  1. Mar 17, 2015 at 7:55 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Well you guys didn't even have to fill out a super long "compatibility" questionnaire TW-Harmony :thumbsup: LOL
  2. Mar 17, 2015 at 7:58 PM
    Madjik_Man
    Colorado Front Range
    Ah... add that to the fact that the 95-97 grille I have on my truck is pushed back more compared to the 01-04.
    I really was hoping for the 95-97 grille combined with the 01-04 bumper. That would have been perfect IMO
  3. Mar 17, 2015 at 8:03 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Well yeah!
    You gotta clean absolutely everything when you buy used. That way after 30,000 miles you can gaze proudly upon your filthy truck and think to yourself: "Wow, I earned every bit of dirt and dust in this truck through all my crazy adventures!" Also, it just doesn't feel like your own until you clean it out and start breakin' it in.
    Now on the subject of toothbrush scrubbin and rear axle buffing?...
    I'm afraid that's just too much anal for me.:p
  4. Mar 17, 2015 at 8:05 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Did you have to replace the master cylinder to use the Tundra kit? Also where did you get the pads? I want the EBC pads but they don't come with the kit.
  5. Mar 17, 2015 at 8:13 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Got the truck back again. It drives much better now. When I picked it up the tech said they flipped the caster to adjust for the toe making it pull. Kinda made sense but seems a little odd
  6. Mar 17, 2015 at 8:46 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I feel ya
  7. Mar 17, 2015 at 8:49 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Toe doesn't affect pull but as long as it drives better now that's all that matters.
    Camber/Caster will affect pull. Camber and Toe affect tire wear.
  8. Mar 17, 2015 at 9:29 PM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    Are you doing an 01-04 front end swap?
    If so let me know how it goes looking to do the same with mine!!
  9. Mar 17, 2015 at 9:31 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    thats soooooooooooo much work though!
  10. Mar 17, 2015 at 9:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    There is a form you fill out on their site. Or yes. Just call them. Very nice people.
    I did that haha it's ridiculous.
    Oh please. You don't even post photos of anything
  11. Mar 17, 2015 at 9:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I used this online order form to help me clarify exactly what I wanted.
    http://www.alcanspring.com/order.htm
    How much lift I wanted, how much weight I carry and how I used my truck were all factors in determining what I wanted from a custom spring pack. Fill out the form and send it off to them. Then follow it up with a phone call to Bill Ford. He will be very clear about what he can do based on what you want.
  12. Mar 17, 2015 at 10:07 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Monte beat me to it.
    Get a tap for the seat bolts will make cleaning the threads a breeze.
    When I was reading that I was thinking did madjik make a second user name.
    You're not supposed to do more then 3 or 4 pumps on those from what I remember.
    This.
  13. Mar 17, 2015 at 10:10 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Plus I so t like other people's funk in my truck lol
    But so worth it <3 look how fresh and pretty it was!
    Now it needs so more TLC again :/
  14. Mar 17, 2015 at 10:10 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Yeah I'm going to do eibach springs to get a little more height up front and UCA's then take it somewhere other than firestone to get it aligned!
    Need to do brakes first. Really need my money tree to start growing
  15. Mar 17, 2015 at 10:16 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I still see lots of rust, get back to work:p
  16. Mar 17, 2015 at 10:18 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    This is what my alcans looked like after a week, granted they weren't supposed to provide lift but they also weren't supposed to lower it.
  17. Mar 17, 2015 at 10:46 PM
    Ice Horse
    Lauren
    Florida
    Impossibru! :p
    That first pic was back on 2009 so it's been a while :laugh:
  18. Mar 17, 2015 at 11:00 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    What is a good treatment for light frame rust? Some kind of gel?
  19. Mar 18, 2015 at 12:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Some people where wondering about the hilux snorkel..well this was just posted on expo
    Probably work on a tacoma. Doesn't look as big
  20. Mar 18, 2015 at 7:07 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Melted the plastic a little:
    Problem is even with the plastic melted and the 90 degree elbow it really just takes forcing it all in and moving shit around.
    Mine is zip tied:
    Hella frush:
