  1. Dec 27, 2011 at 12:19 AM
    #7461
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    Damn dude, 5 hours? :eek: really? What kind of snags did you run into?
    I literally just did this tonight and It just took me 45 minutes from start to finish to remove re-build and re-install my starter. Although i have an el stupido body lift and i think that was my saving grace with getting the starter out as it came out right above the upper control arm and under the body.
    seems to of fixed my starting issues for the time being.
  2. Dec 27, 2011 at 3:01 AM
    #7462
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Well the 5 hours was the total time I spend fucking around with truck related things (all my projects I do on my trucks have taken quite a bit longer than people on tw report them to take). Pulling the thing out the first time was such a hassle. Getting back for the back bolt was the hardest part...there just wasn't enough room to fit my arm in there. Going back in went a lot smoother. I wish a rebuild was all it needed, agleast id know what's wrong with it. But the starter passed again and again so I'm still llookin.
  3. Dec 27, 2011 at 6:42 AM
    #7463
    Taco.VR4
    Taco.VR4 Fast Cars, Off-Road Trucks, and Hott Women ;)
    Jay
    Grand Rapids, MI
    '02 Tacoma, '97 3000GT
    5100s, Icon 3 AAL, Custom-built front/rear bumpers, Hybrid seats, 3000GT modified intake box, toolbox, D-rings
    in the 3000gt world we have something called the "click-click-start fix" for what sounds to be the exact same issue. If it is, the problem is the starter is not getting enough voltage to perform properly (in the 3000gt its due to super-tiny mitsu wiring). Maybe something to look into? just a thought...
  4. Dec 27, 2011 at 6:58 AM
    #7464
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I don't know if this is the case with your starter or not, but I had a starter tested and they said it was fine but I replaced it anyways and it fixed my starting issue.
  5. Dec 27, 2011 at 8:18 AM
    #7465
    87xjmike
    Folsom
    98 5lug 2rz
    for the upper back bolt i used a swiveling extension they're life savers in the garage. Although you have an auto so, completely different acess points.
    Theres only a few other things involved with the starting system, relay, batery wires and ignition key lock cylinder.
    Start with some fresh new and larger battery/ground wires then do relay, then go to a rebuild kit for the starter. Got mine delivered for $20. Although i probably could have gotten away with just sanding down my old contacts.
    I'm fairly certain my starter would have tested fine as my starting issue was intermittent. The plunger contact was filthy and i think it wouldn't always get the current through to push in the flywheel gear spinner.
  6. Dec 27, 2011 at 8:33 AM
    #7466
    Slodgetto
    Slodgetto Über Posre
    Silas
    Ah! :D lol
  7. Dec 27, 2011 at 9:50 AM
    #7467
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    My new frame has ~400 miles on it and I'm very happy with how the work looks and the fact that it only took 4 days. They replaced both lca's and some other random shit...for free :D call up Toyota and see how much those cost a piece :)
  8. Dec 27, 2011 at 2:02 PM
    #7468
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    pizza cutters are on
  9. Dec 27, 2011 at 4:29 PM
    #7469
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    Front/rear and transfer case fluid change out...new wipers, new plugs and wires and the best part...33's with wheelers steelies. A great day to be a Toyota enthusiast!
  10. Dec 27, 2011 at 4:39 PM
    #7470
    hoeflich
    florida
    96 3.4L 4X4
    Stuff
    I appreciate it bro...thing looks sweet with that much tire...got three more weeks or so for my relentless plate bumper to come in...going to make this bitch sexy!
  11. Dec 27, 2011 at 4:42 PM
    #7471
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    Installed new headlights and side markers i got for Christmas, broke one of the side marker pressure pin connectors cuz of the damn cold. broke all my grill tabs. FML
  12. Dec 27, 2011 at 4:47 PM
    #7472
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Test fitted my 33x12.50 on cragar soft 8's... So it rubs the body a bit after the pinch weld so i want to tub it. The problem is idk if i should tub it for 35s so if i ever want to upgrade...
    And anyone ever use the premade firewall tubs??
    http://store.gaugemagazine.com/fire-wall-wheel-tubs.aspx
  13. Dec 27, 2011 at 4:59 PM
    #7473
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Had a red led out in the gauge cluster, and my ac bulb has been out...so replaced everything with green led's. Still awaiting the 4runner control panel though, the ac panel isn't bright right now b/c of the stupid orange film.
  14. Dec 27, 2011 at 5:30 PM
    #7474
    newskooler
    newskooler Well-Known Member
    Nick
    Mount Shasta, Ca
    1997 ext cab base, 2012 Base Access cab, 2018 trd OR
    Mall Crawler
    ^^^^hey lonzorizo the green looks sick. one day ill have to make the journey down to redding and bribe you with beer to show me how to do the gauges and the mini head lights:D
    well in the last month ive:
    installed super winch lp8500
    cut the grille to fit the switch and painted it with bsp spray paint-ehh its alright
    relocated winch controller box into engine bay,
    added a POS campershell
    285/75/16E Duratracs
    adjusted the 881s+billys to level it back out
    replaced my cv- was easy once i figured out the new onces splines werent right and got a new oney:D
    changed front diff fluid to royal purple
    rolled over to 120k and at the same time lost a bulb in the cluster
    sorry for the shitty pictures only have a cell phone camera
  15. Dec 27, 2011 at 5:47 PM
    #7475
    lonzorizo
    Lonnie
    Hoopa, Ca
    Anytime man...we can hit up shasta OHV too and do some wheelin. Only about 15 mins from my apt.
  16. Dec 27, 2011 at 5:48 PM
    #7476
    newskooler
    Nick
    Mount Shasta, Ca
    Mall Crawler
    haha yep ive been playing catch up for the past couple of days getting all the things ive wanted to do done, but couldnt because of school.
  17. Dec 27, 2011 at 5:49 PM
    #7477
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    Took it in to get AC foam cleaned, timing belt replaced, water pump replaced, ribbed belt, alternator belt, and seals all done.
  18. Dec 27, 2011 at 6:01 PM
    #7478
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    so next i think im gonna get that bumper tg bumper off you!:D
  19. Dec 27, 2011 at 6:22 PM
    #7479
    lonzorizo
    Lonnie
    Hoopa, Ca
    Negative...what bulb type is the shifter?
  20. Dec 27, 2011 at 6:41 PM
    #7480
    Slodgetto
    Silas
    I say tub for 35s...... be a waste of time to do it for 33's IMHO.... :notsure: What backspacing are the crager soft 8's?
    I 've never heard of the pre-made firewall tubs... and, personally, will definately NOT be using them... :eek: They look way to big for what you'd actually cut out... You'll want a more triangular shaped piece....
