  1. Mar 28, 2015 at 10:47 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    finally had some time off work this weekend to get some stuff done... new lines, calipers, rotors and pads. oil and diff fluid change, outer tie rods, grill surround, replacing part of the bumper... nothing exciting but all stuff that needed to be done. i'll wrap it all up tomorrow and maybe go get some new tires and an alignment
  2. Mar 28, 2015 at 10:57 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Today I pulled the supercharger once again to change some leaking injector o rings. Gas was spraying out onto my block. Fixed that, then drove it to Minnesota. I figured out if I keep it at 3000rpm or more, the knock sensor cel won't activate, so the drive went better than expected. I just had to drive 80mph to achieve that. Got 15mpg, which is better than I was expecting.
  3. Mar 28, 2015 at 10:58 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If the antenna and mount are properly grounded, the 2 ft'er will work just fine.
  4. Mar 28, 2015 at 11:11 PM
    EricU
    EricU Well-Known Member
    Englewood, CO
    i attempted to install some 6.5 components in my truck (01), had clearance with the window rail and the magnet, got the 3/4" MDF plate cut out to fit nice, wired up and went to put the door panel on and the speaker hit the pocket of the door. i got the tweeters installed on the factory brackets, just used some rather awesome and unforgiving super glue and stuck it on the bracket, works great.
    Having the manager order up the 5x7 component version and will have one of the other guys at work teach me some fiberglass work and mount the 6.5 speakers in the corners of my camper shell so i can wire up a little stereo setup back there for camping, powered by a second battery
  5. Mar 28, 2015 at 11:47 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Hmm.. That's odd man, it should be holding pressure pretty nicely. You sure it's getting tightened down enough or are you just running out of threads? If you have to take it apart again you should take pics of both the threads.
  6. Mar 29, 2015 at 7:19 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    John, are you sure all the fitting are NPT? There's NPT, NPS, metric pipe thread, and British pipe thread. None of them like each other. You should be able to thread in a couple turns by hand at least if the threads match.
  7. Mar 29, 2015 at 8:44 AM
    Old School
    Old School You are ignoring covfefe by this member.
    antenna looks good, I'd plasti-derp the mount!;)
  8. Mar 29, 2015 at 8:58 AM
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I it it now. Goop plus tape holding strong :) the barb side is npt, but I think the heat exchanger side is not tapered - that plus pressure makes it hard to deal.
    Thx guys. Presto, when you're ready... I'll give a hand :) Ryan, if I'm ever passing through... Samsies.
  9. Mar 29, 2015 at 8:59 AM
    johnboyTRD
    South SF bay
    +1
  10. Mar 29, 2015 at 10:09 AM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Badass!
  11. Mar 29, 2015 at 10:14 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I see you have a garage "thinking chair" as well.
  12. Mar 29, 2015 at 10:17 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Drove it 370 miles and took a picture (yesterday)
  13. Mar 29, 2015 at 10:18 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I'm in the land of 10,000 lakes. We don't need a portable shower. :p
  14. Mar 29, 2015 at 10:45 AM
    Idahocartel
    Idahocartel Member
    Sean
    Some where in between Idaho and Los Angeles
    03' Gold DC 4x4
    Flat black wrapped hood
    Some friends that do wraps had some extra matte black so I did the hood [​IMG][/IMG]
  15. Mar 29, 2015 at 11:06 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Jacked up the truck and checked for play in the lbj, didn't have much so instead of buying lbj and tie rods I'll order some 4x sliders
  16. Mar 29, 2015 at 12:06 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    Got lots of shits done on the taco yesterday
    and couple more to be done today
    1. Done front and rear plate bumpers
    2. Done put on 3/4 d-rings
    3. Done installed cold air intake filter
    Next is to install the 125w hid Autralia and the led lights
  17. Mar 29, 2015 at 12:51 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    That thing is BeastMode definitely jealous!!!
  18. Mar 29, 2015 at 1:39 PM
    neegdogdig
    3rd Gen DC V6
    Thanks buddy
  19. Mar 29, 2015 at 1:51 PM
    neegdogdig
    3rd Gen DC V6
    Finally got it done installed
    6k led lights:D:D:D
  20. Mar 29, 2015 at 1:55 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Looks awesome, what bumper is that?
