  1. Dec 21, 2011 at 10:25 PM
    #7301
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Thanks Mike.
    I did a lot of greasing when i worked in a John Deere shop..but never have really heard of doing this on a regular basis for my truck. I will do it tomorrow!
  2. Dec 21, 2011 at 10:31 PM
    #7302
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :thumbsup: Don't forget to hit the slip yoke also when you are under there.
  3. Dec 21, 2011 at 10:34 PM
    #7303
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i looked at that today..looked like it needed it too.
    Know how much a carrier bearing costs??
  4. Dec 21, 2011 at 11:00 PM
    #7304
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Damn you guys must have read my mind! I was just thinking 'I wonder when the U joints were lubed last?" today, as I usually do all my own oil changes and cant recall doing recently(like they might've gone 15-20k miles :eek:). Going to do an oil change tomorrow, so looks like I'll have to grease things up while im at it! :cool:
  5. Dec 21, 2011 at 11:01 PM
    #7305
    Digiratus
    Roaming the PNW
    The RedHead
    Sorry, no idea. Are you certain yours needs replacing?
    What you talking about? Greasing u-joints?
  6. Dec 21, 2011 at 11:11 PM
    #7306
    RelentlessFab
    Eric
    Sparks, NV
    sometimes the little ball valve in the zerk freezes up. Try holding the fitting firmly while pumping it in and usually they'll break loose, or try poking the ball with a screw driver to free it before pumping the grease in.
  7. Dec 21, 2011 at 11:19 PM
    #7307
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    When I did mine a few were tough to pump grease into. I just kept pressure on the zerk until it started pumping in. I got the pump to actually click onto a few of the zerks, too.
    On a side note, do you guys wipe up all the grease that comes out of the joints? I tried to do it with some rags but I still ended up with a crap load of grease splattered on the underside of the truck.
  8. Dec 21, 2011 at 11:23 PM
    #7308
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, you want the grease to go into the fitting in through to the bearing caps and start to come out the bearing caps. Even if you can't see it happening, you can hear it, it makes a sort of a soft poping/farting sound when the old grease starts to come out of the bearing cap. :eek:
    You might try adjusting the grease gun tip so that it barely fits onto the zirk fitting. If its too loose, the grease may leak past the tip instead of going into the zirk. The tip on the gun should be adjustable by turning it.
  9. Dec 22, 2011 at 7:34 AM
    #7309
    95Yota4x4
    95Yota4x4 -FURY FROM THE SKY
    J.D.
    Houston, Tx
    Black 95 Tacoma, reg cab, 2.7L 4 cyl, 4x4
    4" lift
    Not sure I like the orange. Thought it would be more unique than just red but I think I might redo it with red. Gonna do calipers & drums too when I do my brakes. Gotta figure out which color the emblems gonna be first so it matches. What do y'all think? I kinda like it but sometimes I think red would look better. I dunno, help me out.
  10. Dec 22, 2011 at 8:01 AM
    #7310
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Installed ARB.
  11. Dec 22, 2011 at 8:08 AM
    #7311
    Mexicant
    Mexicant Well-Known Member
    B
    Crawlerado
    Braap
    Black on the calipers and drums so they DON'T stand out. IMO
  12. Dec 22, 2011 at 8:16 AM
    #7312
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I run fittingless ujoints. Seems i lose the fittings anyways. That may be the case.
    If its cold where the paint is drying it can double or triple or the drying time or even never dry.
    To test this if you want to save your paint roller for the next day toss it in a plastic bag and chuck it in the freezer will still be wet and useable in the morning:D
  13. Dec 22, 2011 at 8:22 AM
    #7313
    Blackdawg
    Monte
    Wyoming/St. Louis
    you'll need to let it dry for around 3 days i bet. Id let it cure another day before another coat. You doing some clear too?
  14. Dec 22, 2011 at 1:30 PM
    #7314
    scocar
    scocar hypotenoper
    Couple of guidelines for paint:
    1. Paint only sticks to one thing: primer (or a lightly sanded previous coat of paint that is sound)
    2. Paint at the correct temperture and humidity ranges provided on the can.
    3. Multiple light coats. You don't want heavy costs because the outside cures before the inside.
    I don't even bother trying to paint stuff during winter, mainly because I have a detached garage without temp control or insulation. Note to self: Next house, 3-car garage fully insulated and temp controlled. With bathroom. And a kitchenette. And a bed.
  15. Dec 22, 2011 at 1:34 PM
    #7315
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    ...sweet!
    What did you do up front suspension wise?
    Winch?
  16. Dec 22, 2011 at 1:55 PM
    #7316
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Im coming to your next house for mod day :)
  17. Dec 22, 2011 at 2:02 PM
    #7317
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    I can paint year round at work! :D
  18. Dec 22, 2011 at 3:29 PM
    #7318
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    took my dads chains to see if they fit. and they do
  19. Dec 22, 2011 at 3:29 PM
    #7319
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    New tires gota get them on at some point. 33x12.50
  20. Dec 22, 2011 at 3:31 PM
    #7320
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I got the tracking number for my Hella Fog Lights!
