  1. Mar 13, 2015 at 11:34 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I use a honey and maple syrup blend, makes the truck smell delicious
  2. Mar 13, 2015 at 11:37 AM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    That must be the full Canadian synthetic.....LOL jk
  3. Mar 13, 2015 at 12:05 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    im kind of nervous with the synthetic, ive heard some horror stories about it ruining diffs or something lol..
  4. Mar 13, 2015 at 12:08 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    When I had my rear gears replaced and rebuilt I was told to run 75w-90 conventional for a while for the break in.
    I change it every oil change now with synthetic after the break in period was done and this next oil change i will be running 75w-140 synthetic
  5. Mar 13, 2015 at 12:18 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Hmm I'll check that out too, thank you. However the only outlet that I have is the cig lighter, don't have the extra 2 outlets.
  6. Mar 13, 2015 at 12:18 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    140?!?!?!
  7. Mar 13, 2015 at 12:22 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    With how I drive the truck 140 should be a better fit.
    Seems guys that drive it hard and or are SC upgrade to the high temp stuff.
    Viscosity is the same 75w so thats not a concern, the 140 over 90 is designed to take higher temps before breaking down it seems.
  8. Mar 13, 2015 at 12:36 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    how often do u change it?
  9. Mar 13, 2015 at 12:39 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Yep nothing under the hood for power outlets.. I'll pull the cig lighter outlet tonight and check it out.
  10. Mar 13, 2015 at 12:41 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Currently I have been running 75w-90 and changing every oil change so like every 7-8k miles
    My grenaded rear end was a mixture of things that lead to its demise.
    60k miles no change, Hard accelerations and shifts on street and dirt, Welded tabs on rear axle without changing fluid, Racing clutch, 38 lbs flywheel, failing ujoints on rear driveshaft and a worn out carrier bearing.
    KAAABOOM!:burnrubber::boom:
  11. Mar 13, 2015 at 12:50 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    hmm i didn't even think about that.. Jerry from BAMF welded on shock mounts to my rear axle and i don't think I've changed the fluid since then.. i was thinking about waiting to change it till i regear in a few months but may just do it sooner..
  12. Mar 13, 2015 at 12:53 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Keep in mind that 75w-90 in colder weather and in a daily driver is most likely best.
    Where I live its warm all year and its not my daily driver so 140 is not going to hurt anything.
    Plus it will help when I tow and or am loaded down in the bed.
  13. Mar 13, 2015 at 12:59 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    how much does it cost to replace a rear end lol?
  14. Mar 13, 2015 at 1:02 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    It cost me a total of $2k because it was a 2 day rush job, parts and labor.
    I have a locker too but when my gears exploded they chewed up everything in side.
    I didnt have a second car then.. if it would have happened now.. it would have just been the cost of new gears and most likely a lot less labor.
  15. Mar 13, 2015 at 1:08 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Might as well so it, its easy and doesn't cost much. I had to do it like 4x in my last truck because i kept going through water before i did the breather mod :D
  16. Mar 13, 2015 at 1:15 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    yeah id rather not have my diff explode :eek: id be screwed.
  17. Mar 13, 2015 at 1:37 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    To add to the bad news, my idle pulley bearings are gone so that might have been the reason behind my trucks whine, ordered a new one $40 should be here tomorrow
  18. Mar 13, 2015 at 2:24 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    I probably will do it next week when my paycheck comes in.. Tires and cb radio set me back pretty good lol..
    After owning the truck for 5-6 years I found out that the previous owner put a little rubber cap on my front diff breather... :frusty:
  19. Mar 13, 2015 at 5:20 PM
    MainahWithaYota
    MainahWithaYota Well-Known Member
    Dallas, GA
    04 DC v6 4x4
    Bought new Energy poly steering bushings, timing belt kit, couple jugs of coolant, transmission fluid & filter along with the gasket needed. Also got a new Denso sensor for the front of the cat. Now just need to find the time to do the work...
  20. Mar 13, 2015 at 5:22 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Swapping out leaf springs for a 3-link setup under Supra TT's truck today.
