Sconce93 Active Member
    Luke
    Nashville TN
    02 Tacoma TRD
    Heck yes:D theres not a better way to do it on planet earth!!
  9. Mar 11, 2015 at 7:33 PM
    Sconce93
    Luke
    Nashville TN
    02 Tacoma TRD
    Thats killer man, how long did it take you?
  10. Mar 11, 2015 at 7:40 PM
    TIPICOTACO
    Tyler
    nw nj
    Did some "spring cleaning" today.. Took the skids off, sanded the rust and re-painted them; cleaned off the past 4 months of grime/salt, greased all the zerks, did an oil change, cleaned up the engine bay, and cleaned out the bed.
    Discovered this while I was greasing the drive shaft. Rearmost u joint is shot! That would explain the vibes and noise that had been progressively getting worse over the winter
    Are the Spicer u-joints really worth 3x the auto parts store brand? Much beefier? What's with the zerk in the cap on the Spicer 5-1510x? My oem ones had a 90* zerk in the cross. Any other recommendations? GMB? AC Delco? Parts Master?
  11. Mar 11, 2015 at 7:42 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    How can u tell it's shot? I'm a noob of course, so its an honest question
  12. Mar 11, 2015 at 7:42 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    This.
    IIRC, I just cut the two wires going to the sensor, tapped them off, and plugged in the pump as per usual. Too much effort trying to make the senor work with a new reservoir for something that I couldn't care less about. There is no connection between the low fluid sensor and the pump, and the light just doesn't turn on. Never saw it come on with the stock reservoir anyways...
  13. Mar 11, 2015 at 7:43 PM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Is the rear driveshaft the same between PreRunners and 4x4s?
  14. Mar 11, 2015 at 7:47 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Damn, wish I knew this before....so just cut the wires, and hook up the sensor plugs? The pump will still work like this?
  15. Mar 11, 2015 at 7:50 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    What does the front of the drive shaft connect to?
  16. Mar 11, 2015 at 7:52 PM
    Balockay
    Blake
    Cleburne, TX
    It's been a long fucking day :facepalm:
  17. Mar 11, 2015 at 7:55 PM
    Squeaky Penguin
    Brett
    Best picture I could get with my phone in the dark.
    Plug in main 4 wire plug. Connect 2 wire plug to pump. Cut off sensor. Done.
  18. Mar 11, 2015 at 8:03 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Exactly what I did. And same here never had any light come on before I did this either. I wonder if they come pre wired but not actually plugged into anything.
  19. Mar 11, 2015 at 8:08 PM
    Squeaky Penguin
    Brett
    Did some testing of the new springs. Need to find a bigger pile of snow, wasn't fully flexed.
  20. Mar 11, 2015 at 8:13 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    :thumbsup: Young Brett
